Re: [DeTomaso] Which axles on which side?
We're talking about front wheel bearing nuts here. Tomas <-----Ursprungligt Meddelande-----> From: Forest Goodhart [forestg@att.net] Sent: 28/5/2016 3:34:04 AM To: detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? I do not think it matters which side the axle is on. I've worked on cars with two lefts and also cars with two rights. Neither ever had any issue with axle nuts coming loose, they are torqued to 360 lb/ft plus or minus From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> To: Tomas Gunnarsson <guson@home.se> Cc: "<detomaso@detomasolist.com>" <detomaso@detomasolist.com> Sent: Friday, May 27, 2016 5:36 PM Subject: Re: [DeTomaso] Which axles on which side? Tomas, You have to remove the driveshaft to see the nut.... Mike Sent from my iPhone On May 27, 2016, at 15:51, "Tomas Gunnarsson" <[1]guson@home.se> wrote: I'll check next time my car has its wheels off! :-D Tomas <-----Ursprungligt Meddelande-----> From: Mike Drew [[2]MikeLDrew@aol.com] Sent: 27/5/2016 9:43:52 PM To: [3]guson@home.se Cc: [4]guido_detomaso@prodigy.net;[5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, I started this thread and the overwhelming response is that the original setup had the LH threads on the LH side of the car. I don't really want to know why, just wanted to know what was done originally.... Cheers! Mike Sent from my iPad
On May 27, 2016, at 12:35 PM, Tomas Gunnarsson <[6]guson@home.se> wrote:
I'm pretty sure it's the other way around. Left side of the car, RH thread.
Tomas <-----Ursprungligt Meddelande-----> From: Guido deTomaso [[7]guido_detomaso@prodigy.net] Sent: 27/5/2016 8:23:20 PM To:
Cc: [11]MikeLDrew@aol.com;[12]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Late to this party. Pretty hard to imagine skidding to a stop and having the left side lug nuts spin off because of angular momentum, the hub stopped but the lugs kept spinning. Similarly hard to imagine the lightweight Pantera axle nut continuing to spin even if not tightened since it has a friction feature. Any fastener tightened at all is going to produce enough friction to be impervious to angular momentum / angular velocity changes. The self-tightening phenomenon is somewhat easy to predict where there's a rotating load and a thread. A bicycle pedal is a good example, if you can visualize the weight of the rider's foot going around a loose thread, visualize the male thread of the pedal shaft "walking" around the female thread of the crank arm, you may be able to predict which side will be self-tightening with a LH thread. Similarly British car knock off caps, if the hubs are put on the wrong side of the car, or the car is towed backwards, good chance the wheels will fall off, hasn't happened to me but I've heard several 1st
accounts. Again if you look at the weight of the car, visualize it walking around the thread, you can predict that the right side of
car will get the LH thread. ( Hit the top of the knock off toward
Hi guys,
I thought I would lead off with he first technical question on the new forum.
The rear axles are marked S and D, for 'left' and 'right' respectively. But that speaks to the thread direction (one of them is reverse
rear of the car to tighten ). LH threaded lug nuts, still used I believe on heavy-duty trucks, same principle. Other times reverse thread seems to be there only in case of catastrophe: Witness every VW and Porsche I'm aware of, they put a LH thread on the left side front spindle. Now this has no weight on the thread ... in order for the nut to want to turn, first the outside bearing would have to start spinning on the spindle, then the d-shape washer would have to fail, and the cotter pin or clamping feature would have to fail, ONLY THEN the reverse thread would save the day, until the heat build up snaps the spindle anyway. On the Pantera ... I don't see any path for the weight of the car to walk around the thread of the axle nut ... maybe it's there but I can't see it. However if under acceleration the flange spline failed, the nuts would tighten if they followed the flange, yes ? Perhaps this is the only reason for the handed thread in this application. Or so it seems to me, I could be wrong. GD From: B Hower via DeTomaso <[13]detomaso@server.detomasolist.com> To: Vinh Ly <[14]vinh.d.ly@gmail.com>; Larry Stock <[15]larrys@panteraparts.com> Cc: Mike Drew <[16]MikeLDrew@aol.com>; "[17]detomaso@detomasolist.com" <[18]detomaso@detomasolist.com> Sent: Sunday, May 22, 2016 12:44 PM Subject: Re: [DeTomaso] Which axles on which side? You would probably never notice a problem. Bud #3400 ( Drive it like there is no tomorrow -- for there may not be ! ) __________________________________________________________________ From: Vinh Ly <[19]vinh.d.ly@gmail.com> To: Larry Stock <[20]larrys@panteraparts.com> Cc: Mike Drew <[21]MikeLDrew@aol.com>; [22]detomaso@detomasolist.com Sent: Friday, May 20, 2016 12:56 PM Subject: Re: [DeTomaso] Which axles on which side? Question, what would be the ramifications if the axles were incorrectly installed on the wrong side? Thanks, Vinh Ly #7445 On Fri, May 20, 2016 at 1:48 PM, Larry Stock <[1][1][23]larrys@panteraparts.com> wrote: S= Sinestro or Left (the Sinister hand that holds the sword when dueling with the Romans) that goes on the Left side (drivers side) Mike, you win the prize for getting this one correct Larry On 5/20/16, 10:33 AM, "DeTomaso on behalf of Mike Drew via DeTomaso" <[2][2][24]detomaso-bounces@server.detomasolist.com on behalf of [3][3][25]detomaso@server.detomasolist.com> wrote: thread,
left to tighten)
It's my belief that the S or left-tighten axle goes on the left side of the car but I can't remember for sure. Can somebody confirm or deny?
Thanks!
And welcome back!
Sent from my iPhone _______________________________________________
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [4][4][26]DeTomaso@server.detomasolist.com [5][5][27]http://server.detomasolist.com/mailman/listinfo/detomaso
_______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [6][6][28]DeTomaso@server.detomasolist.com [7][7][29]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. References 1. mailto:[8][30]larrys@panteraparts.com 2. mailto:[9][31]detomaso-bounces@server.detomasolist.com 3. mailto:[10][32]detomaso@server.detomasolist.com 4. mailto:[11][33]DeTomaso@server.detomasolist.com 5. [12][34]http://server.detomasolist.com/mailman/listinfo/detomaso 6. mailto:[13][35]DeTomaso@server.detomasolist.com 7. [14][36]http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [15][37]DeTomaso@server.detomasolist.com [16][38]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. References 1. [39]mailto:larrys@panteraparts.com 2. [40]mailto:detomaso-bounces@server.detomasolist.com 3. [41]mailto:detomaso@server.detomasolist.com 4. [42]mailto:DeTomaso@server.detomasolist.com 5. [43]http://server.detomasolist.com/mailman/listinfo/detomaso 6. [44]mailto:DeTomaso@server.detomasolist.com 7. [45]http://server.detomasolist.com/mailman/listinfo/detomaso 8. [46]mailto:larrys@panteraparts.com 9. [47]mailto:detomaso-bounces@server.detomasolist.com 10. [48]mailto:detomaso@server.detomasolist.com 11. [49]mailto:DeTomaso@server.detomasolist.com 12. [50]http://server.detomasolist.com/mailman/listinfo/detomaso 13. [51]mailto:DeTomaso@server.detomasolist.com 14. [52]http://server.detomasolist.com/mailman/listinfo/detomaso 15. [53]mailto:DeTomaso@server.detomasolist.com 16. [54]http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [55]DeTomaso@server.detomasolist.com [56]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [57]DeTomaso@server.detomasolist.com [58]http://server.detomasolist.com/mailman/listinfo/detomaso
[8]b.hower3400@yahoo.com;[9]vinh.d.ly@gmail.com;[10]larrys@panteraparts .com person the the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:guson@home.se 2. mailto:MikeLDrew@aol.com 3. mailto:guson@home.se 4. mailto:guido_detomaso@prodigy.net 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guido_detomaso@prodigy.net 8. mailto:b.hower3400@yahoo.com 9. mailto:vinh.d.ly@gmail.com 10. mailto:larrys@panteraparts.com 11. mailto:MikeLDrew@aol.com 12. mailto:detomaso@detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:vinh.d.ly@gmail.com 15. mailto:larrys@panteraparts.com 16. mailto:MikeLDrew@aol.com 17. mailto:detomaso@detomasolist.com 18. mailto:detomaso@detomasolist.com 19. mailto:vinh.d.ly@gmail.com 20. mailto:larrys@panteraparts.com 21. mailto:MikeLDrew@aol.com 22. mailto:detomaso@detomasolist.com 23. mailto:larrys@panteraparts.com 24. mailto:detomaso-bounces@server.detomasolist.com 25. mailto:detomaso@server.detomasolist.com 26. mailto:DeTomaso@server.detomasolist.com 27. http://server.detomasolist.com/mailman/listinfo/detomaso 28. mailto:DeTomaso@server.detomasolist.com 29. http://server.detomasolist.com/mailman/listinfo/detomaso 30. mailto:larrys@panteraparts.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso@server.detomasolist.com 33. mailto:DeTomaso@server.detomasolist.com 34. http://server.detomasolist.com/mailman/listinfo/detomaso 35. mailto:DeTomaso@server.detomasolist.com 36. http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:DeTomaso@server.detomasolist.com 38. http://server.detomasolist.com/mailman/listinfo/detomaso 39. mailto:larrys@panteraparts.com 40. mailto:detomaso-bounces@server.detomasolist.com 41. mailto:detomaso@server.detomasolist.com 42. mailto:DeTomaso@server.detomasolist.com 43. http://server.detomasolist.com/mailman/listinfo/detomaso 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:larrys@panteraparts.com 47. mailto:detomaso-bounces@server.detomasolist.com 48. mailto:detomaso@server.detomasolist.com 49. mailto:DeTomaso@server.detomasolist.com 50. http://server.detomasolist.com/mailman/listinfo/detomaso 51. mailto:DeTomaso@server.detomasolist.com 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:DeTomaso@server.detomasolist.com 58. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. < === message truncated === We're talking about front wheel bearing nuts here. Tomas <-----Ursprungligt Meddelande-----> From: Forest Goodhart [forestg@att.net] Sent: 28/5/2016 3:34:04 AM To: detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? I do not think it matters which side the axle is on. I've worked on cars with two lefts and also cars with two rights. Neither ever had any issue with axle nuts coming loose, they are torqued to 360 lb/ft plus or minus From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> To: Tomas Gunnarsson <guson@home.se> Cc: "<detomaso@detomasolist.com>" <detomaso@detomasolist.com> Sent: Friday, May 27, 2016 5:36 PM Subject: Re: [DeTomaso] Which axles on which side? Tomas, You have to remove the driveshaft to see the nut.... Mike Sent from my iPhone On May 27, 2016, at 15:51, "Tomas Gunnarsson" <[1]guson@home.se> wrote: I'll check next time my car has its wheels off! :-D Tomas <-----Ursprungligt Meddelande-----> From: Mike Drew [[2]MikeLDrew@aol.com] Sent: 27/5/2016 9:43:52 PM To: [3]guson@home.se Cc: [4]guido_detomaso@prodigy.net;[5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, I started this thread and the overwhelming response is that the original setup had the LH threads on the LH side of the car. I don't really want to know why, just wanted to know what was done originally.... Cheers! Mike Sent from my iPad > On May 27, 2016, at 12:35 PM, Tomas Gunnarsson <[6]guson@home.se> wrote: > > I'm pretty sure it's the other way around. Left side of the car, RH > thread. > > Tomas > <-----Ursprungligt Meddelande-----> > From: Guido deTomaso [[7]guido_detomaso@prodigy.net] > Sent: 27/5/2016 8:23:20 PM > To: [8]b.hower3400@yahoo.com;[9]vinh.d.ly@gmail.com;[10]larrys@panteraparts .com > Cc: [11]MikeLDrew@aol.com;[12]detomaso@detomasolist.com > Subject: Re: [DeTomaso] Which axles on which side? > Late to this party. > Pretty hard to imagine skidding to a stop and having the left side lug > nuts spin off because of angular momentum, the hub stopped but the lugs > kept spinning. Similarly hard to imagine the lightweight Pantera axle > nut continuing to spin even if not tightened since it has a friction > feature. Any fastener tightened at all is going to produce enough > friction to be impervious to angular momentum / angular velocity > changes. > The self-tightening phenomenon is somewhat easy to predict where > there's a rotating load and a thread. A bicycle pedal is a good > example, if you can visualize the weight of the rider's foot going > around a loose thread, visualize the male thread of the pedal shaft > "walking" around the female thread of the crank arm, you may be able to > predict which side will be self-tightening with a LH thread. > Similarly British car knock off caps, if the hubs are put on the wrong > side of the car, or the car is towed backwards, good chance the wheels > will fall off, hasn't happened to me but I've heard several 1st person > accounts. Again if you look at the weight of the car, visualize it > walking around the thread, you can predict that the right side of the > car will get the LH thread. ( Hit the top of the knock off toward the > rear of the car to tighten ). LH threaded lug nuts, still used I > believe on heavy-duty trucks, same principle. > Other times reverse thread seems to be there only in case of > catastrophe: Witness every VW and Porsche I'm aware of, they put a LH > thread on the left side front spindle. Now this has no weight on the > thread ... in order for the nut to want to turn, first the outside > bearing would have to start spinning on the spindle, then the d-shape > washer would have to fail, and the cotter pin or clamping feature would > have to fail, ONLY THEN the reverse thread would save the day, until > the heat build up snaps the spindle anyway. > On the Pantera ... I don't see any path for the weight of the car to > walk around the thread of the axle nut ... maybe it's there but I can't > see it. However if under acceleration the flange spline failed, the > nuts would tighten if they followed the flange, yes ? Perhaps this is > the only reason for the handed thread in this application. > Or so it seems to me, I could be wrong. > GD > From: B Hower via DeTomaso <[13]detomaso@server.detomasolist.com> > To: Vinh Ly <[14]vinh.d.ly@gmail.com>; Larry Stock > <[15]larrys@panteraparts.com> > Cc: Mike Drew <[16]MikeLDrew@aol.com>; "[17]detomaso@detomasolist.com" > <[18]detomaso@detomasolist.com> > Sent: Sunday, May 22, 2016 12:44 PM > Subject: Re: [DeTomaso] Which axles on which side? > You would probably never notice a problem. > Bud #3400 ( Drive it like there is no tomorrow -- for there may not > be > ! ) > __________________________________________________________________ > From: Vinh Ly <[19]vinh.d.ly@gmail.com> > To: Larry Stock <[20]larrys@panteraparts.com> > Cc: Mike Drew <[21]MikeLDrew@aol.com>; [22]detomaso@detomasolist.com > Sent: Friday, May 20, 2016 12:56 PM > Subject: Re: [DeTomaso] Which axles on which side? > Question, what would be the ramifications if the axles were > incorrectly > installed on the wrong side? > Thanks, > Vinh Ly > #7445 > On Fri, May 20, 2016 at 1:48 PM, Larry Stock > <[1][1][23]larrys@panteraparts.com> wrote: > S= Sinestro or Left (the Sinister hand that holds the sword when > dueling > with the Romans) that goes on the Left side (drivers side) > Mike, you win the prize for getting this one correct > Larry > On 5/20/16, 10:33 AM, "DeTomaso on behalf of Mike Drew via > DeTomaso" > <[2][2][24]detomaso-bounces@server.detomasolist.com on behalf of > [3][3][25]detomaso@server.detomasolist.com> wrote: >> Hi guys, >> >> I thought I would lead off with he first technical question on the > new >> forum. >> >> The rear axles are marked S and D, for 'left' and 'right' > respectively. >> But that speaks to the thread direction (one of them is reverse > thread, >> left to tighten) >> >> It's my belief that the S or left-tighten axle goes on the left > side > of >> the car but I can't remember for sure. Can somebody confirm or > deny? >> >> Thanks! >> >> And welcome back! >> >> Mike >> >> Sent from my iPhone >> _______________________________________________ >> >> Detomaso Forum NO LONGER Managed by POCA >> Posted emails must not exceed 1.5 Megabytes >> DeTomaso mailing list >> [4][4][26]DeTomaso@server.detomasolist.com >> [5][5][27]http://server.detomasolist.com/mailman/listinfo/detomaso >> >> To manage your subscription (change email address, unsubscribe, > etc.) > use >> the links above. >> > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [6][6][28]DeTomaso@server.detomasolist.com > [7][7][29]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, > etc.) > use the links above. > References > 1. mailto:[8][30]larrys@panteraparts.com > 2. mailto:[9][31]detomaso-bounces@server.detomasolist.com > 3. mailto:[10][32]detomaso@server.detomasolist.com > 4. mailto:[11][33]DeTomaso@server.detomasolist.com > 5. [12][34]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. mailto:[13][35]DeTomaso@server.detomasolist.com > 7. [14][36]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [15][37]DeTomaso@server.detomasolist.com > [16][38]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > References > 1. [39]mailto:larrys@panteraparts.com > 2. [40]mailto:detomaso-bounces@server.detomasolist.com > 3. [41]mailto:detomaso@server.detomasolist.com > 4. [42]mailto:DeTomaso@server.detomasolist.com > 5. [43]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. [44]mailto:DeTomaso@server.detomasolist.com > 7. [45]http://server.detomasolist.com/mailman/listinfo/detomaso > 8. [46]mailto:larrys@panteraparts.com > 9. [47]mailto:detomaso-bounces@server.detomasolist.com > 10. [48]mailto:detomaso@server.detomasolist.com > 11. [49]mailto:DeTomaso@server.detomasolist.com > 12. [50]http://server.detomasolist.com/mailman/listinfo/detomaso > 13. [51]mailto:DeTomaso@server.detomasolist.com > 14. [52]http://server.detomasolist.com/mailman/listinfo/detomaso > 15. [53]mailto:DeTomaso@server.detomasolist.com > 16. [54]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [55]DeTomaso@server.detomasolist.com > [56]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > _______________________________________________ > > > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [57]DeTomaso@server.detomasolist.com > [58]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:guson@home.se 2. mailto:MikeLDrew@aol.com 3. mailto:guson@home.se 4. mailto:guido_detomaso@prodigy.net 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guido_detomaso@prodigy.net 8. mailto:b.hower3400@yahoo.com 9. mailto:vinh.d.ly@gmail.com 10. mailto:larrys@panteraparts.com 11. mailto:MikeLDrew@aol.com 12. mailto:detomaso@detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:vinh.d.ly@gmail.com 15. mailto:larrys@panteraparts.com 16. mailto:MikeLDrew@aol.com 17. mailto:detomaso@detomasolist.com 18. mailto:detomaso@detomasolist.com 19. mailto:vinh.d.ly@gmail.com 20. mailto:larrys@panteraparts.com 21. mailto:MikeLDrew@aol.com 22. mailto:detomaso@detomasolist.com 23. mailto:larrys@panteraparts.com 24. mailto:detomaso-bounces@server.detomasolist.com 25. mailto:detomaso@server.detomasolist.com 26. mailto:DeTomaso@server.detomasolist.com 27. http://server.detomasolist.com/mailman/listinfo/detomaso 28. mailto:DeTomaso@server.detomasolist.com 29. http://server.detomasolist.com/mailman/listinfo/detomaso 30. mailto:larrys@panteraparts.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso@server.detomasolist.com 33. mailto:DeTomaso@server.detomasolist.com 34. http://server.detomasolist.com/mailman/listinfo/detomaso 35. mailto:DeTomaso@server.detomasolist.com 36. http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:DeTomaso@server.detomasolist.com 38. http://server.detomasolist.com/mailman/listinfo/detomaso 39. mailto:larrys@panteraparts.com 40. mailto:detomaso-bounces@server.detomasolist.com 41. mailto:detomaso@server.detomasolist.com 42. mailto:DeTomaso@server.detomasolist.com 43. http://server.detomasolist.com/mailman/listinfo/detomaso 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:larrys@panteraparts.com 47. mailto:detomaso-bounces@server.detomasolist.com 48. mailto:detomaso@server.detomasolist.com 49. mailto:DeTomaso@server.detomasolist.com 50. http://server.detomasolist.com/mailman/listinfo/detomaso 51. mailto:DeTomaso@server.detomasolist.com 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:DeTomaso@server.detomasolist.com 58. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. < === message truncated ===
No we are talking about rear bearing nuts and axles. From: Tomas Gunnarsson <guson@home.se> To: forestg@att.net Cc: detomaso@detomasolist.com Sent: Saturday, May 28, 2016 1:23 PM Subject: Re: [DeTomaso] Which axles on which side? We're talking about front wheel bearing nuts here. Tomas <-----Ursprungligt Meddelande-----> From: Forest Goodhart [forestg@att.net] Sent: 28/5/2016 3:34:04 AM To: detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? I do not think it matters which side the axle is on. I've worked on cars with two lefts and also cars with two rights. Neither ever had any issue with axle nuts coming loose, they are torqued to 360 lb/ft plus or minus From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> To: Tomas Gunnarsson <guson@home.se> Cc: "<detomaso@detomasolist.com>" <detomaso@detomasolist.com> Sent: Friday, May 27, 2016 5:36 PM Subject: Re: [DeTomaso] Which axles on which side? Tomas, You have to remove the driveshaft to see the nut.... Mike Sent from my iPhone On May 27, 2016, at 15:51, "Tomas Gunnarsson" <[1]guson@home.se> wrote: I'll check next time my car has its wheels off! :-D Tomas <-----Ursprungligt Meddelande-----> From: Mike Drew [[2]MikeLDrew@aol.com] Sent: 27/5/2016 9:43:52 PM To: [3]guson@home.se Cc: [4]guido_detomaso@prodigy.net;[5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, I started this thread and the overwhelming response is that the original setup had the LH threads on the LH side of the car. I don't really want to know why, just wanted to know what was done originally.... Cheers! Mike Sent from my iPad > On May 27, 2016, at 12:35 PM, Tomas Gunnarsson <[6]guson@home.se> wrote: > > I'm pretty sure it's the other way around. Left side of the car, RH > thread. > > Tomas > <-----Ursprungligt Meddelande-----> > From: Guido deTomaso [[7]guido_detomaso@prodigy.net] > Sent: 27/5/2016 8:23:20 PM > To: [8]b.hower3400@yahoo.com;[9]vinh.d.ly@gmail.com;[10]larrys@panteraparts .com > Cc: [11]MikeLDrew@aol.com;[12]detomaso@detomasolist.com > Subject: Re: [DeTomaso] Which axles on which side? > Late to this party. > Pretty hard to imagine skidding to a stop and having the left side lug > nuts spin off because of angular momentum, the hub stopped but the lugs > kept spinning. Similarly hard to imagine the lightweight Pantera axle > nut continuing to spin even if not tightened since it has a friction > feature. Any fastener tightened at all is going to produce enough > friction to be impervious to angular momentum / angular velocity > changes. > The self-tightening phenomenon is somewhat easy to predict where > there's a rotating load and a thread. A bicycle pedal is a good > example, if you can visualize the weight of the rider's foot going > around a loose thread, visualize the male thread of the pedal shaft > "walking" around the female thread of the crank arm, you may be able to > predict which side will be self-tightening with a LH thread. > Similarly British car knock off caps, if the hubs are put on the wrong > side of the car, or the car is towed backwards, good chance the wheels > will fall off, hasn't happened to me but I've heard several 1st person > accounts. Again if you look at the weight of the car, visualize it > walking around the thread, you can predict that the right side of the > car will get the LH thread. ( Hit the top of the knock off toward the > rear of the car to tighten ). LH threaded lug nuts, still used I > believe on heavy-duty trucks, same principle. > Other times reverse thread seems to be there only in case of > catastrophe: Witness every VW and Porsche I'm aware of, they put a LH > thread on the left side front spindle. Now this has no weight on the > thread ... in order for the nut to want to turn, first the outside > bearing would have to start spinning on the spindle, then the d-shape > washer would have to fail, and the cotter pin or clamping feature would > have to fail, ONLY THEN the reverse thread would save the day, until > the heat build up snaps the spindle anyway. > On the Pantera ... I don't see any path for the weight of the car to > walk around the thread of the axle nut ... maybe it's there but I can't > see it. However if under acceleration the flange spline failed, the > nuts would tighten if they followed the flange, yes ? Perhaps this is > the only reason for the handed thread in this application. > Or so it seems to me, I could be wrong. > GD > From: B Hower via DeTomaso <[13]detomaso@server.detomasolist.com> > To: Vinh Ly <[14]vinh.d.ly@gmail.com>; Larry Stock > <[15]larrys@panteraparts.com> > Cc: Mike Drew <[16]MikeLDrew@aol.com>; "[17]detomaso@detomasolist.com" > <[18]detomaso@detomasolist.com> > Sent: Sunday, May 22, 2016 12:44 PM > Subject: Re: [DeTomaso] Which axles on which side? > You would probably never notice a problem. > Bud #3400 ( Drive it like there is no tomorrow -- for there may not > be > ! ) > __________________________________________________________________ > From: Vinh Ly <[19]vinh.d.ly@gmail.com> > To: Larry Stock <[20]larrys@panteraparts.com> > Cc: Mike Drew <[21]MikeLDrew@aol.com>; [22]detomaso@detomasolist.com > Sent: Friday, May 20, 2016 12:56 PM > Subject: Re: [DeTomaso] Which axles on which side? > Question, what would be the ramifications if the axles were > incorrectly > installed on the wrong side? > Thanks, > Vinh Ly > #7445 > On Fri, May 20, 2016 at 1:48 PM, Larry Stock > <[1][1][23]larrys@panteraparts.com> wrote: > S= Sinestro or Left (the Sinister hand that holds the sword when > dueling > with the Romans) that goes on the Left side (drivers side) > Mike, you win the prize for getting this one correct > Larry > On 5/20/16, 10:33 AM, "DeTomaso on behalf of Mike Drew via > DeTomaso" > <[2][2][24]detomaso-bounces@server.detomasolist.com on behalf of > [3][3][25]detomaso@server.detomasolist.com> wrote: >> Hi guys, >> >> I thought I would lead off with he first technical question on the > new >> forum. >> >> The rear axles are marked S and D, for 'left' and 'right' > respectively. >> But that speaks to the thread direction (one of them is reverse > thread, >> left to tighten) >> >> It's my belief that the S or left-tighten axle goes on the left > side > of >> the car but I can't remember for sure. Can somebody confirm or > deny? >> >> Thanks! >> >> And welcome back! >> >> Mike >> >> Sent from my iPhone >> _______________________________________________ >> >> Detomaso Forum NO LONGER Managed by POCA >> Posted emails must not exceed 1.5 Megabytes >> DeTomaso mailing list >> [4][4][26]DeTomaso@server.detomasolist.com >> [5][5][27]http://server.detomasolist.com/mailman/listinfo/detomaso >> >> To manage your subscription (change email address, unsubscribe, > etc.) > use >> the links above. >> > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [6][6][28]DeTomaso@server.detomasolist.com > [7][7][29]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, > etc.) > use the links above. > References > 1. mailto:[8][30]larrys@panteraparts.com > 2. mailto:[9][31]detomaso-bounces@server.detomasolist.com > 3. mailto:[10][32]detomaso@server.detomasolist.com > 4. mailto:[11][33]DeTomaso@server.detomasolist.com > 5. [12][34]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. mailto:[13][35]DeTomaso@server.detomasolist.com > 7. [14][36]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [15][37]DeTomaso@server.detomasolist.com > [16][38]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > References > 1. [39]mailto:larrys@panteraparts.com > 2. [40]mailto:detomaso-bounces@server.detomasolist.com > 3. [41]mailto:detomaso@server.detomasolist.com > 4. [42]mailto:DeTomaso@server.detomasolist.com > 5. [43]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. [44]mailto:DeTomaso@server.detomasolist.com > 7. [45]http://server.detomasolist.com/mailman/listinfo/detomaso > 8. [46]mailto:larrys@panteraparts.com > 9. [47]mailto:detomaso-bounces@server.detomasolist.com > 10. [48]mailto:detomaso@server.detomasolist.com > 11. [49]mailto:DeTomaso@server.detomasolist.com > 12. [50]http://server.detomasolist.com/mailman/listinfo/detomaso > 13. [51]mailto:DeTomaso@server.detomasolist.com > 14. [52]http://server.detomasolist.com/mailman/listinfo/detomaso > 15. [53]mailto:DeTomaso@server.detomasolist.com > 16. [54]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [55]DeTomaso@server.detomasolist.com > [56]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > _______________________________________________ > > > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [57]DeTomaso@server.detomasolist.com > [58]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:guson@home.se 2. mailto:MikeLDrew@aol.com 3. mailto:guson@home.se 4. mailto:guido_detomaso@prodigy.net 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guido_detomaso@prodigy.net 8. mailto:b.hower3400@yahoo.com 9. mailto:vinh.d.ly@gmail.com 10. mailto:larrys@panteraparts.com 11. mailto:MikeLDrew@aol.com 12. mailto:detomaso@detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:vinh.d.ly@gmail.com 15. mailto:larrys@panteraparts.com 16. mailto:MikeLDrew@aol.com 17. mailto:detomaso@detomasolist.com 18. mailto:detomaso@detomasolist.com 19. mailto:vinh.d.ly@gmail.com 20. mailto:larrys@panteraparts.com 21. mailto:MikeLDrew@aol.com 22. mailto:detomaso@detomasolist.com 23. mailto:larrys@panteraparts.com 24. mailto:detomaso-bounces@server.detomasolist.com 25. mailto:detomaso@server.detomasolist.com 26. mailto:DeTomaso@server.detomasolist.com 27. http://server.detomasolist.com/mailman/listinfo/detomaso 28. mailto:DeTomaso@server.detomasolist.com 29. http://server.detomasolist.com/mailman/listinfo/detomaso 30. mailto:larrys@panteraparts.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso@server.detomasolist.com 33. mailto:DeTomaso@server.detomasolist.com 34. http://server.detomasolist.com/mailman/listinfo/detomaso 35. mailto:DeTomaso@server.detomasolist.com 36. http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:DeTomaso@server.detomasolist.com 38. http://server.detomasolist.com/mailman/listinfo/detomaso 39. mailto:larrys@panteraparts.com 40. mailto:detomaso-bounces@server.detomasolist.com 41. mailto:detomaso@server.detomasolist.com 42. mailto:DeTomaso@server.detomasolist.com 43. http://server.detomasolist.com/mailman/listinfo/detomaso 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:larrys@panteraparts.com 47. mailto:detomaso-bounces@server.detomasolist.com 48. mailto:detomaso@server.detomasolist.com 49. mailto:DeTomaso@server.detomasolist.com 50. http://server.detomasolist.com/mailman/listinfo/detomaso 51. mailto:DeTomaso@server.detomasolist.com 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:DeTomaso@server.detomasolist.com 58. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. < === message truncated === _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. No we are talking about rear bearing nuts and axles. __________________________________________________________________ From: Tomas Gunnarsson <guson@home.se> To: forestg@att.net Cc: detomaso@detomasolist.com Sent: Saturday, May 28, 2016 1:23 PM Subject: Re: [DeTomaso] Which axles on which side? We're talking about front wheel bearing nuts here. Tomas <-----Ursprungligt Meddelande-----> From: Forest Goodhart [[1]forestg@att.net] Sent: 28/5/2016 3:34:04 AM To: [2]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? I do not think it matters which side the axle is on. I've worked on cars with two lefts and also cars with two rights. Neither ever had any issue with axle nuts coming loose, they are torqued to 360 lb/ft plus or minus From: Mike Drew via DeTomaso <[3]detomaso@server.detomasolist.com> To: Tomas Gunnarsson <[4]guson@home.se> Cc: "<[5]detomaso@detomasolist.com>" <[6]detomaso@detomasolist.com> Sent: Friday, May 27, 2016 5:36 PM Subject: Re: [DeTomaso] Which axles on which side? Tomas, You have to remove the driveshaft to see the nut.... Mike Sent from my iPhone On May 27, 2016, at 15:51, "Tomas Gunnarsson" <[1][7]guson@home.se> wrote: I'll check next time my car has its wheels off! :-D Tomas <-----Ursprungligt Meddelande-----> From: Mike Drew [[2][8]MikeLDrew@aol.com] Sent: 27/5/2016 9:43:52 PM To: [3][9]guson@home.se Cc: [4][10]guido_detomaso@prodigy.net;[5][11]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, I started this thread and the overwhelming response is that the original setup had the LH threads on the LH side of the car. I don't really want to know why, just wanted to know what was done originally.... Cheers! Mike Sent from my iPad > On May 27, 2016, at 12:35 PM, Tomas Gunnarsson <[6][12]guson@home.se> wrote: > > I'm pretty sure it's the other way around. Left side of the car, RH > thread. > > Tomas > <-----Ursprungligt Meddelande-----> > From: Guido deTomaso [[7][13]guido_detomaso@prodigy.net] > Sent: 27/5/2016 8:23:20 PM > To: [8][14]b.hower3400@yahoo.com;[9][15]vinh.d.ly@gmail.com;[10][16]larrys@ panteraparts .com > Cc: [11][17]MikeLDrew@aol.com;[12][18]detomaso@detomasolist.com > Subject: Re: [DeTomaso] Which axles on which side? > Late to this party. > Pretty hard to imagine skidding to a stop and having the left side lug > nuts spin off because of angular momentum, the hub stopped but the lugs > kept spinning. Similarly hard to imagine the lightweight Pantera axle > nut continuing to spin even if not tightened since it has a friction > feature. Any fastener tightened at all is going to produce enough > friction to be impervious to angular momentum / angular velocity > changes. > The self-tightening phenomenon is somewhat easy to predict where > there's a rotating load and a thread. A bicycle pedal is a good > example, if you can visualize the weight of the rider's foot going > around a loose thread, visualize the male thread of the pedal shaft > "walking" around the female thread of the crank arm, you may be able to > predict which side will be self-tightening with a LH thread. > Similarly British car knock off caps, if the hubs are put on the wrong > side of the car, or the car is towed backwards, good chance the wheels > will fall off, hasn't happened to me but I've heard several 1st person > accounts. Again if you look at the weight of the car, visualize it > walking around the thread, you can predict that the right side of the > car will get the LH thread. ( Hit the top of the knock off toward the > rear of the car to tighten ). LH threaded lug nuts, still used I > believe on heavy-duty trucks, same principle. > Other times reverse thread seems to be there only in case of > catastrophe: Witness every VW and Porsche I'm aware of, they put a LH > thread on the left side front spindle. Now this has no weight on the > thread ... in order for the nut to want to turn, first the outside > bearing would have to start spinning on the spindle, then the d-shape > washer would have to fail, and the cotter pin or clamping feature would > have to fail, ONLY THEN the reverse thread would save the day, until > the heat build up snaps the spindle anyway. > On the Pantera ... I don't see any path for the weight of the car to > walk around the thread of the axle nut ... maybe it's there but I can't > see it. However if under acceleration the flange spline failed, the > nuts would tighten if they followed the flange, yes ? Perhaps this is > the only reason for the handed thread in this application. > Or so it seems to me, I could be wrong. > GD > From: B Hower via DeTomaso <[13][19]detomaso@server.detomasolist.com> > To: Vinh Ly <[14][20]vinh.d.ly@gmail.com>; Larry Stock > <[15][21]larrys@panteraparts.com> > Cc: Mike Drew <[16][22]MikeLDrew@aol.com>; "[17][23]detomaso@detomasolist.com" > <[18][24]detomaso@detomasolist.com> > Sent: Sunday, May 22, 2016 12:44 PM > Subject: Re: [DeTomaso] Which axles on which side? > You would probably never notice a problem. > Bud #3400 ( Drive it like there is no tomorrow -- for there may not > be > ! ) > __________________________________________________________________ > From: Vinh Ly <[19][25]vinh.d.ly@gmail.com> > To: Larry Stock <[20][26]larrys@panteraparts.com> > Cc: Mike Drew <[21][27]MikeLDrew@aol.com>; [22][28]detomaso@detomasolist.com > Sent: Friday, May 20, 2016 12:56 PM > Subject: Re: [DeTomaso] Which axles on which side? > Question, what would be the ramifications if the axles were > incorrectly > installed on the wrong side? > Thanks, > Vinh Ly > #7445 > On Fri, May 20, 2016 at 1:48 PM, Larry Stock > <[1][1][23][29]larrys@panteraparts.com> wrote: > S= Sinestro or Left (the Sinister hand that holds the sword when > dueling > with the Romans) that goes on the Left side (drivers side) > Mike, you win the prize for getting this one correct > Larry > On 5/20/16, 10:33 AM, "DeTomaso on behalf of Mike Drew via > DeTomaso" > <[2][2][24][30]detomaso-bounces@server.detomasolist.com on behalf of > [3][3][25][31]detomaso@server.detomasolist.com> wrote: >> Hi guys, >> >> I thought I would lead off with he first technical question on the > new >> forum. >> >> The rear axles are marked S and D, for 'left' and 'right' > respectively. >> But that speaks to the thread direction (one of them is reverse > thread, >> left to tighten) >> >> It's my belief that the S or left-tighten axle goes on the left > side > of >> the car but I can't remember for sure. Can somebody confirm or > deny? >> >> Thanks! >> >> And welcome back! >> >> Mike >> >> Sent from my iPhone >> _______________________________________________ >> >> Detomaso Forum NO LONGER Managed by POCA >> Posted emails must not exceed 1.5 Megabytes >> DeTomaso mailing list >> [4][4][26][32]DeTomaso@server.detomasolist.com >> [5][5][27][33]http://server.detomasolist.com/mailman/listinfo/detomaso >> >> To manage your subscription (change email address, unsubscribe, > etc.) > use >> the links above. >> > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [6][6][28][34]DeTomaso@server.detomasolist.com > [7][7][29][35]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, > etc.) > use the links above. > References > 1. mailto:[8][30][36]larrys@panteraparts.com > 2. mailto:[9][31][37]detomaso-bounces@server.detomasolist.com > 3. mailto:[10][32][38]detomaso@server.detomasolist.com > 4. mailto:[11][33][39]DeTomaso@server.detomasolist.com > 5. [12][34][40]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. mailto:[13][35][41]DeTomaso@server.detomasolist.com > 7. [14][36][42]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [15][37][43]DeTomaso@server.detomasolist.com > [16][38][44]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > References > 1. [39]mailto:[45]larrys@panteraparts.com > 2. [40]mailto:[46]detomaso-bounces@server.detomasolist.com > 3. [41]mailto:[47]detomaso@server.detomasolist.com > 4. [42]mailto:[48]DeTomaso@server.detomasolist.com > 5. [43][49]http://server.detomasolist.com/mailman/listinfo/detomaso > 6. [44]mailto:[50]DeTomaso@server.detomasolist.com > 7. [45][51]http://server.detomasolist.com/mailman/listinfo/detomaso > 8. [46]mailto:[52]larrys@panteraparts.com > 9. [47]mailto:[53]detomaso-bounces@server.detomasolist.com > 10. [48]mailto:[54]detomaso@server.detomasolist.com > 11. [49]mailto:[55]DeTomaso@server.detomasolist.com > 12. [50][56]http://server.detomasolist.com/mailman/listinfo/detomaso > 13. [51]mailto:[57]DeTomaso@server.detomasolist.com > 14. [52][58]http://server.detomasolist.com/mailman/listinfo/detomaso > 15. [53]mailto:[59]DeTomaso@server.detomasolist.com > 16. [54][60]http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [55][61]DeTomaso@server.detomasolist.com > [56][62]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > _______________________________________________ > > > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [57][63]DeTomaso@server.detomasolist.com > [58][64]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:[65]guson@home.se 2. mailto:[66]MikeLDrew@aol.com 3. mailto:[67]guson@home.se 4. mailto:[68]guido_detomaso@prodigy.net 5. mailto:[69]detomaso@detomasolist.com 6. mailto:[70]guson@home.se 7. mailto:[71]guido_detomaso@prodigy.net 8. mailto:[72]b.hower3400@yahoo.com 9. mailto:[73]vinh.d.ly@gmail.com 10. mailto:[74]larrys@panteraparts.com 11. mailto:[75]MikeLDrew@aol.com 12. mailto:[76]detomaso@detomasolist.com 13. mailto:[77]detomaso@server.detomasolist.com 14. mailto:[78]vinh.d.ly@gmail.com 15. mailto:[79]larrys@panteraparts.com 16. mailto:[80]MikeLDrew@aol.com 17. mailto:[81]detomaso@detomasolist.com 18. mailto:[82]detomaso@detomasolist.com 19. mailto:[83]vinh.d.ly@gmail.com 20. mailto:[84]larrys@panteraparts.com 21. mailto:[85]MikeLDrew@aol.com 22. mailto:[86]detomaso@detomasolist.com 23. mailto:[87]larrys@panteraparts.com 24. mailto:[88]detomaso-bounces@server.detomasolist.com 25. mailto:[89]detomaso@server.detomasolist.com 26. mailto:[90]DeTomaso@server.detomasolist.com 27. [91]http://server.detomasolist.com/mailman/listinfo/detomaso 28. mailto:[92]DeTomaso@server.detomasolist.com 29. [93]http://server.detomasolist.com/mailman/listinfo/detomaso 30. mailto:[94]larrys@panteraparts.com 31. mailto:[95]detomaso-bounces@server.detomasolist.com 32. mailto:[96]detomaso@server.detomasolist.com 33. mailto:[97]DeTomaso@server.detomasolist.com 34. [98]http://server.detomasolist.com/mailman/listinfo/detomaso 35. mailto:[99]DeTomaso@server.detomasolist.com 36. [100]http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:[101]DeTomaso@server.detomasolist.com 38. [102]http://server.detomasolist.com/mailman/listinfo/detomaso 39. mailto:[103]larrys@panteraparts.com 40. mailto:[104]detomaso-bounces@server.detomasolist.com 41. mailto:[105]detomaso@server.detomasolist.com 42. mailto:[106]DeTomaso@server.detomasolist.com 43. [107]http://server.detomasolist.com/mailman/listinfo/detomaso 44. mailto:[108]DeTomaso@server.detomasolist.com 45. [109]http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:[110]larrys@panteraparts.com 47. mailto:[111]detomaso-bounces@server.detomasolist.com 48. mailto:[112]detomaso@server.detomasolist.com 49. mailto:[113]DeTomaso@server.detomasolist.com 50. [114]http://server.detomasolist.com/mailman/listinfo/detomaso 51. mailto:[115]DeTomaso@server.detomasolist.com 52. [116]http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:[117]DeTomaso@server.detomasolist.com 54. [118]http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:[119]DeTomaso@server.detomasolist.com 56. [120]http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:[121]DeTomaso@server.detomasolist.com 58. [122]http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [123]DeTomaso@server.detomasolist.com [124]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. < === message truncated === _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [125]DeTomaso@server.detomasolist.com [126]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:forestg@att.net 2. mailto:detomaso@detomasolist.com 3. mailto:detomaso@server.detomasolist.com 4. mailto:guson@home.se 5. mailto:detomaso@detomasolist.com 6. mailto:detomaso@detomasolist.com 7. mailto:guson@home.se 8. mailto:MikeLDrew@aol.com 9. mailto:guson@home.se 10. mailto:guido_detomaso@prodigy.net 11. mailto:detomaso@detomasolist.com 12. mailto:guson@home.se 13. mailto:guido_detomaso@prodigy.net 14. mailto:b.hower3400@yahoo.com 15. mailto:vinh.d.ly@gmail.com 16. mailto:larrys@panteraparts 17. mailto:MikeLDrew@aol.com 18. mailto:detomaso@detomasolist.com 19. mailto:detomaso@server.detomasolist.com 20. mailto:vinh.d.ly@gmail.com 21. mailto:larrys@panteraparts.com 22. mailto:MikeLDrew@aol.com 23. mailto:detomaso@detomasolist.com 24. mailto:detomaso@detomasolist.com 25. mailto:vinh.d.ly@gmail.com 26. mailto:larrys@panteraparts.com 27. mailto:MikeLDrew@aol.com 28. mailto:detomaso@detomasolist.com 29. mailto:larrys@panteraparts.com 30. mailto:detomaso-bounces@server.detomasolist.com 31. mailto:detomaso@server.detomasolist.com 32. mailto:DeTomaso@server.detomasolist.com 33. http://server.detomasolist.com/mailman/listinfo/detomaso 34. mailto:DeTomaso@server.detomasolist.com 35. http://server.detomasolist.com/mailman/listinfo/detomaso 36. mailto:larrys@panteraparts.com 37. mailto:detomaso-bounces@server.detomasolist.com 38. mailto:detomaso@server.detomasolist.com 39. mailto:DeTomaso@server.detomasolist.com 40. http://server.detomasolist.com/mailman/listinfo/detomaso 41. mailto:DeTomaso@server.detomasolist.com 42. http://server.detomasolist.com/mailman/listinfo/detomaso 43. mailto:DeTomaso@server.detomasolist.com 44. http://server.detomasolist.com/mailman/listinfo/detomaso 45. mailto:larrys@panteraparts.com 46. mailto:detomaso-bounces@server.detomasolist.com 47. mailto:detomaso@server.detomasolist.com 48. mailto:DeTomaso@server.detomasolist.com 49. http://server.detomasolist.com/mailman/listinfo/detomaso 50. mailto:DeTomaso@server.detomasolist.com 51. http://server.detomasolist.com/mailman/listinfo/detomaso 52. mailto:larrys@panteraparts.com 53. mailto:detomaso-bounces@server.detomasolist.com 54. mailto:detomaso@server.detomasolist.com 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:DeTomaso@server.detomasolist.com 58. http://server.detomasolist.com/mailman/listinfo/detomaso 59. mailto:DeTomaso@server.detomasolist.com 60. http://server.detomasolist.com/mailman/listinfo/detomaso 61. mailto:DeTomaso@server.detomasolist.com 62. http://server.detomasolist.com/mailman/listinfo/detomaso 63. mailto:DeTomaso@server.detomasolist.com 64. http://server.detomasolist.com/mailman/listinfo/detomaso 65. mailto:guson@home.se 66. mailto:MikeLDrew@aol.com 67. mailto:guson@home.se 68. mailto:guido_detomaso@prodigy.net 69. mailto:detomaso@detomasolist.com 70. mailto:guson@home.se 71. mailto:guido_detomaso@prodigy.net 72. mailto:b.hower3400@yahoo.com 73. mailto:vinh.d.ly@gmail.com 74. mailto:larrys@panteraparts.com 75. mailto:MikeLDrew@aol.com 76. mailto:detomaso@detomasolist.com 77. mailto:detomaso@server.detomasolist.com 78. mailto:vinh.d.ly@gmail.com 79. mailto:larrys@panteraparts.com 80. mailto:MikeLDrew@aol.com 81. mailto:detomaso@detomasolist.com 82. mailto:detomaso@detomasolist.com 83. mailto:vinh.d.ly@gmail.com 84. mailto:larrys@panteraparts.com 85. mailto:MikeLDrew@aol.com 86. mailto:detomaso@detomasolist.com 87. mailto:larrys@panteraparts.com 88. mailto:detomaso-bounces@server.detomasolist.com 89. mailto:detomaso@server.detomasolist.com 90. mailto:DeTomaso@server.detomasolist.com 91. http://server.detomasolist.com/mailman/listinfo/detomaso 92. mailto:DeTomaso@server.detomasolist.com 93. http://server.detomasolist.com/mailman/listinfo/detomaso 94. mailto:larrys@panteraparts.com 95. mailto:detomaso-bounces@server.detomasolist.com 96. mailto:detomaso@server.detomasolist.com 97. mailto:DeTomaso@server.detomasolist.com 98. http://server.detomasolist.com/mailman/listinfo/detomaso 99. mailto:DeTomaso@server.detomasolist.com 100. http://server.detomasolist.com/mailman/listinfo/detomaso 101. mailto:DeTomaso@server.detomasolist.com 102. http://server.detomasolist.com/mailman/listinfo/detomaso 103. mailto:larrys@panteraparts.com 104. mailto:detomaso-bounces@server.detomasolist.com 105. mailto:detomaso@server.detomasolist.com 106. mailto:DeTomaso@server.detomasolist.com 107. http://server.detomasolist.com/mailman/listinfo/detomaso 108. mailto:DeTomaso@server.detomasolist.com 109. http://server.detomasolist.com/mailman/listinfo/detomaso 110. mailto:larrys@panteraparts.com 111. mailto:detomaso-bounces@server.detomasolist.com 112. mailto:detomaso@server.detomasolist.com 113. mailto:DeTomaso@server.detomasolist.com 114. http://server.detomasolist.com/mailman/listinfo/detomaso 115. mailto:DeTomaso@server.detomasolist.com 116. http://server.detomasolist.com/mailman/listinfo/detomaso 117. mailto:DeTomaso@server.detomasolist.com 118. http://server.detomasolist.com/mailman/listinfo/detomaso 119. mailto:DeTomaso@server.detomasolist.com 120. http://server.detomasolist.com/mailman/listinfo/detomaso 121. mailto:DeTomaso@server.detomasolist.com 122. http://server.detomasolist.com/mailman/listinfo/detomaso 123. mailto:DeTomaso@server.detomasolist.com 124. http://server.detomasolist.com/mailman/listinfo/detomaso 125. mailto:DeTomaso@server.detomasolist.com 126. http://server.detomasolist.com/mailman/listinfo/detomaso
Tomas, Uh, no, we're not. Remember I'm the guy that started the thread by asking the question in the first place. We are talking about the axles. There are no axles in the front, only spindles. :) Mike Sent from my iPhone On May 28, 2016, at 13:23, "Tomas Gunnarsson" <guson@home.se> wrote:
Cc: [11]MikeLDrew@aol.com;[12]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Late to this party. Pretty hard to imagine skidding to a stop and having the left side lug nuts spin off because of angular momentum, the hub stopped but the lugs kept spinning. Similarly hard to imagine the lightweight Pantera axle nut continuing to spin even if not tightened since it has a friction feature. Any fastener tightened at all is going to produce enough friction to be impervious to angular momentum / angular velocity changes. The self-tightening phenomenon is somewhat easy to predict where there's a rotating load and a thread. A bicycle pedal is a good example, if you can visualize the weight of the rider's foot going around a loose thread, visualize the male thread of the pedal shaft "walking" around the female thread of the crank arm, you may be able to predict which side will be self-tightening with a LH thread. Similarly British car knock off caps, if the hubs are put on the wrong side of the car, or the car is towed backwards, good chance the wheels will fall off, hasn't happened to me but I've heard several 1st person accounts. Again if you look at the weight of the car, visualize it walking around the thread, you can predict that the right side of
Hi guys,
left to tighten)
Thanks!
And welcome back!
[8]b.hower3400@yahoo.com;[9]vinh.d.ly@gmail.com;[10]larrys@panteraparts .com the the the the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:guson@home.se 2. mailto:MikeLDrew@aol.com 3. mailto:guson@home.se 4. mailto:guido_detomaso@prodigy.net 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guido_detomaso@prodigy.net 8. mailto:b.hower3400@yahoo.com 9. mailto:vinh.d.ly@gmail.com 10. mailto:larrys@panteraparts.com 11. mailto:MikeLDrew@aol.com 12. mailto:detomaso@detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:vinh.d.ly@gmail.com 15. mailto:larrys@panteraparts.com 16. mailto:MikeLDrew@aol.com 17. mailto:detomaso@detomasolist.com 18. mailto:detomaso@detomasolist.com 19. mailto:vinh.d.ly@gmail.com 20. mailto:larrys@panteraparts.com 21. mailto:MikeLDrew@aol.com 22. mailto:detomaso@detomasolist.com 23. mailto:larrys@panteraparts.com 24. mailto:detomaso-bounces@server.detomasolist.com 25. mailto:detomaso@server.detomasolist.com 26. mailto:DeTomaso@server.detomasolist.com 27. http://server.detomasolist.com/mailman/listinfo/detomaso 28. mailto:DeTomaso@server.detomasolist.com 29. http://server.detomasolist.com/mailman/listinfo/detomaso 30. mailto:larrys@panteraparts.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso@server.detomasolist.com 33. mailto:DeTomaso@server.detomasolist.com 34. http://server.detomasolist.com/mailman/listinfo/detomaso 35. mailto:DeTomaso@server.detomasolist.com 36. http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:DeTomaso@server.detomasolist.com 38. http://server.detomasolist.com/mailman/listinfo/detomaso 39. mailto:larrys@panteraparts.com 40. mailto:detomaso-bounces@server.detomasolist.com 41. mailto:detomaso@server.detomasolist.com 42. mailto:DeTomaso@server.detomasolist.com 43. http://server.detomasolist.com/mailman/listinfo/detomaso 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:larrys@panteraparts.com 47. mailto:detomaso-bounces@server.detomasolist.com 48. mailto:detomaso@server.detomasolist.com 49. mailto:DeTomaso@server.detomasolist.com 50. http://server.detomasolist.com/mailman/listinfo/detomaso 51. mailto:DeTomaso@server.detomasolist.com 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. mailto:DeTomaso@server.detomasolist.com 58. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. < === message truncated === _______________________________________________
Forest Goodhart
Tomas Gunnarsson
