Dear Michael, I have two Panteras. One has an engine with dyno tested 450 hp and it uses an aluminum Fidenza flywheel. The other Pantera has a 385 hp engine and a stock flywheel. I detect the smallest amount of increased sensitivity with the aluminum flywheel Pantera when starting from a stop. I do not detect that with the heavier flywheel in the other Pantera. Otherwise, I don't find any big advantage with an aluminum flywheel over stock. My most recent engine build uses an aftermarket steel or iron flywheel, which is about 2/3rds of the weight of the stock iron flywheel and about halfway in between the weights of the stock and aluminum units. It seems to be an excellent compromise in reduced weight, cost and compatibility with the other hardware bits at the clutch-flywheel interface. Finally, with a tricked out Cleveland stroker that has plenty of torque, you would be perfectly fine with the stock flywheel or the reduced weight aftermarket iron flywheel. Aluminum flywheels have some bragging rights, higher expense and tiny practical benefits for typical street/highway/occasional track use. Warmest regards, Chuck Engles On Fri, Sep 9, 2016 at 9:41 AM, Michael Barnes wrote:
Looking for some advise please chaps. I'm having my Cleveland stroked out with all the goodies added, Now I've been offered a centre force flywheel and clutch assembly, it's a lot of money for the flywheel, is it worth it? What do you think? Thanks in advance Sent from Michael's iPhone _______________________________________________
I like the Fidanza because it is cheap, new, and easy to find/buy. Being aluminum is a benefit, but I can¹t tell the difference. You can find them on ebay, but I think I bought my last one from one of the Mustang vendors. BTW, I¹m running the same clutch/flywheel/PP on my Pantera and my Cobra. I removed the weights from my Cobra. I can¹t tell a difference whether they are there or not. On 9/9/16, 11:18 AM, "detomaso-bounces@server.detomasolist.com on behalf of cengles@cox.net" <detomaso-bounces@server.detomasolist.com on behalf of cengles@cox.net> wrote:
Dear Michael,
cengles@cox.net
Will Kooiman
