Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19
guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com
You can reach the person managing the list at detomaso-owner@server.detomasolist.com
When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..."
Daily Detomaso List Digest
Today's Topics:
1. Fans and shroud (Jack Donahue) 2. Re: Fans and shroud (Himes, Terry (397C)) 3. Tires for Grp IV Flared Car (MyCars) 4. Re: Tires for Grp IV Flared Car (LSJ) 5. Re: Fans and shroud (Jack Donahue) 6. Re: Fans and shroud (Jack Donahue) 7. Re: Fans and shroud (Larry Stock) 8. McLeod hydraulic throw out (Cullen McCann) 9. Re: Fans and shroud (Ken Green) 10. McLeod hydraulic throw out (Larry Finch) 11. Re: Tires for Grp IV Flared Car (MyCars) 12. Re: Tires for Grp IV Flared Car (MyCars) 13. Re: McLeod hydraulic throw out (Will Kooiman) 14. Re: McLeod hydraulic throw out (Cullen McCann) 15. Re: McLeod hydraulic throw out (Larry Stock) 16. Re: Sanden Compressors noises (Mike Drew) 17. Re: Sanden Compressors noises (Julian Kift) 18. Re: Sanden Compressors noises (Mike Drew) 19. Re: McLeod hydraulic throw out (Larry Finch) 20. Re: McLeod hydraulic throw out (Cullen McCann) 21. NPC, Need transmission suggestions (michael frazier) 22. Re: Sanden Compressors noises (David Nunn) 23. Re: NPC, Need transmission suggestions (bill) 24. Re: Sanden Compressors noises (bill)
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <demongusta@gmail.com> To: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Cc: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov> To: Jack Donahue <demongusta@gmail.com>, "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-)
Terry
"A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!"
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud
Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso
It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com wrote:
To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso DeTomaso Info Page<http://server.detomasolist.com/mailman/listinfo/detomaso> server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ...
Today's Topics:
Jack,
Terry
It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com wrote:
To subscribe or unsubscribe via the World Wide Web, visit [1]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com
Today's Topics:
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<[3]mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@serve r.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>> Subject: [DeTomaso] Fans and shroud
radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
[4]http://server.detomasolist.com/mailman/listinfo/detomaso
DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.co m> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Well said! "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Date: Saturday, September 17, 2016 7:56 AM To: Owen Cooke <owen@tadhgcooke.com<mailto:owen@tadhgcooke.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Owen Cooke <owen@tadhgcooke.com<mailto:owen@tadhgcooke.com>> Sent: Saturday, September 17, 2016 2:19 AM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com<mailto:detomaso-request@server.detomasolist.com> wrote: Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso DeTomaso Info Page<http://server.detomasolist.com/mailman/listinfo/detomaso> server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com<mailto:detomaso-request@server.detomasolist.com> You can reach the person managing the list at detomaso-owner@server.detomasolist.com<mailto:detomaso-owner@server.detomasolist.com> When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..." Daily Detomaso List Digest Today's Topics: 1. Fans and shroud (Jack Donahue) 2. Re: Fans and shroud (Himes, Terry (397C)) 3. Tires for Grp IV Flared Car (MyCars) 4. Re: Tires for Grp IV Flared Car (LSJ) 5. Re: Fans and shroud (Jack Donahue) 6. Re: Fans and shroud (Jack Donahue) 7. Re: Fans and shroud (Larry Stock) 8. McLeod hydraulic throw out (Cullen McCann) 9. Re: Fans and shroud (Ken Green) 10. McLeod hydraulic throw out (Larry Finch) 11. Re: Tires for Grp IV Flared Car (MyCars) 12. Re: Tires for Grp IV Flared Car (MyCars) 13. Re: McLeod hydraulic throw out (Will Kooiman) 14. Re: McLeod hydraulic throw out (Cullen McCann) 15. Re: McLeod hydraulic throw out (Larry Stock) 16. Re: Sanden Compressors noises (Mike Drew) 17. Re: Sanden Compressors noises (Julian Kift) 18. Re: Sanden Compressors noises (Mike Drew) 19. Re: McLeod hydraulic throw out (Larry Finch) 20. Re: McLeod hydraulic throw out (Cullen McCann) 21. NPC, Need transmission suggestions (michael frazier) 22. Re: Sanden Compressors noises (David Nunn) 23. Re: NPC, Need transmission suggestions (bill) 24. Re: Sanden Compressors noises (bill) ---------------------------------------------------------------------- Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com<mailto:CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com>> Content-Type: text/plain; charset=utf-8 Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 ------------------------------ Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov<mailto:terry.himes@jpl.nasa.gov>> To: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov<mailto:D4016E9F.92F3B%thimes@jpl.nasa.gov>> Content-Type: text/plain; charset="utf-8" Jack, Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-) Terry "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov><mailto:thimes@jpl.nasa.gov> ?? From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com><mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Jack, Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-) Terry "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <[3]demongusta@gmail.com<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[4]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <[5]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "[6]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <[7]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it's because I want to, not necessarily NEED to. It ain't broke, but I am fixing it(?). Didn't want to admit that, but...Lol. There really is an ulterior motive, but I just don't want to mention it right now; but I ran my idea past Brassworks - who says they will "build-to-suit" - but the Hall unit looks to be "tried-and-proven". Now - fans. I really don't know the brand name of my fans, but they are suckers - about 12" diameter - and the blades are "curved" - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone's post about the Flex-a-lite's since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [8]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [9]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:demongusta@gmail.com 4. mailto:detomaso@server.detomasolist.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:DeTomaso@server.detomasolist.com 9. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 3 Date: Fri, 16 Sep 2016 10:03:20 -0700 From: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] Tires for Grp IV Flared Car Message-ID: <6fa00360-0d5e-3618-1132-2455f7b0aca2@comcast.net<mailto:6fa00360-0d5e-3618-1132-2455f7b0aca2@comcast.net>> Content-Type: text/plain; charset=utf-8; format=flowed I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy ------------------------------ Message: 4 Date: Fri, 16 Sep 2016 17:08:50 +0000 (UTC) From: LSJ <lashdeep@yahoo.com<mailto:lashdeep@yahoo.com>> To: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Tires for Grp IV Flared Car Message-ID: <1287234121.1004140.1474045730621@mail.yahoo.com<mailto:1287234121.1004140.1474045730621@mail.yahoo.com>> Content-Type: text/plain; charset="utf-8" What size wheel up front? ?LSJ central wines-spirits?? est 1934 625 e street nw washington, dc 20004 centralwines.com facebook.com/CentralLiquors 202-737-2800 From: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Friday, September 16, 2016 1:03 PM Subject: [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- What size wheel up front? LSJ central wines-spirits est 1934 625 e street nw washington, dc 20004 [1]centralwines.com [2]facebook.com/CentralLiquors 202-737-2800 __________________________________________________________________ From: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Friday, September 16, 2016 1:03 PM Subject: [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [3]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [4]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://centralwines.com/ 2. http://facebook.com/CentralLiquors 3. mailto:DeTomaso@server.detomasolist.com 4. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 5 Date: Fri, 16 Sep 2016 10:13:05 -0700 From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov<mailto:terry.himes@jpl.nasa.gov>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <09791B61-DE0D-40CC-859D-437A8528952A@gmail.com<mailto:09791B61-DE0D-40CC-859D-437A8528952A@gmail.com>> Content-Type: text/plain; charset="utf-8" Terry - I don?t have the original radiator - I currently have a Fluidyne with twin suckers, tilted forward, and A/C condenser in front. Originally, I wanted to just add a shroud, based on a friend of mine who does some serious off-road driving - he swears by a shroud - says it really made a difference for him and that I should AT LEAST get one for the whole ?Pantera-Heat-Prevention Program. That sounds good - (PHPP). Anyway, the more I looked into things, the more I was ?converted" to brass/copper as it seems to be more reliable - and more repairable (which I like). jack On Sep 16, 2016, at 9:54 AM, Himes, Terry (397C) <terry.himes@jpl.nasa.gov<mailto:terry.himes@jpl.nasa.gov>> wrote: Jack, Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-) Terry "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> <mailto:thimes@jpl.nasa.gov> ?? From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> <mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com> <mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> <mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> <mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> <mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> <mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> <mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso <http://server.detomasolist.com/mailman/listinfo/detomaso> To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Terry - I don't have the original radiator - I currently have a Fluidyne with twin suckers, tilted forward, and A/C condenser in front. Originally, I wanted to just add a shroud, based on a friend of mine who does some serious off-road driving - he swears by a shroud - says it really made a difference for him and that I should AT LEAST get one for the whole "Pantera-Heat-Prevention Program. That sounds good - (PHPP). Anyway, the more I looked into things, the more I was "converted" to brass/copper as it seems to be more reliable - and more repairable (which I like). jack On Sep 16, 2016, at 9:54 AM, Himes, Terry (397C) <[1]terry.himes@jpl.nasa.gov<mailto:terry.himes@jpl.nasa.gov>> wrote: Jack, Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-) Terry "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [2]thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> From: DeTomaso <[3]detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <[4]demongusta@gmail.com<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[5]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <[6]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "[7]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <[8]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it's because I want to, not necessarily NEED to. It ain't broke, but I am fixing it(?). Didn't want to admit that, but...Lol. There really is an ulterior motive, but I just don't want to mention it right now; but I ran my idea past Brassworks - who says they will "build-to-suit" - but the Hall unit looks to be "tried-and-proven". Now - fans. I really don't know the brand name of my fans, but they are suckers - about 12" diameter - and the blades are "curved" - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone's post about the Flex-a-lite's since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [10]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:terry.himes@jpl.nasa.gov 2. mailto:thimes@jpl.nasa.gov 3. mailto:detomaso-bounces@server.detomasolist.com 4. mailto:demongusta@gmail.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 6 Date: Fri, 16 Sep 2016 10:17:31 -0700 From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: GR2835@comcast.net<mailto:GR2835@comcast.net> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <2334BABE-726C-4D16-85EA-BB997B2B61CB@gmail.com<mailto:2334BABE-726C-4D16-85EA-BB997B2B61CB@gmail.com>> Content-Type: text/plain; charset=utf-8 There-in lies one of my problems - I could never MAKE a shroud. I wish I could - maybe out of foil-wrap. I will check out that website, thanks. On Sep 16, 2016, at 10:07 AM, GR2835@comcast.net<mailto:GR2835@comcast.net> wrote: Pantera Electronics has recommended fans with part numbers under the fan controller button on their website. I have a stock radiator that was modified for lay down and air conditioning condenser up front........I have a fan shroud that I made and mounted the 2 sucker fans. 192 thermostat ran 192 in a 14 mile traffic jam last year that.took me 90 minutes to get through.......temperature was 98 degrees leaving the 2015 Woodward Cruise...........my wife complained that she was too cold with the air set on the warmest setting. Good luck Gerry in Illinois ----- Original Message ----- From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Cc: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Fri, 16 Sep 2016 16:29:46 -0000 (UTC) Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 7 Date: Fri, 16 Sep 2016 11:24:26 -0700 From: Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> To: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4018324.17A0EF%larrys@panteraparts.com<mailto:D4018324.17A0EF%larrys@panteraparts.com>> Content-Type: text/plain; charset="ISO-8859-1" Hi Jack, You should be able to use the fans off the Fluidyne, if not we have our Maridyne system fans and our own bracket kit and if you need shrouds for a full lie-down system, we have those too. Typically we recommend our half Lay forward system which minimizes the thru air turbulence. 11041B Defl. Rad. S.S. Lay down for kit $95.00 11042B Stainless deflector right $65.00 11043B Stainless deflector left $65.00 11055B Radiator Puller Fan Shroud SS Mounting brackets set of 3 $125.00 11055P PPC Puller Fans & Shroud Assy $325.00 If the Hall Brass radiator has the stock quick 90 degree hard radiator tubes installed, you will not be able to mount a puller fan shroud under those tubes, if it has the straight out tubes then you can use 90 degree molded rubber hoses to clear the Puller shroud like your Fluidyne. Larry Stock Pantera Parts Connection LC 550 Mallory Way Carson City NV 89701 www.PanteraParts.com<http://www.PanteraParts.com> PH 775-283-4411 Fax 775-283-4410 Cell 1-800-DeTomaso 800-338-6627 On 9/16/16, 9:29 AM, "DeTomaso on behalf of Jack Donahue" <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of demongusta@gmail.com<mailto:demongusta@gmail.com>> wrote: Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 8 Date: Fri, 16 Sep 2016 14:09:55 -0500 From: Cullen McCann <cmccann1972@gmail.com<mailto:cmccann1972@gmail.com>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] McLeod hydraulic throw out Message-ID: <CAFwr-MXfE-RBLar+qAHGPYYWnwSszwYufvAcAcUT2ngvZZ1Aqg@mail.gmail.com<mailto:CAFwr-MXfE-RBLar+qAHGPYYWnwSszwYufvAcAcUT2ngvZZ1Aqg@mail.gmail.com>> Content-Type: text/plain; charset="utf-8" Good afternoon! Has anyone installed the McLeod hydraulic throwout bearing that they say is Pantera specific for the ZF, and what was your experience? I've had a fantastic experience with them on another performance car application. https://www.summitracing.com/parts/mcl-1402-22 Thank you!! -------------- next part -------------- Good afternoon! Has anyone installed the McLeod hydraulic throwout bearing that they say is Pantera specific for the ZF, and what was your experience? I've had a fantastic experience with them on another performance car application. [1]https://www.summitracing.com/parts/mcl-1402-22 Thank you!! References 1. https://www.summitracing.com/parts/mcl-1402-22 ------------------------------ Message: 9 Date: Fri, 16 Sep 2016 19:27:46 +0000 (UTC) From: Ken Green <kenn_green@yahoo.com<mailto:kenn_green@yahoo.com>> To: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <1796334072.2409059.1474054066544@mail.yahoo.com<mailto:1796334072.2409059.1474054066544@mail.yahoo.com>> Content-Type: text/plain; charset="utf-8" Jack, ??? You should be able to find the fan and shroud here: https://www.flex-a-lite.com/electric-fans/12-volt-electric-fans/universal/pr... From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 9:29 AM Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about? radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum.? And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past? Brassworks? - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved?? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up? a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Jack, You should be able to find the fan and shroud here: [1]https://www.flex-a-lite.com/electric-fans/12-volt-electric-fans/univ ersal/primary-fans.html __________________________________________________________________ From: Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 9:29 AM Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit itas because I want to, not necessarily NEED to. It ainat broke, but I am fixing it(?). Didnat want to admit that, but...Lol. There really is an ulterior motive, but I just donat want to mention it right now; but I ran my idea past Brassworks - who says they will abuild-to-suita - but the Hall unit looks to be atried-and-provena. Now - fans. I really donat know the brand name of my fans, but they are suckers - about 12a diameter - and the blades are acurveda - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someoneas post about the Flex-a-liteas since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [2]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [3]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. https://www.flex-a-lite.com/electric-fans/12-volt-electric-fans/universal/pr... 2. mailto:DeTomaso@server.detomasolist.com 3. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 10 Date: Fri, 16 Sep 2016 12:35:17 -0700 From: Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>> To: Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] McLeod hydraulic throw out Message-ID: <6C366701-6502-47C0-A0DC-59494515D156@aol.com<mailto:6C366701-6502-47C0-A0DC-59494515D156@aol.com>> Content-Type: text/plain; charset=utf-8 Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a ? A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. ------------------------------ Message: 11 Date: Fri, 16 Sep 2016 12:50:41 -0700 From: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> To: LSJ <lashdeep@yahoo.com<mailto:lashdeep@yahoo.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Tires for Grp IV Flared Car Message-ID: <37e8f14d-dde9-3ce5-f312-4dd9b1c3f234@comcast.net<mailto:37e8f14d-dde9-3ce5-f312-4dd9b1c3f234@comcast.net>> Content-Type: text/plain; charset="utf-8"; Format="flowed" Going off memory (my car is still in Seattle) I am in San Diego area. They are 15" Aluminum Weld 5-spoke rims, that I believe are about 9.5" wide. On 9/16/2016 10:08 AM, LSJ wrote: What size wheel up front? LSJ /*central */ /*wines-spirits est 1934 */ /* */ /*625 e street nw */ /*washington, dc 20004*/ /* */ /*centralwines.com <http://centralwines.com/> */ /* */ /*facebook.com/CentralLiquors <http://facebook.com/CentralLiquors> */ /* */ /*202-737-2800*/ ------------------------------------------------------------------------ *From:* MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> *To:* detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> *Sent:* Friday, September 16, 2016 1:03 PM *Subject:* [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> <mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Going off memory (my car is still in Seattle) I am in San Diego area. They are 15" Aluminum Weld 5-spoke rims, that I believe are about 9.5" wide. On 9/16/2016 10:08 AM, LSJ wrote: What size wheel up front? LSJ central wines-spirits est 1934 625 e street nw washington, dc 20004 [1]centralwines.com [2]facebook.com/CentralLiquors 202-737-2800 __________________________________________________________________ From: MyCars [3]<mycars@comcast.net<mailto:mycars@comcast.net>> To: [4]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Friday, September 16, 2016 1:03 PM Subject: [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [5]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [6]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://centralwines.com/ 2. http://facebook.com/CentralLiquors 3. mailto:mycars@comcast.net 4. mailto:detomaso@server.detomasolist.com 5. mailto:DeTomaso@server.detomasolist.com 6. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 12 Date: Fri, 16 Sep 2016 13:00:36 -0700 From: MyCars <mycars@comcast.net<mailto:mycars@comcast.net>> To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Tires for Grp IV Flared Car Message-ID: <013ad905-7f93-99e8-761f-878f602ee6cb@comcast.net<mailto:013ad905-7f93-99e8-761f-878f602ee6cb@comcast.net>> Content-Type: text/plain; charset="windows-1252"; Format="flowed" I just checked Weld's website http://weldwheels.com/shop/street-strip/sport-forged-wheels/prostar.html They do not offer a 15" rim 9.5" wide, so I would guess they are 9" wide On 9/16/2016 12:50 PM, MyCars wrote: Going off memory (my car is still in Seattle) I am in San Diego area. They are 15" Aluminum Weld 5-spoke rims, that I believe are about 9.5" wide. On 9/16/2016 10:08 AM, LSJ wrote: What size wheel up front? LSJ central wines-spirits est 1934 625 e street nw washington, dc 20004 [1]centralwines.com [2]facebook.com/CentralLiquors 202-737-2800 __________________________________________________________________ From: MyCars [3]<mycars@comcast.net<mailto:mycars@comcast.net>> To: [4]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Friday, September 16, 2016 1:03 PM Subject: [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [5]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [6]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://centralwines.com/ 2. http://facebook.com/CentralLiquors 3. mailto:mycars@comcast.net 4. mailto:detomaso@server.detomasolist.com 5. mailto:DeTomaso@server.detomasolist.com 6. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- I just checked Weld's website [1]http://weldwheels.com/shop/street-strip/sport-forged-wheels/prostar. html They do not offer a 15" rim 9.5" wide, so I would guess they are 9" wide On 9/16/2016 12:50 PM, MyCars wrote: Going off memory (my car is still in Seattle) I am in San Diego area. They are 15" Aluminum Weld 5-spoke rims, that I believe are about 9.5" wide. On 9/16/2016 10:08 AM, LSJ wrote: What size wheel up front? LSJ central wines-spirits est 1934 625 e street nw washington, dc 20004 [1]centralwines.com [2]facebook.com/CentralLiquors 202-737-2800 __________________________________________________________________ From: MyCars [3][2]<mycars@comcast.net<mailto:mycars@comcast.net>> To: [[3]4]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Sent: Friday, September 16, 2016 1:03 PM Subject: [DeTomaso] Tires for Grp IV Flared Car I just bought 345-35 R15 Pirelli Asimmetrico (24.8" tall) tires for the rear and wondering what would be a good match for the front. I found 225-50 R15 Pirelli P Zero Trofeo R (23.9" tall). This would give the car a bit of rake, but what would the handling be like? Thanks in advance for your thoughts Roy _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[4]5]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [6][5]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. [6]http://centralwines.com/ 2. [7]http://facebook.com/CentralLiquors 3. [8]mailto:mycars@comcast.net 4. [9]mailto:detomaso@server.detomasolist.com 5. [10]mailto:DeTomaso@server.detomasolist.com 6. [11]http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [12]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [13]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. Members who post to this list grant license to the list to forward any message p osted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of lis t messages. References 1. http://weldwheels.com/shop/street-strip/sport-forged-wheels/prostar.html 2. mailto:mycars@comcast.net 3. mailto:4]detomaso@server.detomasolist.com 4. mailto:5]DeTomaso@server.detomasolist.com 5. http://server.detomasolist.com/mailman/listinfo/detomaso 6. http://centralwines.com/ 7. http://facebook.com/CentralLiquors 8. mailto:mycars@comcast.net 9. mailto:detomaso@server.detomasolist.com 10. mailto:DeTomaso@server.detomasolist.com 11. http://server.detomasolist.com/mailman/listinfo/detomaso 12. mailto:DeTomaso@server.detomasolist.com 13. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 13 Date: Fri, 16 Sep 2016 16:26:27 -0400 From: Will Kooiman <will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> To: Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>>, Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] McLeod hydraulic throw out Message-ID: <D401CD29.16A666%will.kooiman@gmail.com<mailto:D401CD29.16A666%will.kooiman@gmail.com>> Content-Type: text/plain; charset="ISO-8859-1" Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a ? A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 14 Date: Fri, 16 Sep 2016 15:50:41 -0500 From: Cullen McCann <cmccann1972@gmail.com<mailto:cmccann1972@gmail.com>> To: Will Kooiman <will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> Cc: Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>>, Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>> Subject: Re: [DeTomaso] McLeod hydraulic throw out Message-ID: <CAFwr-MXS50CCAQsJNmavjATb-j1RSZxcQrYF3EOYwY-xD=9Jpg@mail.gmail.com<mailto:CAFwr-MXS50CCAQsJNmavjATb-j1RSZxcQrYF3EOYwY-xD=9Jpg@mail.gmail.com>> Content-Type: text/plain; charset="utf-8" Thank you Larry. You answered my question perfectly. I am like Will, I have one on my Cobra as well, with a ford Top Loader and its been there for several years and Ive always loved it. I actually bought one that was "new" but several generations old, and when I called McLeod to inquire about fresh O-rings, they sent me a brand new unit just to "ensure a positive experience". I installed it with a performance clutch and a scattershield, bled it according to the instructions and that was about 4 years ago. Havent had a lick of trouble. (knocking on wood now). the frame rails on my cobra are 24" apart and I couldn't fit the clutch fork between the side of the bellhousing and the frame rail, and ive had a bad experience with performance clutches and cables breaking in the past...so I went the hydraulic route and have loved it. however... I will certainly consider carefully this drama as I set up my P car. I have a plan B with an external slave also, if I choose not to use the factory unit. Thank you sir. Cullen On Fri, Sep 16, 2016 at 3:26 PM, Will Kooiman <will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a ? A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Thank you Larry. You answered my question perfectly. I am like Will, I have one on my Cobra as well, with a ford Top Loader and its been there for several years and Ive always loved it. I actually bought one that was "new" but several generations old, and when I called McLeod to inquire about fresh O-rings, they sent me a brand new unit just to "ensure a positive experience". I installed it with a performance clutch and a scattershield, bled it according to the instructions and that was about 4 years ago. Havent had a lick of trouble.A (knocking on wood now). the frame rails on my cobra are 24" apart and I couldn't fit the clutch fork between the side of the bellhousing and the frame rail, and ive had a bad experience with performance clutches and cables breaking in the past...so I went the hydraulic route and have loved it. however... I will certainly consider carefully this drama as I set up my P car. I have a plan B with an external slave also, if I choose not to use the factory unit.A Thank you sir. Cullen On Fri, Sep 16, 2016 at 3:26 PM, Will Kooiman <[1]will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium.A Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <[2]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: >Cullen, > >2511 came equipped with one of those from Dennis when I purchased it in >2002. Since then I have rebuilt the unit twice (three?) and most recently >did so using what I believe to be their current offering. I spoke with >and ordered directly from McLeod. > >My opinion, in brief, is a very simple "NO!!" > >The current offering was shipped to me with an incorrect input snout >spacer (I solved that by using the old spacer which luckily I still had >on hand), and the stainless steel input line, due to its 90ADEG fitting >where one should have used a 45ADEG fitting, twisted itself, unseen of >course, within the bell housing when it was connected to the hard line >attached to the chassis rails. Even stainless steel lines don't hold up >very long against grinding by a pressure plate. > >The stainless steel bleed line is about 4 inches too long, sticking >outside the bell housing in a terrible display of ugly. > >Finally, my last experience started with me ordering the same rebuild kit >I had previously used, using the same number off of the previous invoice. >What I received from them was the rebuild kit for the current unit which >uses an entirely different set of all rings. I ultimately determined that >for all three generations of their hydraulic bearing McLeod has used >exactly the same rebuild kit part number. They added no suffix such as a >A A or a AB which to me seems indicative of a problem within the company. >No, they no longer support a rebuild kit for the first two generations. > >While you have some experience in using one of these previously, the task >of establishing proper free play and clearances is quite exacting and >unforgiving. If you get it wrong there is nothing left to do but pull the >transaxle and start all over again. > >The unit I have is now adjusted for the factory shortcomings and as has >been my experience for over 50,000 miles, the system works just fine. >Dennis however no longer recommends their installation and based on my >experience I would not encourage any other owners to venture down that >road for themselves. > >Feel free to reach out to me off-line or by phone for more of the gory >details. > >Larry > >Sent from me using a magic, handheld electronic gizmo. >_______________________________________________ > > >Detomaso Email List is not managed by POCA >Posted emails must not exceed 1.5 Megabytes >DeTomaso mailing list >[3]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> >[4]http://server.detomasolist.com/mailman/listinfo/detomaso > >To manage your subscription (change email address, unsubscribe, etc.) use >the links above. > >Members who post to this list grant license to the list to forward any >message posted here to all past, current, or future members of the list. >They also grant the list owner permission to maintain an archive or >approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [5]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [6]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:will.kooiman@gmail.com 2. mailto:detomaso@server.detomasolist.com 3. mailto:DeTomaso@server.detomasolist.com 4. http://server.detomasolist.com/mailman/listinfo/detomaso 5. mailto:DeTomaso@server.detomasolist.com 6. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 15 Date: Fri, 16 Sep 2016 13:53:15 -0700 From: Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> To: Will Kooiman <will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>>, Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>>, Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] McLeod hydraulic throw out Message-ID: <D401A883.17A144%larrys@panteraparts.com<mailto:D401A883.17A144%larrys@panteraparts.com>> Content-Type: text/plain; charset="EUC-KR" The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a ? A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 16 Date: Fri, 16 Sep 2016 14:11:22 -0700 From: Mike Drew <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>> To: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>> Cc: "<detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises Message-ID: <C4C5C3CB-D201-4825-A845-85208C7B8B62@aol.com<mailto:C4C5C3CB-D201-4825-A845-85208C7B8B62@aol.com>> Content-Type: text/plain; charset="us-ascii" All, Here is a photo of the IPSCO water pump idler pulley setup. Note there is no alternator in view, as this car is fitted with a flat firewall kit that moves the alternator outboard of the A/C system. -------------- next part -------------- A non-text attachment was scrubbed... Name: image.jpeg Type: image/jpeg Size: 594482 bytes Desc: not available URL: <http://server.detomasolist.com/pipermail/detomaso/attachments/20160916/33a69e52/attachment-0001.jpeg> -------------- next part -------------- Mike Sent from my iPhone On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: Rob, If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It eliminates the "fitted", non-adjustable belt and makes it adjustable. It sure makes installation a lot easier. It's not listed on IPSCO's web site so you have to call or e-mail to get details. Also, IPSCO has an idler pulley kit that makes installation and belt tensioning a breeze. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm References 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 17 Date: Fri, 16 Sep 2016 21:16:34 +0000 From: Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> To: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>, Mike Drew <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises Message-ID: <CY4PR18MB12865ADBFE3EEDECFFB644A895F30@CY4PR18MB1286.namprd18.prod.outlook.com<mailto:CY4PR18MB12865ADBFE3EEDECFFB644A895F30@CY4PR18MB1286.namprd18.prod.outlook.com>> Content-Type: text/plain; charset="iso-8859-1" Mike, It gets even better, that looks to be a different idler again, the one that was previously linked appears to go in the stock location, but was adjustable from the front negating the usual need to get a wrench on the rear. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 2:11 PM To: David Nunn Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises All, Here is a photo of the IPSCO water pump idler pulley setup. Note there is no alternator in view, as this car is fitted with a flat firewall kit that moves the alternator outboard of the A/C system. [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] Mike Sent from my iPhone On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: Rob, If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It eliminates the "fitted", non-adjustable belt and makes it adjustable. It sure makes installation a lot easier. It's not listed on IPSCO's web site so you have to call or e-mail to get details. Also, IPSCO has an idler pulley kit that makes installation and belt tensioning a breeze. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm References 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm [http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.jpg]<http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm> Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ...<http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm> www.ipsco.org<http://www.ipsco.org> Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, this assembly allow adjustment without trying to hold a wrench behind the bracket to tighten in ... _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Mike, It gets even better, that looks to be a different idler again, the one that was previously linked appears to go in the stock location, but was adjustable from the front negating the usual need to get a wrench on the rear. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 2:11 PM To: David Nunn Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises All, Here is a photo of the IPSCO water pump idler pulley setup. Note there is no alternator in view, as this car is fitted with a flat firewall kit that moves the alternator outboard of the A/C system. [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] Mike Sent from my iPhone On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: > Rob, > > If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It > eliminates the "fitted", non-adjustable belt and makes it adjustable. > It sure makes installation a lot easier. It's not listed on IPSCO's web > site so you have to call or e-mail to get details. > > Also, IPSCO has an idler pulley kit that makes installation and belt > tensioning a breeze. > > [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm > > References > > 1. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm [2][Idler%20Pulley.jpg] [3]Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ... www.ipsco.org<http://www.ipsco.org> Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, this assembly allow adjustment without trying to hold a wrench behind the bracket to tighten in ... > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> > [4]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [5]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 2. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 3. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 4. http://server.detomasolist.com/mailman/listinfo/detomaso 5. http://server.detomasolist.com/mailman/listinfo/detomaso -------------- next part -------------- A non-text attachment was scrubbed... Name: image.jpeg Type: image/jpeg Size: 594482 bytes Desc: image.jpeg URL: <http://server.detomasolist.com/pipermail/detomaso/attachments/20160916/ed6ee2dd/attachment-0001.jpeg> ------------------------------ Message: 18 Date: Fri, 16 Sep 2016 14:18:39 -0700 From: Mike Drew <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>> To: Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises Message-ID: <7B7EDC5D-6016-45F7-B580-31A839921366@aol.com<mailto:7B7EDC5D-6016-45F7-B580-31A839921366@aol.com>> Content-Type: text/plain; charset=us-ascii Julian, Yes, he mentioned two different products for different applications but only had a link for the stock replacement idler. My photo shows the idler that replaces the alternator to tension the water pump belt. Mike Sent from my iPhone On Sep 16, 2016, at 14:16, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> wrote: Mike, It gets even better, that looks to be a different idler again, the one that was previously linked appears to go in the stock location, but was adjustable from the front negating the usual need to get a wrench on the rear. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 2:11 PM To: David Nunn Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises All, Here is a photo of the IPSCO water pump idler pulley setup. Note there is no alternator in view, as this car is fitted with a flat firewall kit that moves the alternator outboard of the A/C system. [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] Mike Sent from my iPhone On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: Rob, If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It eliminates the "fitted", non-adjustable belt and makes it adjustable. It sure makes installation a lot easier. It's not listed on IPSCO's web site so you have to call or e-mail to get details. Also, IPSCO has an idler pulley kit that makes installation and belt tensioning a breeze. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm References 1. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm [2][Idler%20Pulley.jpg] [3]Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ... www.ipsco.org<http://www.ipsco.org> Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, this assembly allow adjustment without trying to hold a wrench behind the bracket to tighten in ... _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [4]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [5]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 2. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 3. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 4. http://server.detomasolist.com/mailman/listinfo/detomaso 5. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 19 Date: Fri, 16 Sep 2016 14:19:14 -0700 From: Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>> To: Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] McLeod hydraulic throw out Message-ID: <78A89D59-A850-402B-8862-ABC7DFF75CD9@aol.com<mailto:78A89D59-A850-402B-8862-ABC7DFF75CD9@aol.com>> Content-Type: text/plain; charset=utf-8 Heat? As I previously wrote, I have over 50,000 miles using one of the McLeod systems. Those 50,000 miles have all been WITH a black plastic plug in the hole that some wish to call a ventilation hole rather than an inspection hole. Your choice, I don't really care. Whatever heat issues may or may not be present, with or without a plug, have never appeared to be an issue in any way, shape or form in my many years of experience. I am all ears if Larry or anyone else has history that supports a failure of the McLeod unit from excessive heat. Larry Sent from me using a magic, handheld electronic gizmo. On Sep 16, 2016, at 1:53 PM, Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> wrote: The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 20 Date: Fri, 16 Sep 2016 16:38:06 -0500 From: Cullen McCann <cmccann1972@gmail.com<mailto:cmccann1972@gmail.com>> To: Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> Cc: Email List Address For Posting <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>>, Larry Finch <fresnofinches@aol.com<mailto:fresnofinches@aol.com>> Subject: Re: [DeTomaso] McLeod hydraulic throw out Message-ID: <CAFwr-MWHHeaX0ok7ajqCPFCdY9WbHzjGrnmoMoMYuHjYFCj-cA@mail.gmail.com<mailto:CAFwr-MWHHeaX0ok7ajqCPFCdY9WbHzjGrnmoMoMYuHjYFCj-cA@mail.gmail.com>> Content-Type: text/plain; charset="utf-8" well, I have the quicktime bellhousing for the ZF on 4653. I forgot to mention that. Also didn't consider it would be relevant. hmmmm. On Fri, Sep 16, 2016 at 3:53 PM, Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> wrote: The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: Wow. I have one in my Cobra, and so far it has worked perfectly. My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave. At any rate, as I said, it has worked perfectly - so far. -- Will On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: Cullen, 2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod. My opinion, in brief, is a very simple "NO!!" The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90? fitting where one should have used a 45? fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate. The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly. Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a ? A or a ?B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations. While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again. The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves. Feel free to reach out to me off-line or by phone for more of the gory details. Larry Sent from me using a magic, handheld electronic gizmo. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- well, I have the quicktime bellhousing for the ZF on 4653. I forgot to mention that. Also didn't consider it would be relevant. hmmmm. On Fri, Sep 16, 2016 at 3:53 PM, Larry Stock <[1]larrys@panteraparts.com<mailto:larrys@panteraparts.com>> wrote: The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <[2]detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of [3]will.kooiman@gmail.com<mailto:will.kooiman@gmail.com>> wrote: >Wow. > >I have one in my Cobra, and so far it has worked perfectly. > >My Cobra came with an external slave from a Volvo that was readily >available 20 years ago, but is now unobtanium.A Rather than building a new >bracket for a different slave, I switched to a McLeod slave. > >At any rate, as I said, it has worked perfectly - so far. > >-- >Will > > > > > >On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" ><[4]detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> wrote: > >>Cullen, >> >>2511 came equipped with one of those from Dennis when I purchased it in >>2002. Since then I have rebuilt the unit twice (three?) and most recently >>did so using what I believe to be their current offering. I spoke with >>and ordered directly from McLeod. >> >>My opinion, in brief, is a very simple "NO!!" >> >>The current offering was shipped to me with an incorrect input snout >>spacer (I solved that by using the old spacer which luckily I still had >>on hand), and the stainless steel input line, due to its 90ADEG fitting >>where one should have used a 45ADEG fitting, twisted itself, unseen of >>course, within the bell housing when it was connected to the hard line >>attached to the chassis rails. Even stainless steel lines don't hold up >>very long against grinding by a pressure plate. >> >>The stainless steel bleed line is about 4 inches too long, sticking >>outside the bell housing in a terrible display of ugly. >> >>Finally, my last experience started with me ordering the same rebuild kit >>I had previously used, using the same number off of the previous invoice. >>What I received from them was the rebuild kit for the current unit which >>uses an entirely different set of all rings. I ultimately determined that >>for all three generations of their hydraulic bearing McLeod has used >>exactly the same rebuild kit part number. They added no suffix such as a >>A A or a AB which to me seems indicative of a problem within the company. >>No, they no longer support a rebuild kit for the first two generations. >> >>While you have some experience in using one of these previously, the task >>of establishing proper free play and clearances is quite exacting and >>unforgiving. If you get it wrong there is nothing left to do but pull the >>transaxle and start all over again. >> >>The unit I have is now adjusted for the factory shortcomings and as has >>been my experience for over 50,000 miles, the system works just fine. >>Dennis however no longer recommends their installation and based on my >>experience I would not encourage any other owners to venture down that >>road for themselves. >> >>Feel free to reach out to me off-line or by phone for more of the gory >>details. >> >>Larry >> >>Sent from me using a magic, handheld electronic gizmo. >>_______________________________________________ >> >> >>Detomaso Email List is not managed by POCA >>Posted emails must not exceed 1.5 Megabytes >>DeTomaso mailing list >>[5]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> >>[6]http://server.detomasolist.com/mailman/listinfo/detomaso >> >>To manage your subscription (change email address, unsubscribe, etc.) use >>the links above. >> >>Members who post to this list grant license to the list to forward any >>message posted here to all past, current, or future members of the list. >>They also grant the list owner permission to maintain an archive or >>approve the archiving of list messages. > > >_______________________________________________ > > >Detomaso Email List is not managed by POCA >Posted emails must not exceed 1.5 Megabytes >DeTomaso mailing list >[7]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> >[8]http://server.detomasolist.com/mailman/listinfo/detomaso > >To manage your subscription (change email address, unsubscribe, etc.) use >the links above. > >Members who post to this list grant license to the list to forward any >message posted here to all past, current, or future members of the list. >They also grant the list owner permission to maintain an archive or >approve the archiving of list messages. > _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [10]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:larrys@panteraparts.com 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:will.kooiman@gmail.com 4. mailto:detomaso@server.detomasolist.com 5. mailto:DeTomaso@server.detomasolist.com 6. http://server.detomasolist.com/mailman/listinfo/detomaso 7. mailto:DeTomaso@server.detomasolist.com 8. http://server.detomasolist.com/mailman/listinfo/detomaso 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso ------------------------------ Message: 21 Date: Fri, 16 Sep 2016 21:46:51 +0000 From: michael frazier <red3644@hotmail.com<mailto:red3644@hotmail.com>> To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] NPC, Need transmission suggestions Message-ID: <SN1PR07MB2254F82A006D414EA80223FCB9F30@SN1PR07MB2254.namprd07.prod.outlook.com<mailto:SN1PR07MB2254F82A006D414EA80223FCB9F30@SN1PR07MB2254.namprd07.prod.outlook.com>> Content-Type: text/plain; charset="utf-8" Hi All, I?m putting a 1951 Ford truck back on the road. It sat in a barn since 1961 and only has 25k miles, but those were farm miles and it is beat though not rusted out. Beautiful Rat Rod patina that will remain. The frame is boxed and cross braced, and holds a complete Jaguar XJ suspension front and back. I plan to run a spare Cleveland, actually a real Boss 351, and want an overdrive transmission. Manual or automatic, either one. It won?t be drag raced but will be used regularly and would likely be run in an open road race some time. That?s the reason for the overdrive. I?ve been out of this part of the game for a while and was wondering what would work well. What would bolt up and work. What would it come out of? Any info and ideas would be greatly appreciated. Michael Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10 -------------- next part -------------- Hi All, I'm putting a 1951 Ford truck back on the road. It sat in a barn since 1961 and only has 25k miles, but those were farm miles and it is beat though not rusted out. Beautiful Rat Rod patina that will remain. The frame is boxed and cross braced, and holds a complete Jaguar XJ suspension front and back. I plan to run a spare Cleveland, actually a real Boss 351, and want an overdrive transmission. Manual or automatic, either one. It won't be drag raced but will be used regularly and would likely be run in an open road race some time. That's the reason for the overdrive. I've been out of this part of the game for a while and was wondering what would work well. What would bolt up and work. What would it come out of? Any info and ideas would be greatly appreciated. Michael Sent from [1]Mail for Windows 10 References 1. https://go.microsoft.com/fwlink/?LinkId=550986 ------------------------------ Message: 22 Date: Fri, 16 Sep 2016 15:04:46 -0700 From: "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> To: "'Mike Drew'" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, "'Julian Kift'" <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Message-ID: <003301d21066$5739cc80$05ad6580$@telus.net<mailto:003301d21066$5739cc80$05ad6580$@telus.net>> Content-Type: text/plain; charset="us-ascii" Julian, Further to what Mike wrote; here's a photo of the front of my engine, with both IPSCO items installed. David -----Original Message----- From: Mike Drew [mailto:MikeLDrew@aol.com] Sent: September 16, 2016 2:19 PM To: Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Julian, Yes, he mentioned two different products for different applications but only had a link for the stock replacement idler. My photo shows the idler that replaces the alternator to tension the water pump belt. Mike Sent from my iPhone On Sep 16, 2016, at 14:16, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> wrote: Mike, It gets even better, that looks to be a different idler again, the one that was previously linked appears to go in the stock location, but was adjustable from the front negating the usual need to get a wrench on the rear. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Friday, September 16, 2016 2:11 PM To: David Nunn Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Sanden Compressors noises All, Here is a photo of the IPSCO water pump idler pulley setup. Note there is no alternator in view, as this car is fitted with a flat firewall kit that moves the alternator outboard of the A/C system. [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] Mike Sent from my iPhone On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: Rob, If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It eliminates the "fitted", non-adjustable belt and makes it adjustable. It sure makes installation a lot easier. It's not listed on IPSCO's web site so you have to call or e-mail to get details. Also, IPSCO has an idler pulley kit that makes installation and belt tensioning a breeze. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm References 1. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm [2][Idler%20Pulley.jpg] [3]Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ... www.ipsco.org<http://www.ipsco.org> Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, this assembly allow adjustment without trying to hold a wrench behind the bracket to tighten in ... _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [4]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [5]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 2. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 3. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm 4. http://server.detomasolist.com/mailman/listinfo/detomaso 5. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- A non-text attachment was scrubbed... Name: AC bracket & pulleys_opt.jpg Type: image/jpeg Size: 219525 bytes Desc: not available URL: <http://server.detomasolist.com/pipermail/detomaso/attachments/20160916/e7e2256b/attachment-0001.jpg> ------------------------------ Message: 23 Date: Fri, 16 Sep 2016 16:26:53 -0600 From: bill <bill@incendium.com<mailto:bill@incendium.com>> To: michael frazier <red3644@hotmail.com<mailto:red3644@hotmail.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] NPC, Need transmission suggestions Message-ID: <asutxkibtwmp20w9x9fxrayp.1474064813467@email.android.com<mailto:asutxkibtwmp20w9x9fxrayp.1474064813467@email.android.com>> Content-Type: text/plain; charset="utf-8" Michael:Screw that put a Ford flat head V8 in that suckered.? CheersBill MooreCalgary -------- Original message --------From: michael frazier <red3644@hotmail.com<mailto:red3644@hotmail.com>> Date: 2016-09-16 3:46 PM (GMT-07:00) To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] NPC, Need transmission suggestions Hi All, I?m putting a 1951 Ford truck back on the road.? It sat in a barn since 1961 and only has 25k miles, but those were farm miles and it is beat though not rusted out.? Beautiful Rat Rod patina that will remain.? The frame is boxed and cross braced, and holds a complete Jaguar XJ suspension front and back. I plan to run a spare Cleveland, actually a real Boss 351, and want an overdrive transmission.? Manual or automatic, either one.? It won?t be drag raced but will be used regularly and would likely be run in an open road race some time.? That?s the reason for the overdrive. I?ve been out of this part of the game for a while and was wondering what would work well. What would bolt up and work.? What would it come out of? Any info and ideas would be greatly appreciated. Michael Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10 ?? Hi All, ?? I'm putting a 1951 Ford truck back on the road.? It sat in a barn since ?? 1961 and only has 25k miles, ?? but those were farm miles and it is beat though not rusted out. ?? Beautiful Rat Rod patina that will ?? remain.? The frame is boxed and cross braced, and holds a complete ?? Jaguar XJ suspension front and back. ?? I plan to run a spare Cleveland, actually a real Boss 351, and want an ?? overdrive transmission.? Manual or ?? automatic, either one.? It won't be drag raced but will be used ?? regularly and would likely be run in an ?? open road race some time.? That's the reason for the overdrive. ?? I've been out of this part of the game for a while and was wondering ?? what would work well. ?? What would bolt up and work.? What would it come out of? ?? Any info and ideas would be greatly appreciated. ?? Michael ?? Sent from [1]Mail for Windows 10 References ?? 1. https://go.microsoft.com/fwlink/?LinkId=550986 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Michael: Screw that put a Ford flat head V8 in that suckered. Cheers Bill Moore Calgary -------- Original message -------- From: michael frazier <red3644@hotmail.com<mailto:red3644@hotmail.com>> Date: 2016-09-16 3:46 PM (GMT-07:00) To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] NPC, Need transmission suggestions Hi All, I'm putting a 1951 Ford truck back on the road. It sat in a barn since 1961 and only has 25k miles, but those were farm miles and it is beat though not rusted out. Beautiful Rat Rod patina that will remain. The frame is boxed and cross braced, and holds a complete Jaguar XJ suspension front and back. I plan to run a spare Cleveland, actually a real Boss 351, and want an overdrive transmission. Manual or automatic, either one. It won't be drag raced but will be used regularly and would likely be run in an open road race some time. That's the reason for the overdrive. I've been out of this part of the game for a while and was wondering what would work well. What would bolt up and work. What would it come out of? Any info and ideas would be greatly appreciated. Michael Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10 Hi All, I'm putting a 1951 Ford truck back on the road. It sat in a barn since 1961 and only has 25k miles, but those were farm miles and it is beat though not rusted out. Beautiful Rat Rod patina that will remain. The frame is boxed and cross braced, and holds a complete Jaguar XJ suspension front and back. I plan to run a spare Cleveland, actually a real Boss 351, and want an overdrive transmission. Manual or automatic, either one. It won't be drag raced but will be used regularly and would likely be run in an open road race some time. That's the reason for the overdrive. I've been out of this part of the game for a while and was wondering what would work well. What would bolt up and work. What would it come out of? Any info and ideas would be greatly appreciated. Michael Sent from [1]Mail for Windows 10 References 1. https://go.microsoft.com/fwlink/?LinkId=550986 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Message: 24 Date: Fri, 16 Sep 2016 16:31:46 -0600 From: bill <bill@incendium.com<mailto:bill@incendium.com>> To: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>, 'Mike Drew' <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Message-ID: <twbfe1jjjap5dl76l23cu2gv.1474065106843@email.android.com<mailto:twbfe1jjjap5dl76l23cu2gv.1474065106843@email.android.com>> Content-Type: text/plain; charset="utf-8" Wow !,,,, That looks to nice to cover up..... CheersBill MooreCalgary -------- Original message --------From: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>> Date: 2016-09-16 4:04 PM (GMT-07:00) To: 'Mike Drew' <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Julian, Further to what Mike wrote; here's a photo of the front of my engine, with both IPSCO items installed. David -----Original Message----- From: Mike Drew [mailto:MikeLDrew@aol.com] Sent: September 16, 2016 2:19 PM To: Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Julian, Yes, he mentioned two different products for different applications but only had a link for the stock replacement idler. My photo shows the idler that replaces the alternator to tension the water pump belt. Mike Sent from my iPhone On Sep 16, 2016, at 14:16, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> wrote: ?? Mike, ?? It gets even better, that looks to be a different idler again, the one ?? that was previously linked appears to go in the stock location, but was ?? adjustable from the front negating the usual need to get a wrench on ?? the rear. ?? Julian ???? __________________________________________________________________ ?? From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of ?? Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> ?? Sent: Friday, September 16, 2016 2:11 PM ?? To: David Nunn ?? Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> ?? Subject: Re: [DeTomaso] Sanden Compressors noises ?? All, ?? Here is a photo of the IPSCO water pump idler pulley setup. Note there ?? is no alternator in view, as this car is fitted with a flat firewall ?? kit that moves the alternator outboard of the A/C system. ?? [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] ?? Mike ?? Sent from my iPhone ?? On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: ? Rob, ? If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It? eliminates the "fitted", non-adjustable belt and makes it ?? adjustable. ? It sure makes installation a lot easier. It's not listed on IPSCO's ?? web ? site so you have to call or e-mail to get details. ? Also, IPSCO has an idler pulley kit that makes installation and ?? belt ? tensioning a breeze. ? [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm References ? 1. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm ?? [2][Idler%20Pulley.jpg] ?? [3]Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ... ?? www.ipsco.org<http://www.ipsco.org> ?? Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, ?? this assembly allow adjustment without trying to hold a wrench behind ?? the bracket to tighten in ... _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> [4]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) ?? use the links above. Members who post to this list grant license to the list to forward ?? any message posted here to all past, current, or future members of the ?? list. They also grant the list owner permission to maintain an archive ?? or approve the archiving of list messages. ?? _______________________________________________ ?? Detomaso Email List is not managed by POCA ?? Posted emails must not exceed 1.5 Megabytes ?? DeTomaso mailing list ?? DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> ?? [5]http://server.detomasolist.com/mailman/listinfo/detomaso ?? To manage your subscription (change email address, unsubscribe, etc.) ?? use the links above. ?? Members who post to this list grant license to the list to forward any ?? message posted here to all past, current, or future members of the ?? list. They also grant the list owner permission to maintain an archive ?? or approve the archiving of list messages. References ?? 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm ?? 2. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm ?? 3. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm ?? 4. http://server.detomasolist.com/mailman/listinfo/detomaso ?? 5. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. -------------- next part -------------- Wow !,,,, That looks to nice to cover up..... Cheers Bill Moore Calgary -------- Original message -------- From: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>> Date: 2016-09-16 4:04 PM (GMT-07:00) To: 'Mike Drew' <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Julian, Further to what Mike wrote; here's a photo of the front of my engine, with both IPSCO items installed. David -----Original Message----- From: Mike Drew [mailto:MikeLDrew@aol.com] Sent: September 16, 2016 2:19 PM To: Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Cc: David Nunn <dnunn@telus.net<mailto:dnunn@telus.net>>; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Sanden Compressors noises Julian, Yes, he mentioned two different products for different applications but only had a link for the stock replacement idler. My photo shows the idler that replaces the alternator to tension the water pump belt. Mike Sent from my iPhone On Sep 16, 2016, at 14:16, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> wrote: > Mike, > > It gets even better, that looks to be a different idler again, the one > that was previously linked appears to go in the stock location, but was > adjustable from the front negating the usual need to get a wrench on > the rear. > Julian > __________________________________________________________________ > > From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of > Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> > Sent: Friday, September 16, 2016 2:11 PM > To: David Nunn > Cc: <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> > Subject: Re: [DeTomaso] Sanden Compressors noises > > All, > Here is a photo of the IPSCO water pump idler pulley setup. Note there > is no alternator in view, as this car is fitted with a flat firewall > kit that moves the alternator outboard of the A/C system. > [cid:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com<mailto:da0fdac9-8741-4e03-b676-ebaa4760fb6f@namprd18.prod.outlook.com>] > Mike > Sent from my iPhone > On Sep 15, 2016, at 15:41, "David Nunn" <dnunn@telus.net<mailto:dnunn@telus.net>> wrote: >> Rob, >> >> If I'm not mistaken, IPSCO sells a kit that modifies Kirk's kit. It >> eliminates the "fitted", non-adjustable belt and makes it > adjustable. >> It sure makes installation a lot easier. It's not listed on IPSCO's > web >> site so you have to call or e-mail to get details. >> >> Also, IPSCO has an idler pulley kit that makes installation and > belt >> tensioning a breeze. >> >> [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm >> >> References >> >> 1. [1]http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm > [2][Idler%20Pulley.jpg] > [3]Idler Pulley - IPSCO, Pantera, Viper, Mechanical Parking ... > www.ipsco.org<http://www.ipsco.org> > Pantera Idler Pulley Assembly . Replacement for factory Idler Pulley, > this assembly allow adjustment without trying to hold a wrench behind > the bracket to tighten in ... >> _______________________________________________ >> >> >> Detomaso Email List is not managed by POCA Posted emails must not >> exceed 1.5 Megabytes DeTomaso mailing list >> DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> >> [4]http://server.detomasolist.com/mailman/listinfo/detomaso >> >> To manage your subscription (change email address, unsubscribe, etc.) > use the links above. >> >> Members who post to this list grant license to the list to forward > any message posted here to all past, current, or future members of the > list. They also grant the list owner permission to maintain an archive > or approve the archiving of list messages. > _______________________________________________ > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> > [5]http://server.detomasolist.com/mailman/listinfo/detomaso > To manage your subscription (change email address, unsubscribe, etc.) > use the links above. > Members who post to this list grant license to the list to forward any > message posted here to all past, current, or future members of the > list. They also grant the list owner permission to maintain an archive > or approve the archiving of list messages. > > References > > 1. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm > 2. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm > 3. http://www.ipsco.org/Pantera%20Parts/Idler%20Pulley.htm > 4. http://server.detomasolist.com/mailman/listinfo/detomaso > 5. http://server.detomasolist.com/mailman/listinfo/detomaso > _______________________________________________ > > > Detomaso Email List is not managed by POCA Posted emails must not > exceed 1.5 Megabytes DeTomaso mailing list > DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> > http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ Subject: Digest Footer _______________________________________________ Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. ------------------------------ End of DeTomaso Digest, Vol 147, Issue 19 ***************************************** _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. Well said! "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Julian Kift <[3]julian_kift@hotmail.com> Date: Saturday, September 17, 2016 7:56 AM To: Owen Cooke <[4]owen@tadhgcooke.com>, "[5]detomaso@server.detomasolist.com" <[6]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian ________________________________ From: DeTomaso <[7]detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <[8]owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: [9]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [10]detomaso-request@server.detomasolist.com wrote: Send DeTomaso mailing list submissions to [11]detomaso@server.detomasolist.com To subscribe or unsubscribe via the World Wide Web, visit [12]http://server.detomasolist.com/mailman/listinfo/detomaso DeTomaso Info Page<[13]http://server.detomasolist.com/mailman/listinfo/detomaso> server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to [14]detomaso-request@server.detomasolist.com You can reach the person managing the list at [15]detomaso-owner@server.detomasolist.com When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..." Daily Detomaso List Digest Today's Topics: 1. Fans and shroud (Jack Donahue) 2. Re: Fans and shroud (Himes, Terry (397C)) 3. Tires for Grp IV Flared Car (MyCars) 4. Re: Tires for Grp IV Flared Car (LSJ) 5. Re: Fans and shroud (Jack Donahue) 6. Re: Fans and shroud (Jack Donahue) 7. Re: Fans and shroud (Larry Stock) 8. McLeod hydraulic throw out (Cullen McCann) 9. Re: Fans and shroud (Ken Green) 10. McLeod hydraulic throw out (Larry Finch) 11. Re: Tires for Grp IV Flared Car (MyCars) 12. Re: Tires for Grp IV Flared Car (MyCars) 13. Re: McLeod hydraulic throw out (Will Kooiman) 14. Re: McLeod hydraulic throw out (Cullen McCann) 15. Re: McLeod hydraulic throw out (Larry Stock) 16. Re: Sanden Compressors noises (Mike Drew) 17. Re: Sanden Compressors noises (Julian Kift) 18. Re: Sanden Compressors noises (Mike Drew) 19. Re: McLeod hydraulic throw out (Larry Finch) 20. Re: McLeod hydraulic throw out (Cullen McCann) 21. NPC, Need transmission suggestions (michael frazier) 22. Re: Sanden Compressors noises (David Nunn) 23. Re: NPC, Need transmission suggestions (bill) 24. Re: Sanden Compressors noises (bill) ---------------------------------------------------------------------- Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <[16]demongusta@gmail.com> To: "[17]detomaso@server.detomasolist.com" <[18]detomaso@server.detomasolist.com> Cc: "[19]detomaso@server.detomasolist.com" <[20]detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: <[21]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8 Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 ------------------------------ Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <[22]terry.himes@jpl.nasa.gov> To: Jack Donahue <[23]demongusta@gmail.com>, "[24]detomaso@server.detomasolist.com" <[25]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <[26]D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8" Jack, Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-) Terry "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [27]thimes@jpl.nasa.gov<[28]mailto:thimes@jpl.nasa.gov> ?? From: DeTomaso <[29]detomaso-bounces@server.detomasolist.com<[30]mailto:detomaso-bounc es@server.detomasolist.com>> on behalf of Jack Donahue <[31]demongusta@gmail.com<[32]mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[33]detomaso@server.detomasolist.com<[34]mailto:detomaso@server.detoma solist.com>" <[35]detomaso@server.detomasolist.com<[36]mailto:detomaso@server.detoma solist.com>> Cc: "[37]detomaso@server.detomasolist.com<[38]mailto:detomaso@server.detoma solist.com>" <[39]detomaso@server.detomasolist.com<[40]mailto:detomaso@server.detoma solist.com>> Subject: [DeTomaso] Fans and shroud Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348 _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [41]DeTomaso@server.detomasolist.com<[42]mailto:DeTomaso@server.detomas olist.com> [43]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
When I bought my first Pantera in 2000 I had a heating problem at the track. When It would puke about 1/2 gal of coolant it would overheat and was hell to try and keep cool. It would sometimes suck the full puke tank back in as it cooled and work for a few laps then overheat again. I would refill the unit belch it at the radiator and it would work again for a while. After a couple of disappointing track days, I was under the car and followed the radiator lines forward. The engine return was routed from the top of the radiator. I found that when the car was rebuilt some years before they had replaced the radiator with a "Chevy" style radiator which had the lines reversed. My engine return was from the top of the radiator and the engine hot was going to the bottom of the radiator. Rearranged different radiator hook up hoses and it has been fine since. Sometimes the obvious isn't jerry knotts On 9/17/2016 9:56 AM, Julian Kift wrote:
From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19
guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com wrote: > Send DeTomaso mailing list submissions to > detomaso@server.detomasolist.com > > To subscribe or unsubscribe via the World Wide Web, visit > [1]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... > or, via email, send a message with subject or body 'help' to > detomaso-request@server.detomasolist.com > > You can reach the person managing the list at > detomaso-owner@server.detomasolist.com > > When replying, please edit your Subject line so it is more specific > than "Re: Contents of DeTomaso digest..." > > > Daily Detomaso List Digest > > Today's Topics: > > 1. Fans and shroud (Jack Donahue) > 2. Re: Fans and shroud (Himes, Terry (397C)) > 3. Tires for Grp IV Flared Car (MyCars) > 4. Re: Tires for Grp IV Flared Car (LSJ) > 5. Re: Fans and shroud (Jack Donahue) > 6. Re: Fans and shroud (Jack Donahue) > 7. Re: Fans and shroud (Larry Stock) > 8. McLeod hydraulic throw out (Cullen McCann) > 9. Re: Fans and shroud (Ken Green) > 10. McLeod hydraulic throw out (Larry Finch) > 11. Re: Tires for Grp IV Flared Car (MyCars) > 12. Re: Tires for Grp IV Flared Car (MyCars) > 13. Re: McLeod hydraulic throw out (Will Kooiman) > 14. Re: McLeod hydraulic throw out (Cullen McCann) > 15. Re: McLeod hydraulic throw out (Larry Stock) > 16. Re: Sanden Compressors noises (Mike Drew) > 17. Re: Sanden Compressors noises (Julian Kift) > 18. Re: Sanden Compressors noises (Mike Drew) > 19. Re: McLeod hydraulic throw out (Larry Finch) > 20. Re: McLeod hydraulic throw out (Cullen McCann) > 21. NPC, Need transmission suggestions (michael frazier) > 22. Re: Sanden Compressors noises (David Nunn) > 23. Re: NPC, Need transmission suggestions (bill) > 24. Re: Sanden Compressors noises (bill) > > > ---------------------------------------------------------------------- > > Message: 1 > Date: Fri, 16 Sep 2016 09:29:46 -0700 > From: Jack Donahue <demongusta@gmail.com> > To: "detomaso@server.detomasolist.com" > <detomaso@server.detomasolist.com> > Cc: "detomaso@server.detomasolist.com" > <detomaso@server.detomasolist.com> > Subject: [DeTomaso] Fans and shroud > Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> > Content-Type: text/plain; charset=utf-8 > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > > ------------------------------ > > Message: 2 > Date: Fri, 16 Sep 2016 16:54:05 +0000 > From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov> > To: Jack Donahue <demongusta@gmail.com>, > "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> > Subject: Re: [DeTomaso] Fans and shroud > Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov> > Content-Type: text/plain; charset="utf-8" > > Jack, > > Good stuff. I too am running the original radiator with new fans. I'm not going to change it > now but I will follow your progress. Someday I will have to deal with it. So keep posting and > I will keep saving the responses. ;-) > > Terry > > > > "A Purple Heart proves you were smart enough to hatch a plan, > stupid enough to try it and lucky enough to survive!" > > Terry W. Himes > JPL Jet Propulsion Laboratory > Dawn Spacecraft Team > Rosetta Sequence Team Lead > Phone: (818) 393-6261 > Cell: (818) 653-8213 > Fax: (818) 393-3147 > thimes@jpl.nasa.gov<[3]mailto:thimes@jpl.nasa.gov> > ?? > > From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@serve r.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> > Date: Friday, September 16, 2016 9:29 AM > To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>> > Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.c om>> > Subject: [DeTomaso] Fans and shroud > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.co m> > [4]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. >
When I bought my first Pantera in 2000 I had a heating problem at the track. When It would puke about 1/2 gal of coolant it would overheat and was hell to try and keep cool. It would sometimes suck the full puke tank back in as it cooled and work for a few laps then overheat again. I would refill the unit belch it at the radiator and it would work again for a while. After a couple of disappointing track days, I was under the car and followed the radiator lines forward. The engine return was routed from the top of the radiator. I found that when the car was rebuilt some years before they had replaced the radiator with a "Chevy" style radiator which had the lines reversed. My engine return was from the top of the radiator and the engine hot was going to the bottom of the radiator. Rearranged different radiator hook up hoses and it has been fine since. Sometimes the obvious isn't jerry knotts On 9/17/2016 9:56 AM, Julian Kift wrote: It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian __________________________________________________________________ From: DeTomaso [1]<detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke [2]<owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: [3]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [4]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [5]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [1][6]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to [7]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [8]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue [9]<demongusta@gmail.com> To: [10]"detomaso@server.detomasolist.com" [11]<detomaso@server.detomasolist.com> Cc: [12]"detomaso@server.detomasolist.com" [13]<detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: [14]<CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" [15]<terry.himes@jpl.nasa.gov> To: Jack Donahue [16]<demongusta@gmail.com>, [17]"detomaso@server.detomasolist.com" [18]<detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: [19]<D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [20]thimes@jpl.nasa.gov<[3][21]mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <[22]detomaso-bounces@server.detomasolist.com[23]<mailto:detomaso-bounces@ser ve r.detomasolist.com>> on behalf of Jack Donahue <[24]demongusta@gmail.com[25]<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[26]detomaso@server.detomasolist.com[27]<mailto:detomaso@server.detomasolist .c om>" <[28]detomaso@server.detomasolist.com[29]<mailto:detomaso@server.detomasolist .c om>> Cc: "[30]detomaso@server.detomasolist.com[31]<mailto:detomaso@server.detomasolist .c om>" <[32]detomaso@server.detomasolist.com[33]<mailto:detomaso@server.detomasolist .c om>> Subject: [DeTomaso] Fans and shroud
radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
[4][36]http://server.detomasolist.com/mailman/listinfo/detomaso
[34]DeTomaso@server.detomasolist.com[35]<mailto:DeTomaso@server.detomasolist. co m> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Checking the service manual I see that the return line to the water pump is connected to the top, and this is how it has always been connected on my car. Personally I think it makes sense to have it connected to the bottom for at least two reasons: 1) The coolant is at least in theory cooler at the bottom 2) It will supply coolant longer if there is a leak. Not sure how easy it would be to reverse the lines on my car. The lines would have to cross each other. Thomas Den 2016-09-19 kl. 15:46, skrev Jerry Knotts:
guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [4]detomaso-request@server.detomasolist.com wrote: > Send DeTomaso mailing list submissions to > [5]detomaso@server.detomasolist.com > > To subscribe or unsubscribe via the World Wide Web, visit > [1][6]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... > or, via email, send a message with subject or body 'help' to > [7]detomaso-request@server.detomasolist.com > > You can reach the person managing the list at > [8]detomaso-owner@server.detomasolist.com > > When replying, please edit your Subject line so it is more specific > than "Re: Contents of DeTomaso digest..." > > > Daily Detomaso List Digest > > Today's Topics: > > 1. Fans and shroud (Jack Donahue) > 2. Re: Fans and shroud (Himes, Terry (397C)) > 3. Tires for Grp IV Flared Car (MyCars) > 4. Re: Tires for Grp IV Flared Car (LSJ) > 5. Re: Fans and shroud (Jack Donahue) > 6. Re: Fans and shroud (Jack Donahue) > 7. Re: Fans and shroud (Larry Stock) > 8. McLeod hydraulic throw out (Cullen McCann) > 9. Re: Fans and shroud (Ken Green) > 10. McLeod hydraulic throw out (Larry Finch) > 11. Re: Tires for Grp IV Flared Car (MyCars) > 12. Re: Tires for Grp IV Flared Car (MyCars) > 13. Re: McLeod hydraulic throw out (Will Kooiman) > 14. Re: McLeod hydraulic throw out (Cullen McCann) > 15. Re: McLeod hydraulic throw out (Larry Stock) > 16. Re: Sanden Compressors noises (Mike Drew) > 17. Re: Sanden Compressors noises (Julian Kift) > 18. Re: Sanden Compressors noises (Mike Drew) > 19. Re: McLeod hydraulic throw out (Larry Finch) > 20. Re: McLeod hydraulic throw out (Cullen McCann) > 21. NPC, Need transmission suggestions (michael frazier) > 22. Re: Sanden Compressors noises (David Nunn) > 23. Re: NPC, Need transmission suggestions (bill) > 24. Re: Sanden Compressors noises (bill) > > > ---------------------------------------------------------------------- > > Message: 1 > Date: Fri, 16 Sep 2016 09:29:46 -0700 > From: Jack Donahue [9]<demongusta@gmail.com> > To: [10]"detomaso@server.detomasolist.com" > [11]<detomaso@server.detomasolist.com> > Cc: [12]"detomaso@server.detomasolist.com" > [13]<detomaso@server.detomasolist.com> > Subject: [DeTomaso] Fans and shroud > Message-ID: [14]<CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> > Content-Type: text/plain; charset=utf-8 > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > > ------------------------------ > > Message: 2 > Date: Fri, 16 Sep 2016 16:54:05 +0000 > From: "Himes, Terry (397C)" [15]<terry.himes@jpl.nasa.gov> > To: Jack Donahue [16]<demongusta@gmail.com>, > [17]"detomaso@server.detomasolist.com" [18]<detomaso@server.detomasolist.com> > Subject: Re: [DeTomaso] Fans and shroud > Message-ID: [19]<D4016E9F.92F3B%thimes@jpl.nasa.gov> > Content-Type: text/plain; charset="utf-8" > > Jack, > > Good stuff. I too am running the original radiator with new fans. I'm not going to change it > now but I will follow your progress. Someday I will have to deal with it. So keep posting and > I will keep saving the responses. ;-) > > Terry > > > > "A Purple Heart proves you were smart enough to hatch a plan, > stupid enough to try it and lucky enough to survive!" > > Terry W. Himes > JPL Jet Propulsion Laboratory > Dawn Spacecraft Team > Rosetta Sequence Team Lead > Phone: (818) 393-6261 > Cell: (818) 653-8213 > Fax: (818) 393-3147 > [20]thimes@jpl.nasa.gov<[3][21]mailto:thimes@jpl.nasa.gov> > ?? > > From: DeTomaso <[22]detomaso-bounces@server.detomasolist.com[23]<mailto:detomaso-bounces@ser ve r.detomasolist.com>> on behalf of Jack Donahue <[24]demongusta@gmail.com[25]<mailto:demongusta@gmail.com>> > Date: Friday, September 16, 2016 9:29 AM > To: "[26]detomaso@server.detomasolist.com[27]<mailto:detomaso@server.detomasolist .c om>" <[28]detomaso@server.detomasolist.com[29]<mailto:detomaso@server.detomasolist .c om>> > Cc: "[30]detomaso@server.detomasolist.com[31]<mailto:detomaso@server.detomasolist .c om>" <[32]detomaso@server.detomasolist.com[33]<mailto:detomaso@server.detomasolist .c om>> > Subject: [DeTomaso] Fans and shroud > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [34]DeTomaso@server.detomasolist.com[35]<mailto:DeTomaso@server.detomasolist. co m> > [4][36]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. >
Checking the service manual I see that the return line to the water pump is connected to the top, and this is how it has always been connected on my car. Personally I think it makes sense to have it connected to the bottom for at least two reasons: 1) The coolant is at least in theory cooler at the bottom 2) It will supply coolant longer if there is a leak. Not sure how easy it would be to reverse the lines on my car. The lines would have to cross each other. Thomas Den 2016-09-19 kl. 15:46, skrev Jerry Knotts: When I bought my first Pantera in 2000 I had a heating problem at the track. When It would puke about 1/2 gal of coolant it would overheat and was hell to try and keep cool. It would sometimes suck the full puke tank back in as it cooled and work for a few laps then overheat again. I would refill the unit belch it at the radiator and it would work again for a while. After a couple of disappointing track days, I was under the car and followed the radiator lines forward. The engine return was routed from the top of the radiator. I found that when the car was rebuilt some years before they had replaced the radiator with a "Chevy" style radiator which had the lines reversed. My engine return was from the top of the radiator and the engine hot was going to the bottom of the radiator. Rearranged different radiator hook up hoses and it has been fine since. Sometimes the obvious isn't jerry knotts On 9/17/2016 9:56 AM, Julian Kift wrote: It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian __________________________________________________________________ From: DeTomaso [1][1]<detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke [2][2]<owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: [[3]3]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [[4]4]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [[5]5]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [1][6][6]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to [[7]7]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [[8]8]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue [9][9]<demongusta@gmail.com> To: [10][10]"detomaso@server.detomasolist.com" [11][11]<detomaso@server.detomasolist.com> Cc: [12][12]"detomaso@server.detomasolist.com" [13][13]<detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: [14][14]<CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" [15][15]<terry.himes@jpl.nasa.gov> To: Jack Donahue [16][16]<demongusta@gmail.com>, [17][17]"detomaso@server.detomasolist.com" [18][18]<detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: [19][19]<D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [[20]20]thimes@jpl.nasa.gov<[3][21][21]mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <[[22]22]detomaso-bounces@server.detomasolist.com[23][23]<mailto:detomaso-bou nces@ser ve r.detomasolist.com>> on behalf of Jack Donahue <[[24]24]demongusta@gmail.com[25][25]<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[[26]26]detomaso@server.detomasolist.com[27][27]<mailto:detomaso@server.deto masolist .c om>" <[[28]28]detomaso@server.detomasolist.com[29][29]<mailto:detomaso@server.deto masolist .c om>> Cc: "[[30]30]detomaso@server.detomasolist.com[31][31]<mailto:detomaso@server.deto masolist .c om>" <[[32]32]detomaso@server.detomasolist.com[33][33]<mailto:detomaso@server.deto masolist .c om>> Subject: [DeTomaso] Fans and shroud
[4][36][36]http://server.detomasolist.com/mailman/listinfo/detomaso
[[34]34]DeTomaso@server.detomasolist.com[35][35]<mailto:DeTomaso@server.detom asolist. co m> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Thomas, I had to cut about 8 inches off of one of the SS lines and turn it a bit. Then take a tour of the back room of our auto parts store to find a formed hose that I could cut up to provide the correct bends for the reverse attachment. Unfortunately it is about time to replace the cut up hose and I don't have any idea which hose I used. jerry knotts On 9/19/2016 9:07 AM, Thomas Törnblom wrote:
guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [[4]4]detomaso-request@server.detomasolist.com wrote: > Send DeTomaso mailing list submissions to > [[5]5]detomaso@server.detomasolist.com > > To subscribe or unsubscribe via the World Wide Web, visit > [1][6][6]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... > or, via email, send a message with subject or body 'help' to > [[7]7]detomaso-request@server.detomasolist.com > > You can reach the person managing the list at > [[8]8]detomaso-owner@server.detomasolist.com > > When replying, please edit your Subject line so it is more specific > than "Re: Contents of DeTomaso digest..." > > > Daily Detomaso List Digest > > Today's Topics: > > 1. Fans and shroud (Jack Donahue) > 2. Re: Fans and shroud (Himes, Terry (397C)) > 3. Tires for Grp IV Flared Car (MyCars) > 4. Re: Tires for Grp IV Flared Car (LSJ) > 5. Re: Fans and shroud (Jack Donahue) > 6. Re: Fans and shroud (Jack Donahue) > 7. Re: Fans and shroud (Larry Stock) > 8. McLeod hydraulic throw out (Cullen McCann) > 9. Re: Fans and shroud (Ken Green) > 10. McLeod hydraulic throw out (Larry Finch) > 11. Re: Tires for Grp IV Flared Car (MyCars) > 12. Re: Tires for Grp IV Flared Car (MyCars) > 13. Re: McLeod hydraulic throw out (Will Kooiman) > 14. Re: McLeod hydraulic throw out (Cullen McCann) > 15. Re: McLeod hydraulic throw out (Larry Stock) > 16. Re: Sanden Compressors noises (Mike Drew) > 17. Re: Sanden Compressors noises (Julian Kift) > 18. Re: Sanden Compressors noises (Mike Drew) > 19. Re: McLeod hydraulic throw out (Larry Finch) > 20. Re: McLeod hydraulic throw out (Cullen McCann) > 21. NPC, Need transmission suggestions (michael frazier) > 22. Re: Sanden Compressors noises (David Nunn) > 23. Re: NPC, Need transmission suggestions (bill) > 24. Re: Sanden Compressors noises (bill) > > > ---------------------------------------------------------------------- > > Message: 1 > Date: Fri, 16 Sep 2016 09:29:46 -0700 > From: Jack Donahue [9][9]<demongusta@gmail.com> > To: [10][10]"detomaso@server.detomasolist.com" > [11][11]<detomaso@server.detomasolist.com> > Cc: [12][12]"detomaso@server.detomasolist.com" > [13][13]<detomaso@server.detomasolist.com> > Subject: [DeTomaso] Fans and shroud > Message-ID: [14][14]<CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> > Content-Type: text/plain; charset=utf-8 > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > > ------------------------------ > > Message: 2 > Date: Fri, 16 Sep 2016 16:54:05 +0000 > From: "Himes, Terry (397C)" [15][15]<terry.himes@jpl.nasa.gov> > To: Jack Donahue [16][16]<demongusta@gmail.com>, > [17][17]"detomaso@server.detomasolist.com" [18][18]<detomaso@server.detomasolist.com> > Subject: Re: [DeTomaso] Fans and shroud > Message-ID: [19][19]<D4016E9F.92F3B%thimes@jpl.nasa.gov> > Content-Type: text/plain; charset="utf-8" > > Jack, > > Good stuff. I too am running the original radiator with new fans. I'm not going to change it > now but I will follow your progress. Someday I will have to deal with it. So keep posting and > I will keep saving the responses. ;-) > > Terry > > > > "A Purple Heart proves you were smart enough to hatch a plan, > stupid enough to try it and lucky enough to survive!" > > Terry W. Himes > JPL Jet Propulsion Laboratory > Dawn Spacecraft Team > Rosetta Sequence Team Lead > Phone: (818) 393-6261 > Cell: (818) 653-8213 > Fax: (818) 393-3147 > [[20]20]thimes@jpl.nasa.gov<[3][21][21]mailto:thimes@jpl.nasa.gov> > ?? > > From: DeTomaso <[[22]22]detomaso-bounces@server.detomasolist.com[23][23]<mailto:detomaso-bou nces@ser ve r.detomasolist.com>> on behalf of Jack Donahue <[[24]24]demongusta@gmail.com[25][25]<mailto:demongusta@gmail.com>> > Date: Friday, September 16, 2016 9:29 AM > To: "[[26]26]detomaso@server.detomasolist.com[27][27]<mailto:detomaso@server.deto masolist .c om>" <[[28]28]detomaso@server.detomasolist.com[29][29]<mailto:detomaso@server.deto masolist .c om>> > Cc: "[[30]30]detomaso@server.detomasolist.com[31][31]<mailto:detomaso@server.deto masolist .c om>" <[[32]32]detomaso@server.detomasolist.com[33][33]<mailto:detomaso@server.deto masolist .c om>> > Subject: [DeTomaso] Fans and shroud > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [[34]34]DeTomaso@server.detomasolist.com[35][35]<mailto:DeTomaso@server.detom asolist. co m> > [4][36][36]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. >
Thomas, I had to cut about 8 inches off of one of the SS lines and turn it a bit. Then take a tour of the back room of our auto parts store to find a formed hose that I could cut up to provide the correct bends for the reverse attachment. Unfortunately it is about time to replace the cut up hose and I don't have any idea which hose I used. jerry knotts On 9/19/2016 9:07 AM, Thomas Toernblom wrote: Checking the service manual I see that the return line to the water pump is connected to the top, and this is how it has always been connected on my car. Personally I think it makes sense to have it connected to the bottom for at least two reasons: 1) The coolant is at least in theory cooler at the bottom 2) It will supply coolant longer if there is a leak. Not sure how easy it would be to reverse the lines on my car. The lines would have to cross each other. Thomas Den 2016-09-19 kl. 15:46, skrev Jerry Knotts: When I bought my first Pantera in 2000 I had a heating problem at the track. When It would puke about 1/2 gal of coolant it would overheat and was hell to try and keep cool. It would sometimes suck the full puke tank back in as it cooled and work for a few laps then overheat again. I would refill the unit belch it at the radiator and it would work again for a while. After a couple of disappointing track days, I was under the car and followed the radiator lines forward. The engine return was routed from the top of the radiator. I found that when the car was rebuilt some years before they had replaced the radiator with a "Chevy" style radiator which had the lines reversed. My engine return was from the top of the radiator and the engine hot was going to the bottom of the radiator. Rearranged different radiator hook up hoses and it has been fine since. Sometimes the obvious isn't jerry knotts On 9/17/2016 9:56 AM, Julian Kift wrote: It's great to hear that you now have a functioning cooling system, although I have to wonder which of the particular changes contributed most, I suspect the thermostat housing being blocked off was a bulk of the problem. I had a similar experience when I got my first Pantera, it overheated in traffic, so I jumped on the web found all these articles about swapping radiators and fans etc. and duly went and purchased a setup. When I got to going through the car checking the thermostat I found it was a Windsor style, I swapped it for the correct Cleveland t-stat and voila heating issues resolved. It's just a reminder to check the simple stuff prior to laying out big $$$, even now I think there are still a lot of myths' perpetuated about these cars... like someone once said "why let the truth get in the way of a good story" Julian __________________________________________________________________ From: DeTomaso [1][1][1]<detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke [2][2][2]<owen@tadhgcooke.com> Sent: Saturday, September 17, 2016 2:19 AM To: [[[3]3]3]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [[[4]4]4]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [[[5]5]5]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [1][6][6][6]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... or, via email, send a message with subject or body 'help' to [[[7]7]7]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [[[8]8]8]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue [9][9][9]<demongusta@gmail.com> To: [10][10][10]"detomaso@server.detomasolist.com" [11][11][11]<detomaso@server.detomasolist.com> Cc: [12][12][12]"detomaso@server.detomasolist.com" [13][13][13]<detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: [14][14][14]<CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" [15][15][15]<terry.himes@jpl.nasa.gov> To: Jack Donahue [16][16][16]<demongusta@gmail.com>, [17][17][17]"detomaso@server.detomasolist.com" [18][18][18]<detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: [19][19][19]<D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [[[20]20]20]thimes@jpl.nasa.gov<[3][21][21][21]mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <[[[22]22]22]detomaso-bounces@server.detomasolist.com[23][23][23]<mailto:deto maso-bou nces@ser ve r.detomasolist.com>> on behalf of Jack Donahue <[[[24]24]24]demongusta@gmail.com[25][25][25]<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[[[26]26]26]detomaso@server.detomasolist.com[27][27][27]<mailto:detomaso@ser ver.deto masolist .c om>" <[[[28]28]28]detomaso@server.detomasolist.com[29][29][29]<mailto:detomaso@ser ver.deto masolist .c om>> Cc: "[[[30]30]30]detomaso@server.detomasolist.com[31][31][31]<mailto:detomaso@ser ver.deto masolist .c om>" <[[[32]32]32]detomaso@server.detomasolist.com[33][33][33]<mailto:detomaso@ser ver.deto masolist .c om>> Subject: [DeTomaso] Fans and shroud
[4][36][36][36]http://server.detomasolist.com/mailman/listinfo/detomaso
[[[34]34]34]DeTomaso@server.detomasolist.com[35][35][35]<mailto:DeTomaso@serv er.detom asolist. co m> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
"but my car had bleed pipe from the rad back to the swirl tank" I'm kinda fascinated by this mod, which I believe is in the TSB's, connecting the top of the radiator to the swirl tank with a long hose. Not sure how it works or what it was supposed to do. With a completely dry system, I can visualise how it would allow the radiator to fill completely, as air formerly trapped in the top of the radiator would have a path back to the swirl tank, a higher point. But once the engine is started, water or air is going to move from the swirl tank to the radiator, because of pressure difference. Not sure this is helpful but maybe isn't harmful. Most difficult to visualize, if the engine is off and there is air in the radiator, can the weight / head / row gee aych of the water in the swirl tank push the air into the swirl tank ? Is there some Archimedes rule I'm not seeing here ? Also did any cars come from the factory this way, was there an official path and mounting systems for the hose ? Cable ties ? Thanks, Guy D. From: Owen Cooke <owen@tadhgcooke.com> To: detomaso@server.detomasolist.com Sent: Saturday, September 17, 2016 2:19 AM Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com
You can reach the person managing the list at detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <demongusta@gmail.com> To: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Cc: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov> To: Jack Donahue <demongusta@gmail.com>, "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> ??
From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Jack Donahue <demongusta@gmail.com<mailto:demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud
"but my car had bleed pipe from the rad back to the swirl tank" I'm kinda fascinated by this mod, which I believe is in the TSB's, connecting the top of the radiator to the swirl tank with a long hose. Not sure how it works or what it was supposed to do. With a completely dry system, I can visualise how it would allow the radiator to fill completely, as air formerly trapped in the top of the radiator would have a path back to the swirl tank, a higher point. But once the engine is started, water or air is going to move from the swirl tank to the radiator, because of pressure difference. Not sure this is helpful but maybe isn't harmful. Most difficult to visualize, if the engine is off and there is air in the radiator, can the weight / head / row gee aych of the water in the swirl tank push the air into the swirl tank ? Is there some Archimedes rule I'm not seeing here ? Also did any cars come from the factory this way, was there an official path and mounting systems for the hose ? Cable ties ? Thanks, Guy D. __________________________________________________________________ From: Owen Cooke <owen@tadhgcooke.com> To: detomaso@server.detomasolist.com Sent: Saturday, September 17, 2016 2:19 AM Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [1]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [2]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [3]http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to [4]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [5]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <[6]demongusta@gmail.com> To: "[7]detomaso@server.detomasolist.com" <[8]detomaso@server.detomasolist.com> Cc: "[9]detomaso@server.detomasolist.com" <[10]detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: <[11]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <[12]terry.himes@jpl.nasa.gov> To: Jack Donahue <[13]demongusta@gmail.com>, "[14]detomaso@server.detomasolist.com" <[15]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%[16]thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [17]thimes@jpl.nasa.gov<mailto:[18]thimes@jpl.nasa.gov> ??
From: DeTomaso <[19]detomaso-bounces@server.detomasolist.com<mailto:[20]detomaso-bounc es@server.detomasolist.com>> on behalf of Jack Donahue <[21]demongusta@gmail.com<mailto:[22]demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[23]detomaso@server.detomasolist.com<mailto:[24]detomaso@server.detoma solist.com>" <[25]detomaso@server.detomasolist.com<mailto:[26]detomaso@server.detoma solist.com>> Cc: "[27]detomaso@server.detomasolist.com<mailto:[28]detomaso@server.detoma solist.com>" <[29]detomaso@server.detomasolist.com<mailto:[30]detomaso@server.detoma solist.com>> Subject: [DeTomaso] Fans and shroud
[33]http://server.detomasolist.com/mailman/listinfo/detomaso
[31]DeTomaso@server.detomasolist.com<mailto:[32]DeTomaso@server.detomas olist.com> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
IF you apply the "right hand vector" rule (fingers pointed with flow, thumb indicated vector direction), the swirl tank would have its primary vector going down, with the flow in the radiator entering on bottom and exiting top, its vector would be forward of the car. Now taking the cross of those two vectors, the resultant would apply to the vent connection and have flow going in the opposite direct (assuming the car is driven north, taking into account for the coriolis compounding) -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Guido deTomaso Sent: Wednesday, September 21, 2016 17:38 PM To: Owen Cooke; detomaso@server.detomasolist.com Subject: [DeTomaso] Top of radiator connected to swirl tank, was Re: DeTomaso Digest, Vol 147, Issue 19 ....Not sure how it works or what it was supposed to do.. ....Is there some Archimedes rule I'm not seeing here ? ... Guy D. BTW, it took longer to delete the forwarding past emails than to write that malarkey
OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote:
Thanks,
Guy D.
------------------------------------------------------------------------ *From:* Owen Cooke <owen@tadhgcooke.com> *To:* detomaso@server.detomasolist.com *Sent:* Saturday, September 17, 2016 2:19 AM *Subject:* Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19
guys
owen cooke
Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>
To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com <mailto:detomaso-request@server.detomasolist.com>
You can reach the person managing the list at detomaso-owner@server.detomasolist.com <mailto:detomaso-owner@server.detomasolist.com>
When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..."
Today's Topics:
1. Fans and shroud (Jack Donahue) 2. Re: Fans and shroud (Himes, Terry (397C)) 3. Tires for Grp IV Flared Car (MyCars) 4. Re: Tires for Grp IV Flared Car (LSJ) 5. Re: Fans and shroud (Jack Donahue) 6. Re: Fans and shroud (Jack Donahue) 7. Re: Fans and shroud (Larry Stock) 8. McLeod hydraulic throw out (Cullen McCann) 9. Re: Fans and shroud (Ken Green) 10. McLeod hydraulic throw out (Larry Finch) 11. Re: Tires for Grp IV Flared Car (MyCars) 12. Re: Tires for Grp IV Flared Car (MyCars) 13. Re: McLeod hydraulic throw out (Will Kooiman) 14. Re: McLeod hydraulic throw out (Cullen McCann) 15. Re: McLeod hydraulic throw out (Larry Stock) 16. Re: Sanden Compressors noises (Mike Drew) 17. Re: Sanden Compressors noises (Julian Kift) 18. Re: Sanden Compressors noises (Mike Drew) 19. Re: McLeod hydraulic throw out (Larry Finch) 20. Re: McLeod hydraulic throw out (Cullen McCann) 21. NPC, Need transmission suggestions (michael frazier) 22. Re: Sanden Compressors noises (David Nunn) 23. Re: NPC, Need transmission suggestions (bill) 24. Re: Sanden Compressors noises (bill)
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <demongusta@gmail.com <mailto:demongusta@gmail.com>> To: "detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com <mailto:CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com>> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov <mailto:terry.himes@jpl.nasa.gov>> To: Jack Donahue <demongusta@gmail.com <mailto:demongusta@gmail.com>>, "detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov <mailto:thimes@jpl.nasa.gov>> Content-Type: text/plain; charset="utf-8"
Jack,
Good stuff. I too am running the original radiator with new fans. I'm not going to change it now but I will follow your progress. Someday I will have to deal with it. So keep posting and I will keep saving the responses. ;-)
Terry
"A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!"
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov <mailto:thimes@jpl.nasa.gov><mailto:thimes@jpl.nasa.gov <mailto:thimes@jpl.nasa.gov>> ??
From: DeTomaso <detomaso-bounces@server.detomasolist.com <mailto:detomaso-bounces@server.detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com <mailto:detomaso-bounces@server.detomasolist.com>>> on behalf of Jack Donahue <demongusta@gmail.com <mailto:demongusta@gmail.com><mailto:demongusta@gmail.com <mailto:demongusta@gmail.com>>> Date: Friday, September 16, 2016 9:29 AM To: "detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>>" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>>> Cc: "detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>>" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>>> Subject: [DeTomaso] Fans and shroud
Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a
So - I am ready for opinions/suggestions: jack #4348 _______________________________________________
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com <mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.detomasolist.com <mailto:DeTomaso@server.detomasolist.com>> http://server.detomasolist.com/mailman/listinfo/detomaso
On 16/09/2016 23:31, detomaso-request@server.detomasolist.com <mailto:detomaso-request@server.detomasolist.com> wrote: perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote: "but my car had bleed pipe from the rad back to the swirl tank" I'm kinda fascinated by this mod, which I believe is in the TSB's, connecting the top of the radiator to the swirl tank with a long hose. Not sure how it works or what it was supposed to do. With a completely dry system, I can visualise how it would allow the radiator to fill completely, as air formerly trapped in the top of the radiator would have a path back to the swirl tank, a higher point. But once the engine is started, water or air is going to move from the swirl tank to the radiator, because of pressure difference. Not sure this is helpful but maybe isn't harmful. Most difficult to visualize, if the engine is off and there is air in the radiator, can the weight / head / row gee aych of the water in the swirl tank push the air into the swirl tank ? Is there some Archimedes rule I'm not seeing here ? Also did any cars come from the factory this way, was there an official path and mounting systems for the hose ? Cable ties ? Thanks, Guy D. __________________________________________________________________ From: Owen Cooke [1]<owen@tadhgcooke.com> To: [2]detomaso@server.detomasolist.com Sent: Saturday, September 17, 2016 2:19 AM Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [3]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [4]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [5]http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to [6]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [7]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <[8]demongusta@gmail.com> To: "[9]detomaso@server.detomasolist.com" <[10]detomaso@server.detomasolist.com> Cc: "[11]detomaso@server.detomasolist.com" <[12]detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: <[13]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <[14]terry.himes@jpl.nasa.gov> To: Jack Donahue <[15]demongusta@gmail.com>, "[16]detomaso@server.detomasolist.com" <[17]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%[18]thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [19]thimes@jpl.nasa.gov<mailto:[20]thimes@jpl.nasa.gov> ??
From: DeTomaso <[21]detomaso-bounces@server.detomasolist.com<mailto:[22]detomaso-bounc es@server.detomasolist.com>> on behalf of Jack Donahue <[23]demongusta@gmail.com<mailto:[24]demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[25]detomaso@server.detomasolist.com<mailto:[26]detomaso@server.detoma solist.com>" <[27]detomaso@server.detomasolist.com<mailto:[28]detomaso@server.detoma solist.com>> Cc: "[29]detomaso@server.detomasolist.com<mailto:[30]detomaso@server.detoma solist.com>" <[31]detomaso@server.detomasolist.com<mailto:[32]detomaso@server.detoma solist.com>> Subject: [DeTomaso] Fans and shroud
[35]http://server.detomasolist.com/mailman/listinfo/detomaso
[33]DeTomaso@server.detomasolist.com<mailto:[34]DeTomaso@server.detomas olist.com> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
On my car (1984 GT5) it was connected to a fitting using the hole in the swirl tank that was used for the temp sender on early cars. I'm fairly certain that was from the factory. I now have a Fluidyne radiator and have disconnected this line. Den 2016-09-22 kl. 11:51, skrev Owen Cooke:
owen cooke
From: Owen Cooke [1]<owen@tadhgcooke.com> To: [2]detomaso@server.detomasolist.com Sent: Saturday, September 17, 2016 2:19 AM Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [3]detomaso-request@server.detomasolist.com wrote: > Send DeTomaso mailing list submissions to > [4]detomaso@server.detomasolist.com > > To subscribe or unsubscribe via the World Wide Web, visit > [5]http://server.detomasolist.com/mailman/listinfo/detomaso > or, via email, send a message with subject or body 'help' to > [6]detomaso-request@server.detomasolist.com > > You can reach the person managing the list at > [7]detomaso-owner@server.detomasolist.com > > When replying, please edit your Subject line so it is more specific > than "Re: Contents of DeTomaso digest..." > > > Daily Detomaso List Digest > > Today's Topics: > > 1. Fans and shroud (Jack Donahue) > 2. Re: Fans and shroud (Himes, Terry (397C)) > 3. Tires for Grp IV Flared Car (MyCars) > 4. Re: Tires for Grp IV Flared Car (LSJ) > 5. Re: Fans and shroud (Jack Donahue) > 6. Re: Fans and shroud (Jack Donahue) > 7. Re: Fans and shroud (Larry Stock) > 8. McLeod hydraulic throw out (Cullen McCann) > 9. Re: Fans and shroud (Ken Green) > 10. McLeod hydraulic throw out (Larry Finch) > 11. Re: Tires for Grp IV Flared Car (MyCars) > 12. Re: Tires for Grp IV Flared Car (MyCars) > 13. Re: McLeod hydraulic throw out (Will Kooiman) > 14. Re: McLeod hydraulic throw out (Cullen McCann) > 15. Re: McLeod hydraulic throw out (Larry Stock) > 16. Re: Sanden Compressors noises (Mike Drew) > 17. Re: Sanden Compressors noises (Julian Kift) > 18. Re: Sanden Compressors noises (Mike Drew) > 19. Re: McLeod hydraulic throw out (Larry Finch) > 20. Re: McLeod hydraulic throw out (Cullen McCann) > 21. NPC, Need transmission suggestions (michael frazier) > 22. Re: Sanden Compressors noises (David Nunn) > 23. Re: NPC, Need transmission suggestions (bill) > 24. Re: Sanden Compressors noises (bill) > > > ---------------------------------------------------------------------- > > Message: 1 > Date: Fri, 16 Sep 2016 09:29:46 -0700 > From: Jack Donahue <[8]demongusta@gmail.com> > To: "[9]detomaso@server.detomasolist.com" > <[10]detomaso@server.detomasolist.com> > Cc: "[11]detomaso@server.detomasolist.com" > <[12]detomaso@server.detomasolist.com> > Subject: [DeTomaso] Fans and shroud > Message-ID: <[13]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> > Content-Type: text/plain; charset=utf-8 > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > > ------------------------------ > > Message: 2 > Date: Fri, 16 Sep 2016 16:54:05 +0000 > From: "Himes, Terry (397C)" <[14]terry.himes@jpl.nasa.gov> > To: Jack Donahue <[15]demongusta@gmail.com>, > "[16]detomaso@server.detomasolist.com" <[17]detomaso@server.detomasolist.com> > Subject: Re: [DeTomaso] Fans and shroud > Message-ID: <D4016E9F.92F3B%[18]thimes@jpl.nasa.gov> > Content-Type: text/plain; charset="utf-8" > > Jack, > > Good stuff. I too am running the original radiator with new fans. I'm not going to change it > now but I will follow your progress. Someday I will have to deal with it. So keep posting and > I will keep saving the responses. ;-) > > Terry > > > > "A Purple Heart proves you were smart enough to hatch a plan, > stupid enough to try it and lucky enough to survive!" > > Terry W. Himes > JPL Jet Propulsion Laboratory > Dawn Spacecraft Team > Rosetta Sequence Team Lead > Phone: (818) 393-6261 > Cell: (818) 653-8213 > Fax: (818) 393-3147 > [19]thimes@jpl.nasa.gov<mailto:[20]thimes@jpl.nasa.gov> > ?? > > From: DeTomaso <[21]detomaso-bounces@server.detomasolist.com<mailto:[22]detomaso-bounc es@server.detomasolist.com>> on behalf of Jack Donahue <[23]demongusta@gmail.com<mailto:[24]demongusta@gmail.com>> > Date: Friday, September 16, 2016 9:29 AM > To: "[25]detomaso@server.detomasolist.com<mailto:[26]detomaso@server.detoma solist.com>" <[27]detomaso@server.detomasolist.com<mailto:[28]detomaso@server.detoma solist.com>> > Cc: "[29]detomaso@server.detomasolist.com<mailto:[30]detomaso@server.detoma solist.com>" <[31]detomaso@server.detomasolist.com<mailto:[32]detomaso@server.detoma solist.com>> > Subject: [DeTomaso] Fans and shroud > > Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. > Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. > So - I am ready for opinions/suggestions: > jack > #4348 > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [33]DeTomaso@server.detomasolist.com<mailto:[34]DeTomaso@server.detomas olist.com> > [35]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. >
On my car (1984 GT5) it was connected to a fitting using the hole in the swirl tank that was used for the temp sender on early cars. I'm fairly certain that was from the factory. I now have a Fluidyne radiator and have disconnected this line. Den 2016-09-22 kl. 11:51, skrev Owen Cooke: OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote: "but my car had bleed pipe from the rad back to the swirl tank" I'm kinda fascinated by this mod, which I believe is in the TSB's, connecting the top of the radiator to the swirl tank with a long hose. Not sure how it works or what it was supposed to do. With a completely dry system, I can visualise how it would allow the radiator to fill completely, as air formerly trapped in the top of the radiator would have a path back to the swirl tank, a higher point. But once the engine is started, water or air is going to move from the swirl tank to the radiator, because of pressure difference. Not sure this is helpful but maybe isn't harmful. Most difficult to visualize, if the engine is off and there is air in the radiator, can the weight / head / row gee aych of the water in the swirl tank push the air into the swirl tank ? Is there some Archimedes rule I'm not seeing here ? Also did any cars come from the factory this way, was there an official path and mounting systems for the hose ? Cable ties ? Thanks, Guy D. __________________________________________________________________ From: Owen Cooke [1][1]<owen@tadhgcooke.com> To: [[2]2]detomaso@server.detomasolist.com Sent: Saturday, September 17, 2016 2:19 AM Subject: Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19 guys i had overheating problems i put in a new hall brass rad but my car had bleed pipe from the rad back to the swirl tank and no fitting in halls rad for it apart from a top bleed screw so i made a junction to fit the original bleed screw and the bleed pipe to it then new mariah (is that the right name) that fir on the stock brackets and wired them directly from the battery to the relays i found the hole under the thermostat was blocked with solder i removed that and fitted a new stat now all is perfect temp wise - warms up steady and holds the 90c or 195f in all conditions my gauge with sender in block beside the pump/stat ready 150f but its steady and i know what to expect very happy with result owen cooke On 16/09/2016 23:31, [[3]3]detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to [[4]4]detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit [5][5]http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to [[6]6]detomaso-request@server.detomasolist.com
You can reach the person managing the list at [[7]7]detomaso-owner@server.detomasolist.com
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue [8]<[8]demongusta@gmail.com> To: [9]"[9]detomaso@server.detomasolist.com" [10]<[10]detomaso@server.detomasolist.com> Cc: [11]"[11]detomaso@server.detomasolist.com" [12]<[12]detomaso@server.detomasolist.com> Subject: [DeTomaso] Fans and shroud Message-ID: [13]<[13]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com> Content-Type: text/plain; charset=utf-8
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" [14]<[14]terry.himes@jpl.nasa.gov> To: Jack Donahue [15]<[15]demongusta@gmail.com>, [16]"[16]detomaso@server.detomasolist.com" [17]<[17]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Fans and shroud Message-ID: [18]<D4016E9F.92F3B%[18]thimes@jpl.nasa.gov> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [[19]19]thimes@jpl.nasa.gov[20]<mailto:[20]thimes@jpl.nasa.gov> ??
From: DeTomaso <[[21]21]detomaso-bounces@server.detomasolist.com[22]<mailto:[22]detomaso-bou nc es@server.detomasolist.com>> on behalf of Jack Donahue <[[23]23]demongusta@gmail.com[24]<mailto:[24]demongusta@gmail.com>> Date: Friday, September 16, 2016 9:29 AM To: "[[25]25]detomaso@server.detomasolist.com[26]<mailto:[26]detomaso@server.deto ma solist.com>" <[[27]27]detomaso@server.detomasolist.com[28]<mailto:[28]detomaso@server.deto ma solist.com>> Cc: "[[29]29]detomaso@server.detomasolist.com[30]<mailto:[30]detomaso@server.deto ma solist.com>" <[[31]31]detomaso@server.detomasolist.com[32]<mailto:[32]detomaso@server.deto ma solist.com>> Subject: [DeTomaso] Fans and shroud
radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
[35][35]http://server.detomasolist.com/mailman/listinfo/detomaso
[[33]33]DeTomaso@server.detomasolist.com[34]<mailto:[34]DeTomaso@server.detom as olist.com> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
I think typically the factory chassis holes between the coolant tubes you refer to carries the steel pipe that runs the vacuum brake booster to engine vacuum. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> Sent: Thursday, September 22, 2016 2:51 AM To: Guido deTomaso; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Top of radiator connected to swirl tank, was Re: DeTomaso Digest, Vol 147, Issue 19 OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote:
Thanks,
Guy D.
guys
owen cooke
Today's Topics:
Jack,
Terry
I think typically the factory chassis holes between the coolant tubes you refer to carries the steel pipe that runs the vacuum brake booster to engine vacuum. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> Sent: Thursday, September 22, 2016 2:51 AM To: Guido deTomaso; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Top of radiator connected to swirl tank, was Re: DeTomaso Digest, Vol 147, Issue 19 OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote:
the the the
Thanks,
Guy D.
guys
----------------------------------------------------------------------- - pipe
to it
owen cooke
On 16/09/2016 23:31, detomaso-request@server.detomasolist.com <[1]mailto:detomaso-request@server.detomasolist.com> wrote:
Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com <[2]mailto:detomaso@server.detomasolist.com>
To subscribe or unsubscribe via the World Wide Web, visit [3]http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com <[4]mailto:detomaso-request@server.detomasolist.com>
You can reach the person managing the list at detomaso-owner@server.detomasolist.com <[5]mailto:detomaso-owner@server.detomasolist.com>
Today's Topics:
To: "detomaso@server.detomasolist.com <[7]mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <[8]mailto:detomaso@server.detomasolist.com>> Cc: "detomaso@server.detomasolist.com <[9]mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <[10]mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Message-ID: <CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com <[11]mailto:CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com>> Content-Type: text/plain; charset=utf-8
<[6]mailto:demongusta@gmail.com>> perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov <[12]mailto:terry.himes@jpl.nasa.gov>> To: Jack Donahue <demongusta@gmail.com <[13]mailto:demongusta@gmail.com>>, "detomaso@server.detomasolist.com <[14]mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com <[15]mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <D4016E9F.92F3B%thimes@jpl.nasa.gov <[16]mailto:thimes@jpl.nasa.gov>> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov <[17]mailto:thimes@jpl.nasa.gov><mailto:thimes@jpl.nasa.gov <[18]mailto:thimes@jpl.nasa.gov>> ??
<[19]mailto:detomaso-bounces@server.detomasolist.com><mailto:detomaso-b ounces@server.detomasolist.com
<[20]mailto:detomaso-bounces@server.detomasolist.com>>> on behalf of Jack Donahue <demongusta@gmail.com <[21]mailto:demongusta@gmail.com><mailto:demongusta@gmail.com <[22]mailto:demongusta@gmail.com>>>
<[23]mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.de tomasolist.com
<[24]mailto:detomaso@server.detomasolist.com>>" <detomaso@server.detomasolist.com
<[25]mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.de tomasolist.com
<[26]mailto:detomaso@server.detomasolist.com>>>
<[27]mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.de tomasolist.com
<[28]mailto:detomaso@server.detomasolist.com>>" <detomaso@server.detomasolist.com
<[29]mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.de tomasolist.com
<[30]mailto:detomaso@server.detomasolist.com>>> perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
<[32]mailto:DeTomaso@server.detomasolist.com>>
<[31]mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.de tomasolist.com the
Julian yes you could be right i need to check it all again owen cooke On 22/09/2016 13:34, Julian Kift wrote:
Julian
------------------------------------------------------------------------ *From:* DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke <owen@tadhgcooke.com> *Sent:* Thursday, September 22, 2016 2:51 AM *To:* Guido deTomaso; detomaso@server.detomasolist.com *Subject:* Re: [DeTomaso] Top of radiator connected to swirl tank, was Re: DeTomaso Digest, Vol 147, Issue 19 OK i may have stated this incorrectly
owen cooke
Thanks,
Guy D.
guys
owen cooke
Today's Topics:
Hey all - A few weeks ago I was talking asking The List about radiators - all said-and-done, I decided on the Hall radiator, since I wanted brass/copper instead of aluminum. And, yes Mike Drew, I have to admit it?s because I want to, not necessarily NEED to. It ain?t broke, but I am fixing it(?). Didn?t want to admit that, but...Lol. There really is an ulterior motive, but I just don?t want to mention it right now; but I ran my idea past Brassworks - who says they will ?build-to-suit? - but the Hall unit looks to be ?tried-and-proven?. Now - fans. I really don?t know the brand name of my fans, but they are suckers - about 12? diameter - and the blades are ?curved? - sickle-shaped. The names that been bouncing around are Mariah, SPAL, and Flex-a-lite. I had read someone?s post about the Flex-a-lite?s since they said they can be - or are - mounted in a shroud that is a perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me. So - I am ready for opinions/suggestions: jack #4348
Jack,
Terry
<mailto:detomaso@server.detomasolist.com>>> perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
<mailto:DeTomaso@server.detomasolist.com>> list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Julian yes you could be right i need to check it all again owen cooke On 22/09/2016 13:34, Julian Kift wrote: I think typically the factory chassis holes between the coolant tubes you refer to carries the steel pipe that runs the vacuum brake booster to engine vacuum. Julian __________________________________________________________________ From: DeTomaso [1]<detomaso-bounces@server.detomasolist.com> on behalf of Owen Cooke [2]<owen@tadhgcooke.com> Sent: Thursday, September 22, 2016 2:51 AM To: Guido deTomaso; [3]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Top of radiator connected to swirl tank, was Re: DeTomaso Digest, Vol 147, Issue 19 OK i may have stated this incorrectly there is a steel pipe running from the top of the rad back to the engine and i forget exactly where is ends in the engine bay but this was clearly a factory installation as the chassis pieces had nicely flared hole and grommets lying between the two main steel pipes and the chassis pieces it runs through were clearly in the original steel pressing so this was not an after market fitting i will check on exactly where in the engine bay the pipes are going - i only guesses the swirl tank owen cooke On 21/09/2016 22:37, Guido deTomaso wrote:
the the the
Thanks,
Guy D.
*From:* Owen Cooke [4]<owen@tadhgcooke.com> *To:* [5]detomaso@server.detomasolist.com *Sent:* Saturday, September 17, 2016 2:19 AM *Subject:* Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 19
guys
to it
owen cooke
On 16/09/2016 23:31, [6]detomaso-request@server.detomasolist.com <[7]mailto:detomaso-request@server.detomasolist.com> wrote:
Send DeTomaso mailing list submissions to [8]detomaso@server.detomasolist.com <[9]mailto:detomaso@server.detomasolist.com>
To subscribe or unsubscribe via the World Wide Web, visit [10]http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to [11]detomaso-request@server.detomasolist.com <[12]mailto:detomaso-request@server.detomasolist.com>
You can reach the person managing the list at [13]detomaso-owner@server.detomasolist.com <[14]mailto:detomaso-owner@server.detomasolist.com>
Today's Topics:
Message: 1 Date: Fri, 16 Sep 2016 09:29:46 -0700 From: Jack Donahue <[15]demongusta@gmail.com
To: "[17]detomaso@server.detomasolist.com <[18]mailto:detomaso@server.detomasolist.com>" <[19]detomaso@server.detomasolist.com <[20]mailto:detomaso@server.detomasolist.com>> Cc: "[21]detomaso@server.detomasolist.com <[22]mailto:detomaso@server.detomasolist.com>" <[23]detomaso@server.detomasolist.com <[24]mailto:detomaso@server.detomasolist.com>> Subject: [DeTomaso] Fans and shroud Message-ID: <[25]CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com <[26]mailto:CF682A66-9CF9-422E-AD65-2D23A9ABE4BC@gmail.com>> Content-Type: text/plain; charset=utf-8
<[16]mailto:demongusta@gmail.com>> perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
Message: 2 Date: Fri, 16 Sep 2016 16:54:05 +0000 From: "Himes, Terry (397C)" <[27]terry.himes@jpl.nasa.gov <[28]mailto:terry.himes@jpl.nasa.gov>> To: Jack Donahue <[29]demongusta@gmail.com <[30]mailto:demongusta@gmail.com>>, "[31]detomaso@server.detomasolist.com <[32]mailto:detomaso@server.detomasolist.com>" <[33]detomaso@server.detomasolist.com <[34]mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Fans and shroud Message-ID: <[35]D4016E9F.92F3B%thimes@jpl.nasa.gov <[36]mailto:thimes@jpl.nasa.gov>> Content-Type: text/plain; charset="utf-8"
Jack,
Terry
Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [37]thimes@jpl.nasa.gov <[38]mailto:thimes@jpl.nasa.gov><[39]mailto:thimes@jpl.nasa.gov <[40]mailto:thimes@jpl.nasa.gov>> ??
From: DeTomaso <[41]detomaso-bounces@server.detomasolist.com
<[42]mailto:detomaso-bounces@server.detomasolist.com><[43]mailto:detoma so-bounces@server.detomasolist.com
<[44]mailto:detomaso-bounces@server.detomasolist.com>>> on behalf of Jack Donahue <[45]demongusta@gmail.com <[46]mailto:demongusta@gmail.com><[47]mailto:demongusta@gmail.com <[48]mailto:demongusta@gmail.com>>>
Date: Friday, September 16, 2016 9:29 AM To: "[49]detomaso@server.detomasolist.com
<[50]mailto:detomaso@server.detomasolist.com><[51]mailto:detomaso@serve r.detomasolist.com
<[52]mailto:detomaso@server.detomasolist.com>>" <[53]detomaso@server.detomasolist.com
<[54]mailto:detomaso@server.detomasolist.com><[55]mailto:detomaso@serve r.detomasolist.com
<[56]mailto:detomaso@server.detomasolist.com>>>
Cc: "[57]detomaso@server.detomasolist.com
<[58]mailto:detomaso@server.detomasolist.com><[59]mailto:detomaso@serve r.detomasolist.com
<[60]mailto:detomaso@server.detomasolist.com>>" <[61]detomaso@server.detomasolist.com
<[62]mailto:detomaso@server.detomasolist.com><[63]mailto:detomaso@serve r.detomasolist.com
<[64]mailto:detomaso@server.detomasolist.com>>> perfect match for the Pantera radiator size. I think. And someone offered-up a part number, but I deleted (or lost) it. All normal for me.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [65]DeTomaso@server.detomasolist.com
<[68]mailto:DeTomaso@server.detomasolist.com>>
[69]http://server.detomasolist.com/mailman/listinfo/detomaso
<[66]mailto:DeTomaso@server.detomasolist.com><[67]mailto:DeTomaso@serve r.detomasolist.com the
participants (7)
Guido deTomaso
Jerry Knotts
Joseph F. Byrd, Jr.
Owen Cooke
Thomas Törnblom
