Dot 3 or Dot 4 for clutch master cylinder? non or synthetic? Thank you!
1972 Pantera, stockReplacing clutch master cylinder. Do you recomend Synthetic or non synthetic? Dot 3 or Dot 4? (BTW-Seems Dot 4 is all synthetic at local parts stores). Thanks 1972 Pantera, stock Replacing clutch master cylinder. Do you recomend Synthetic or non synthetic? Dot 3 or Dot 4? (BTW-Seems Dot 4 is all synthetic at local parts stores). Thanks
Cliff, The only difference between DOT3 and DOT4 is the temperature rating, which is irrelevant in a hydraulic clutch application. Any DOT3 or DOT4 would work. I would pro a key use a conventional DOT3…. Mike Sent from my iPad
On Mar 18, 2025, at 09:33, Panteratime via DeTomaso <detomaso@server.detomasolist.com> wrote:
1972 Pantera, stock Replacing clutch master cylinder. Do you recomend Synthetic or non synthetic? Dot 3 or Dot 4? (BTW-Seems Dot 4 is all synthetic at local parts stores). Thanks _______________________________________________
Panteratime
