Re: [DeTomaso] Sucking power of a Holly electric fuel pump?
I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt
I don't post much but I have a Holly electric on my "P" car and the issue is sucking not pushing. I mounted mine low on the firewall. It is close to the gas tank and it pushes the gas about 50 inches to the Dominator on top of my Cleveland. Have not had any issues with it for the past 7 or 8 years. Hope this helps. From: guson@home.se To: dtpantera@gmail.com Date: Sun, 29 May 2016 23:42:25 -0700 CC: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. I don't post much but I have a Holly electric on my "P" car and the issue is sucking not pushing. I mounted mine low on the firewall. It is close to the gas tank and it pushes the gas about 50 inches to the Dominator on top of my Cleveland. Have not had any issues with it for the past 7 or 8 years. Hope this helps. From: guson@home.se To: dtpantera@gmail.com Date: Sun, 29 May 2016 23:42:25 -0700 CC: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Biggest problem in sucking gas from a Pantera tank is the 21" lift from tank bottom to begin with. Sure- once a flow is established, the natural siphon helps but the initial lift is substantial in all but a full tank. Thats a tall gas tank! Note that all electric pumps both in-tank and external have a fusible link built-in for safety. Exceed the undefined amperage going thru that thin little wire and the fusible link opens resulting in an inoperative, unrepairable pump. Even in an external pump, gas surrounds the field windings etc apparently for cooling. I once used a Holley 'Super-pump' I got at a swap meet as an aquarium circulator. It lasted one week, then the fusible link burned up. I suddenly realized the pumps were not designed for continuous light duty use, either. FWIW- J Deryke -----Original Message----- From: Edward Comber <eds73l@hotmail.com> To: Tomas Gunnarsson <guson@home.se>; dtpantera <dtpantera@gmail.com> Cc: detomaso <detomaso@server.detomasolist.com> Sent: Mon, May 30, 2016 7:18 am Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I don't post much but I have a Holly electric on my "P" car and the issue is sucking not pushing. I mounted mine low on the firewall. It is close to the gas tank and it pushes the gas about 50 inches to the Dominator on top of my Cleveland. Have not had any issues with it for the past 7 or 8 years. Hope this helps. From: guson@home.se To: dtpantera@gmail.com Date: Sun, 29 May 2016 23:42:25 -0700 CC: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. Biggest problem in sucking gas from a Pantera tank is the 21" lift from tank bottom to begin with. Sure- once a flow is established, the natural siphon helps but the initial lift is substantial in all but a full tank. Thats a tall gas tank! Note that all electric pumps both in-tank and external have a fusible link built-in for safety. Exceed the undefined amperage going thru that thin little wire and the fusible link opens resulting in an inoperative, unrepairable pump. Even in an external pump, gas surrounds the field windings etc apparently for cooling. I once used a Holley 'Super-pump' I got at a swap meet as an aquarium circulator. It lasted one week, then the fusible link burned up. I suddenly realized the pumps were not designed for continuous light duty use, either. FWIW- J Deryke -----Original Message----- From: Edward Comber <eds73l@hotmail.com> To: Tomas Gunnarsson <guson@home.se>; dtpantera <dtpantera@gmail.com> Cc: detomaso <detomaso@server.detomasolist.com> Sent: Mon, May 30, 2016 7:18 am Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I don't post much but I have a Holly electric on my "P" car and the issue is sucking not pushing. I mounted mine low on the firewall. It is close to the gas tank and it pushes the gas about 50 inches to the Dominator on top of my Cleveland. Have not had any issues with it for the past 7 or 8 years. Hope this helps. From: [1]guson@home.se To: [2]dtpantera@gmail.com Date: Sun, 29 May 2016 23:42:25 -0700 CC: [3]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Sucking power of a Holly electric fuel pump? I'm convinced that you can and if not, just fill up the tank with new gas and you'll only have to pull a few inches. Tomas <-----Ursprungligt Meddelande-----> From: Don Thomas [[4]dtpantera@gmail.com] Sent: 30/5/2016 4:13:29 AM To: [5]detomaso@server.detomasolist.com Subject: [DeTomaso] Sucking power of a Holly electric fuel pump? What's the sucking power of an Electric fuel pump ? Do you think I can pull 29 inches with a Holley Electric Fuel Pump ? I'm just wondering if I drain all my gas out of the tank with the electric fuel pump... and then add new gas... if I am going to be SOL ... and have to re-prime the fuel lines? I don't think so... but then again.. I have no idea. Anyone have experience with priming the gas? Thank in advance. -dt _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [6]DeTomaso@server.detomasolist.com [7]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [8]DeTomaso@server.detomasolist.com [9]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:guson@home.se 2. mailto:dtpantera@gmail.com 3. mailto:detomaso@server.detomasolist.com 4. mailto:dtpantera@gmail.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:DeTomaso@server.detomasolist.com 7. http://server.detomasolist.com/mailman/listinfo/detomaso 8. mailto:DeTomaso@server.detomasolist.com 9. http://server.detomasolist.com/mailman/listinfo/detomaso
Edward Comber
jderyke@aol.com
Tomas Gunnarsson
