"Is it possible that the car being on jack stands could have tweaked the car enough to cause the glass to bind as it re-tweaked to its natural state?" "Does anybody think it has anything to do with it being on jack stands prior to glass entry" Rob what is probably nagging your subconsciousness is the idea that the rear glass is a part vital to the structural integrity of the car, and without it being in place the shape will change during jacking. I'm no engineer but that idea sounds absurd and you should eliminate it from your trouble shooting thought process. Sure they flex some, but rather the idea of an imperfection in the seating like Mike D. said sounds more plausible. Is the opening entirely straight sitting on the ground? Is there extreme heat near the suspect cracked areas? Was the glass properly de-burred of all sharp edges? Do you have a seat belt bar mounted to the firewall that might be preloading it? Just shots in the dark. Best of luck, Matt 3584 "Is it possible thatA the car being on jack stands could have tweaked the car enough to cause A A the glass to bind as it re-tweaked to its natural state?" "Does anybody think it has anything to do with it being on jack stands A A prior to glass entry" Rob what is probably nagging your subconsciousness is the idea that the rear glass is a part vital to the structural integrity of the car, and without it being in place the shape will change during jacking. I'm no engineer but that idea sounds absurd and you should eliminate it from your trouble shooting thought process. Sure they flex some, but rather the idea of an imperfection in the seating like Mike D. said sounds more plausible. Is the opening entirely straight sitting on the ground? Is there extreme heat near the suspect cracked areas? Was the glass properly de-burred of all sharp edges? Do you have a seat belt bar mounted to the firewall that might be preloading it? Just shots in the dark.A Best of luck, Matt 3584
I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <nwpantera@gmail.com> wrote:
I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <[1]nwpantera@gmail.com> wrote: "Is it possible thatA the car being on jack stands could have tweaked the car enough to cause A A the glass to bind as it re-tweaked to its natural state?" "Does anybody think it has anything to do with it being on jack stands A A prior to glass entry" Rob what is probably nagging your subconsciousness is the idea that the rear glass is a part vital to the structural integrity of the car, and without it being in place the shape will change during jacking. I'm no engineer but that idea sounds absurd and you should eliminate it from your trouble shooting thought process. Sure they flex some, but rather the idea of an imperfection in the seating like Mike D. said sounds more plausible. Is the opening entirely straight sitting on the ground? Is there extreme heat near the suspect cracked areas? Was the glass properly de-burred of all sharp edges? Do you have a seat belt bar mounted to the firewall that might be preloading it? Just shots in the dark.A Best of luck, Matt 3584 References 1. mailto:nwpantera@gmail.com
I’ve replaced a couple of rear windows over the years with glass and plastic units. None were badly cracked but just had stars, probably from a misguided ratchet or some other tool. I’m looking at the pinch weld area of 6643 right now. It’s double walled and a little wavy but it’s hard to imagine it being so out of shape that it would cause a hot spot / pressure point severe enough to break the glass through the gasket. I’d still put a straight edge on it and flatten it out as well as I could. I doubt body flex caused it since the glass and gasket actually float a bit in the opening…unless you’re using some kind of rigid adhesives...then all bets are off. They should go in quite easily if sized correctly. I gave Mike Drew a tracing of a late model window some time ago FWIW. Michael Frazier From: Rob Dumoulin<mailto:rob@dumoulins.net> Sent: Monday, July 25, 2016 8:08 PM To: Matt Wells<mailto:nwpantera@gmail.com> Cc: Pantera Mail List<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Rear Window Cracked.....again I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <nwpantera@gmail.com> wrote:
I've replaced a couple of rear windows over the years with glass and plastic units. None were badly cracked but just had stars, probably from a misguided ratchet or some other tool. I'm looking at the pinch weld area of 6643 right now. It's double walled and a little wavy but it's hard to imagine it being so out of shape that it would cause a hot spot / pressure point severe enough to break the glass through the gasket. I'd still put a straight edge on it and flatten it out as well as I could. I doubt body flex caused it since the glass and gasket actually float a bit in the opening...unless you're using some kind of rigid adhesives...then all bets are off. They should go in quite easily if sized correctly. I gave Mike Drew a tracing of a late model window some time ago FWIW. Michael Frazier From: [1]Rob Dumoulin Sent: Monday, July 25, 2016 8:08 PM To: [2]Matt Wells Cc: [3]Pantera Mail List Subject: Re: [DeTomaso] Rear Window Cracked.....again I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <nwpantera@gmail.com> wrote: the the that
References 1. mailto:rob@dumoulins.net 2. mailto:nwpantera@gmail.com 3. mailto:detomaso@server.detomasolist.com
I hit my window a few times with a ratchet over the years, and never cracked it. I removed it when I had the car painted, and I polished the roughness out before reinstalling it. As I pushed the final time to get it in it popped. I was pushing with the palm of my hand, and I wasn¹t pushing that hard. So, I had a new one made with safety glass, and this one went in with no drama. That¹s my story anyway. On 7/25/16, 10:33 PM, "DeTomaso on behalf of michael frazier" <detomaso-bounces@server.detomasolist.com on behalf of red3644@hotmail.com> wrote:
Michael Frazier
1. mailto:rob@dumoulins.net 2. mailto:nwpantera@gmail.com 3. mailto:detomaso@server.detomasolist.com _______________________________________________
I had one made of lexan and used that. Nathan Giles
Michael Frazier
On Jul 25, 2016 5:40 PM, "Matt" <nwpantera@gmail.com> wrote: "Is it possible that the car being on jack stands could have tweaked
I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. the the that
Seems like you should inspect the edge of the glass if the window is out, and smooth out any nicks. I think that is where cracks start. Ken From: Will Kooiman <will.kooiman@gmail.com> To: michael frazier <red3644@hotmail.com>; Rob Dumoulin <rob@dumoulins.net>; Matt Wells <nwpantera@gmail.com> Cc: Pantera Mail List <detomaso@server.detomasolist.com> Sent: Friday, July 29, 2016 8:38 PM Subject: Re: [DeTomaso] Rear Window Cracked.....again I hit my window a few times with a ratchet over the years, and never cracked it. I removed it when I had the car painted, and I polished the roughness out before reinstalling it. As I pushed the final time to get it in it popped. I was pushing with the palm of my hand, and I wasn¹t pushing that hard. So, I had a new one made with safety glass, and this one went in with no drama. That¹s my story anyway. On 7/25/16, 10:33 PM, "DeTomaso on behalf of michael frazier" <detomaso-bounces@server.detomasolist.com on behalf of red3644@hotmail.com> wrote:
Michael Frazier
I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <nwpantera@gmail.com> wrote: > "Is it possible that the car being on jack stands could have tweaked the > car enough to cause > the glass to bind as it re-tweaked to its natural state?" > "Does anybody think it has anything to do with it being on jack stands > prior to glass entry" > > Rob what is probably nagging your subconsciousness is the idea that the > rear glass is a part vital to the structural integrity of the car, and > without it being in place the shape will change during jacking. > I'm no engineer but that idea sounds absurd and you should eliminate it > from your trouble shooting thought process. > Sure they flex some, but rather the idea of an imperfection in the seating > like Mike D. said sounds more plausible. > Is the opening entirely straight sitting on the ground? Is there extreme > heat near the suspect cracked areas? Was the glass properly de-burred of > all sharp edges? Do you have a seat belt bar mounted to the firewall that > might be preloading it? > Just shots in the dark. > Best of luck, > Matt > 3584 > >
Michael Frazier
I did not think that the glass was adding structural integrity, but instead thought somehow that the car being on stands two weeks, which may have been closer to three weeks, tweaked the opening just enough that it the glass were a little off it might have been snug on install then cracked during driving. I did not inspect the glass prior to install and was not able to be there when it was done, but my glass guy is a stand up talented guy and will redo it for free. I plan to pass any advice from you guys to him. You are correct that the 5 point harness bar is installed, and it was not installed when the first glass was put in. However, the bar is a perfect fit and has no extra pressure added to make the bolts thread. If anything, I would think it would add support. On Jul 25, 2016 5:40 PM, "Matt" <[3]nwpantera@gmail.com> wrote: the
the that
1. mailto:[4]rob@dumoulins.net 2. mailto:[5]nwpantera@gmail.com 3. mailto:[6]detomaso@server.detomasolist.com _______________________________________________
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [7]DeTomaso@server.detomasolist.com [webicon_gray.png] [8]http://server.detomasolist.com/mailman/listinfo/detomaso
_______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. Seems like you should inspect the edge of the glass if the window is out, and smooth out any nicks. I think that is where cracks start. Ken __________________________________________________________________ From: Will Kooiman <will.kooiman@gmail.com> To: michael frazier <red3644@hotmail.com>; Rob Dumoulin <rob@dumoulins.net>; Matt Wells <nwpantera@gmail.com> Cc: Pantera Mail List <detomaso@server.detomasolist.com> Sent: Friday, July 29, 2016 8:38 PM Subject: Re: [DeTomaso] Rear Window Cracked.....again I hit my window a few times with a ratchet over the years, and never cracked it. I removed it when I had the car painted, and I polished the roughness out before reinstalling it. As I pushed the final time to get it in it popped. I was pushing with the palm of my hand, and I wasnA^1t pushing that hard. So, I had a new one made with safety glass, and this one went in with no drama. ThatA^1s my story anyway. On 7/25/16, 10:33 PM, "DeTomaso on behalf of michael frazier" <[1]detomaso-bounces@server.detomasolist.com on behalf of [2]red3644@hotmail.com> wrote: that list.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com [webicon_gray.png] [10]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:detomaso-bounces@server.detomasolist.com 2. mailto:red3644@hotmail.com 3. mailto:nwpantera@gmail.com 4. mailto:rob@dumoulins.net 5. mailto:nwpantera@gmail.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:DeTomaso@server.detomasolist.com 8. http://server.detomasolist.com/mailman/listinfo/detomaso 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso
Trim the glass (Pattern) an addition 1/16th of an inch all around. That is what an old time Pantera guy told me what to do when I had to replace the glass... That worked perfect. If you are cracking the glass ... it's obviously stressed... and it's pushing to hard on the rubber. Like mentioned before, float the glass. Enjoy, -dt On Fri, Jul 29, 2016 at 9:56 PM, Ken Green via DeTomaso < detomaso@server.detomasolist.com> wrote:
Michael Frazier
the that
Trim the glass (Pattern) an addition 1/16th of an inch all around.A That is what an old time Pantera guy told me what to do when I had to replace the glass...A That worked perfect.A If you are cracking the glass ... it's obviously stressed... and it's pushing to hard on the rubber.A A Like mentioned before, float the glass. Enjoy, -dt On Fri, Jul 29, 2016 at 9:56 PM, Ken Green via DeTomaso <[1]detomaso@server.detomasolist.com> wrote: A A Seems like you should inspect the edge of the glass if the window is A A out, and smooth out any nicks.A I think that is where cracks start. A A Ken A A A __________________________________________________________________ A A From: Will Kooiman <[2]will.kooiman@gmail.com> A A To: michael frazier <[3]red3644@hotmail.com>; Rob Dumoulin A A <[4]rob@dumoulins.net>; Matt Wells <[5]nwpantera@gmail.com> A A Cc: Pantera Mail List <[6]detomaso@server.detomasolist.com> A A Sent: Friday, July 29, 2016 8:38 PM A A Subject: Re: [DeTomaso] Rear Window Cracked.....again A A I hit my window a few times with a ratchet over the years, and never A A cracked it. A A I removed it when I had the car painted, and I polished the roughness A A out A A before reinstalling it.A As I pushed the final time to get it in it A A popped.A I was pushing with the palm of my hand, and I wasnA^1t pushing A A that A A hard. A A So, I had a new one made with safety glass, and this one went in with A A no A A drama. A A ThatA^1s my story anyway. A A On 7/25/16, 10:33 PM, "DeTomaso on behalf of michael frazier" A A <[1][7]detomaso-bounces@server.detomasolist.com on behalf of A A [2][8]red3644@hotmail.com> wrote: A A >A I've replaced a couple of rear windows over the years with glass and A A >A plastic units. A A > A A >A None were badly cracked but just had stars, probably from a A A misguided A A >A ratchet or A A > A A >A some other tool.A I'm looking at the pinch weld area of 6643 right A A >A now.A It's double A A > A A >A walled and a little wavy but it's hard to imagine it being so out of A A >A shape that it would A A > A A >A cause a hot spot / pressure point severe enough to break the glass A A >A through the gasket. A A > A A >A I'd still put a straight edge on it and flatten it out as well as I A A >A could.A I doubt body flex A A > A A >A caused it since the glass and gasket actually float a bit in the A A >A opening...unless you're A A > A A >A using some kind of rigid adhesives...then all bets are off.A They A A >A should go in quite easily A A > A A >A if sized correctly.A I gave Mike Drew a tracing of a late model A A window A A >A some time ago FWIW. A A > A A > A A >A Michael Frazier A A > A A > A A >A From: [1]Rob Dumoulin A A >A Sent: Monday, July 25, 2016 8:08 PM A A >A To: [2]Matt Wells A A >A Cc: [3]Pantera Mail List A A >A Subject: Re: [DeTomaso] Rear Window Cracked.....again A A > A A > A A >A I did not think that the glass was adding structural integrity, but A A >A instead A A >A thought somehow that the car being on stands two weeks, which may A A have A A >A been A A >A closer to three weeks, tweaked the opening just enough that it the A A >A glass A A >A were a little off it might have been snug on install then cracked A A >A during A A >A driving. A A >A I did not inspect the glass prior to install and was not able to be A A >A there A A >A when it was done, but my glass guy is a stand up talented guy and A A will A A >A redo A A >A it for free. I plan to pass any advice from you guys to him. A A >A You are correct that the 5 point harness bar is installed, and it A A was A A >A not A A >A installed when the first glass was put in. However, the bar is a A A >A perfect A A >A fit and has no extra pressure added to make the bolts thread. If A A >A anything, A A >A I would think it would add support. A A >A On Jul 25, 2016 5:40 PM, "Matt" <[3][9]nwpantera@gmail.com> wrote: A A >A > "Is it possible that the car being on jack stands could have A A tweaked A A >A the A A >A > car enough to cause A A >A >A A the glass to bind as it re-tweaked to its natural state?" A A >A > "Does anybody think it has anything to do with it being on jack A A >A stands A A >A >A A prior to glass entry" A A >A > A A >A > Rob what is probably nagging your subconsciousness is the idea A A that A A >A the A A >A > rear glass is a part vital to the structural integrity of the car, A A >A and A A >A > without it being in place the shape will change during jacking. A A >A > I'm no engineer but that idea sounds absurd and you should A A eliminate A A >A it A A >A > from your trouble shooting thought process. A A >A > Sure they flex some, but rather the idea of an imperfection in the A A >A seating A A >A > like Mike D. said sounds more plausible. A A >A > Is the opening entirely straight sitting on the ground? Is there A A >A extreme A A >A > heat near the suspect cracked areas? Was the glass properly A A de-burred A A >A of A A >A > all sharp edges? Do you have a seat belt bar mounted to the A A firewall A A >A that A A >A > might be preloading it? A A >A > Just shots in the dark. A A >A > Best of luck, A A >A > Matt A A >A > 3584 A A >A > A A >A > A A > A A >References A A > A A >A 1. mailto:[4][10]rob@dumoulins.net A A >A 2. mailto:[5][11]nwpantera@gmail.com A A >A 3. mailto:[6][12]detomaso@server.detomasolist.com A A >_______________________________________________ A A > A A > A A >Detomaso Email List is not managed by POCA A A >Posted emails must not exceed 1.5 Megabytes A A >DeTomaso mailing list A A >[7][13]DeTomaso@server.detomasolist.com A A > [webicon_gray.png] A A [8][14]http://server.detomasolist.com/mailman/listinfo/detomaso A A > A A >To manage your subscription (change email address, unsubscribe, etc.) A A use A A >the links above. A A > A A >Members who post to this list grant license to the list to forward any A A >message posted here to all past, current, or future members of the A A list. A A >They also grant the list owner permission to maintain an archive or A A >approve the archiving of list messages. A A _______________________________________________ A A Detomaso Email List is not managed by POCA A A Posted emails must not exceed 1.5 Megabytes A A DeTomaso mailing list A A [9][15]DeTomaso@server.detomasolist.com A A [webicon_gray.png] A A [10][16]http://server.detomasolist.com/mailman/listinfo/detomaso A A To manage your subscription (change email address, unsubscribe, etc.) A A use the links above. A A Members who post to this list grant license to the list to forward any A A message posted here to all past, current, or future members of the A A list. They also grant the list owner permission to maintain an archive A A or approve the archiving of list messages. References A A 1. mailto:[17]detomaso-bounces@server.detomasolist.com A A 2. mailto:[18]red3644@hotmail.com A A 3. mailto:[19]nwpantera@gmail.com A A 4. mailto:[20]rob@dumoulins.net A A 5. mailto:[21]nwpantera@gmail.com A A 6. mailto:[22]detomaso@server.detomasolist.com A A 7. mailto:[23]DeTomaso@server.detomasolist.com A A 8. [24]http://server.detomasolist.com/mailman/listinfo/detomaso A A 9. mailto:[25]DeTomaso@server.detomasolist.com A 10. [26]http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [27]DeTomaso@server.detomasolist.com [28]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:detomaso@server.detomasolist.com 2. mailto:will.kooiman@gmail.com 3. mailto:red3644@hotmail.com 4. mailto:rob@dumoulins.net 5. mailto:nwpantera@gmail.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso-bounces@server.detomasolist.com 8. mailto:red3644@hotmail.com 9. mailto:nwpantera@gmail.com 10. mailto:rob@dumoulins.net 11. mailto:nwpantera@gmail.com 12. mailto:detomaso@server.detomasolist.com 13. mailto:DeTomaso@server.detomasolist.com 14. http://server.detomasolist.com/mailman/listinfo/detomaso 15. mailto:DeTomaso@server.detomasolist.com 16. http://server.detomasolist.com/mailman/listinfo/detomaso 17. mailto:detomaso-bounces@server.detomasolist.com 18. mailto:red3644@hotmail.com 19. mailto:nwpantera@gmail.com 20. mailto:rob@dumoulins.net 21. mailto:nwpantera@gmail.com 22. mailto:detomaso@server.detomasolist.com 23. mailto:DeTomaso@server.detomasolist.com 24. http://server.detomasolist.com/mailman/listinfo/detomaso 25. mailto:DeTomaso@server.detomasolist.com 26. http://server.detomasolist.com/mailman/listinfo/detomaso 27. mailto:DeTomaso@server.detomasolist.com 28. http://server.detomasolist.com/mailman/listinfo/detomaso
Did you check your rubber? There are some terrible after market rubbers floating around. Gesendet vom Irgendwo im Nirgendwo.
Am 30.07.2016 um 17:26 schrieb Don Thomas <don.thomas.ieee@gmail.com>:
1. mailto:detomaso@server.detomasolist.com 2. mailto:will.kooiman@gmail.com 3. mailto:red3644@hotmail.com 4. mailto:rob@dumoulins.net 5. mailto:nwpantera@gmail.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso-bounces@server.detomasolist.com 8. mailto:red3644@hotmail.com 9. mailto:nwpantera@gmail.com 10. mailto:rob@dumoulins.net 11. mailto:nwpantera@gmail.com 12. mailto:detomaso@server.detomasolist.com 13. mailto:DeTomaso@server.detomasolist.com 14. http://server.detomasolist.com/mailman/listinfo/detomaso 15. mailto:DeTomaso@server.detomasolist.com 16. http://server.detomasolist.com/mailman/listinfo/detomaso 17. mailto:detomaso-bounces@server.detomasolist.com 18. mailto:red3644@hotmail.com 19. mailto:nwpantera@gmail.com 20. mailto:rob@dumoulins.net 21. mailto:nwpantera@gmail.com 22. mailto:detomaso@server.detomasolist.com 23. mailto:DeTomaso@server.detomasolist.com 24. http://server.detomasolist.com/mailman/listinfo/detomaso 25. mailto:DeTomaso@server.detomasolist.com 26. http://server.detomasolist.com/mailman/listinfo/detomaso 27. mailto:DeTomaso@server.detomasolist.com 28. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________
<< There are some terrible after market rubbers floating around.>> I could be in trouble... Larry (no rhythm) - Cleveland -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Roland Sent: Saturday, July 30, 2016 11:57 AM To: Don Thomas Cc: Pantera Mail List; Ken Green Subject: Re: [DeTomaso] Rear Window Cracked.....again Did you check your rubber? There are some terrible after market rubbers floating around. Gesendet vom Irgendwo im Nirgendwo. the links above.
message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
participants (9)
Don Thomas
Larry - Ohio Time
Matt
michael frazier
Nathan Giles
Rob Dumoulin
Roland
Will Kooiman
