Rear stock calipers sticking
I just installed the Wilwoods on the front mount of the back brake and left the stock calipers on the rear mount as a parking brake. The hydraulics are not hooked up to the stock calipers and instead there is a fitting to allow the slave cylinder to breath normally but not gather dirt. The parking brake has in the past not released fully and I've just grown accustomed to not using it. While it all was apart, i tried to figure out why. The parking brake cable bracket on the caliper can be pushed back with some effort, but it does not move freely and the spring has little effect on it. Is that normal and if not, what might be the remedies? Thanks! I just installed the Wilwoods on the front mount of the back brake and left the stock calipers on the rear mount as a parking brake. The hydraulics are not hooked up to the stock calipers and instead there is a fitting to allow the slave cylinder to breath normally but not gather dirt. The parking brake has in the past not released fully and I've just grown accustomed to not using it.A While it all was apart, i tried to figure out why.A The parking brake cable bracket on the caliper can be pushed back with some effort, but it does not move freely and the spring has little effect on it. Is that normal and if not, what might be the remedies? Thanks!
I fixed this problem, the parking brakes not releasing, by lubricating the cables. I tried to use a cable lube tool meant for motorcycles, the parking brake cables were a bit too big in diameter for this to work well. Eventually I just jammed the cable lube spray can tiny hose between the cable and the housing, maybe "sealing" the joint with a rag. Raising the cables high in the wheel well, gravity carried the lube all the way to the end under the car. I used a cable lube from a motorcycle store, it was very expensive, like $18 for a tiny can. Of course, your issue may have a different root cause. GD From: Rob Dumoulin <rob@dumoulins.net> To: Pantera Mail List <detomaso@server.detomasolist.com> Sent: Thursday, September 22, 2016 11:59 AM Subject: [DeTomaso] Rear stock calipers sticking I just installed the Wilwoods on the front mount of the back brake and left the stock calipers on the rear mount as a parking brake. The hydraulics are not hooked up to the stock calipers and instead there is a fitting to allow the slave cylinder to breath normally but not gather dirt. The parking brake has in the past not released fully and I've just grown accustomed to not using it.A While it all was apart, i tried to figure out why.A The parking brake cable bracket on the caliper can be pushed back with some effort, but it does not move freely and the spring has little effect on it. Is that normal and if not, what might be the remedies? Thanks! _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. I fixed this problem, the parking brakes not releasing, by lubricating the cables. I tried to use a cable lube tool meant for motorcycles, the parking brake cables were a bit too big in diameter for this to work well. Eventually I just jammed the cable lube spray can tiny hose between the cable and the housing, maybe "sealing" the joint with a rag. Raising the cables high in the wheel well, gravity carried the lube all the way to the end under the car. I used a cable lube from a motorcycle store, it was very expensive, like $18 for a tiny can. Of course, your issue may have a different root cause. GD __________________________________________________________________ From: Rob Dumoulin <rob@dumoulins.net> To: Pantera Mail List <detomaso@server.detomasolist.com> Sent: Thursday, September 22, 2016 11:59 AM Subject: [DeTomaso] Rear stock calipers sticking I just installed the Wilwoods on the front mount of the back brake and left the stock calipers on the rear mount as a parking brake. The hydraulics are not hooked up to the stock calipers and instead there is a fitting to allow the slave cylinder to breath normally but not gather dirt. The parking brake has in the past not released fully and I've just grown accustomed to not using it.A While it all was apart, i tried to figure out why.A The parking brake cable bracket on the caliper can be pushed back with some effort, but it does not move freely and the spring has little effect on it. Is that normal and if not, what might be the remedies? Thanks! _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [1]DeTomaso@server.detomasolist.com [2]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:DeTomaso@server.detomasolist.com 2. http://server.detomasolist.com/mailman/listinfo/detomaso
Guido deTomaso
Rob Dumoulin
