Re: [DeTomaso] Which axles on which side?
On May 20, 2016, at 4:38 PM, Julian Kift <[15]julian_kift@hotmail.com[16]<mailto:julian_kift@hotmail.com>> wrote:
The axle nut is on there at 450 ft/lb but it is only keeping the axle tight in the inner race of the wheel bearings, rotational freedom being within the bearings and even though you are braking hard the axle is still rotating in a forward direction, plus the axle inner flange/half shaft is splined to the axle shaft and most of us do let of the gas when we brake!
Julian ________________________________________ From: marshall smith <[17]marshallgsmith@sbcglobal.net[18]<mailto:marshallgsmith@sbcglobal.ne t>> Sent: Friday, May 20, 2016 1:16 PM To: Douglas Kelm; 'Mike Drew'; [19]detomaso@detomasolist.com[20]<mailto:detomaso@detomasolist.com>; Julian Kift Subject: Re: [DeTomaso] Which axles on which side?
Okay...really dumb question here. Wouldn't hard braking want to loosen the axle nut??
M -------------------------------------------- On Fri, 5/20/16, Julian Kift <[21]julian_kift@hotmail.com[22]<mailto:julian_kift@hotmail.com>> wrote:
Subject: Re: [DeTomaso] Which axles on which side? To: "Douglas Kelm" <[23]dakelm@qwest.net[24]<mailto:dakelm@qwest.net>>, "'Mike Drew'" <[25]MikeLDrew@aol.com[26]<mailto:MikeLDrew@aol.com>>, "[27]detomaso@detomasolist.com[28]<mailto:detomaso@detomasolist.com>" <[29]detomaso@detomasolist.com[30]<mailto:detomaso@detomasolist.com>> Date: Friday, May 20, 2016, 1:12 PM
Doug,
Remember the axle nut is on the inside of the wheel in this case, if it were RH then the counter clockwise motion of the axle would want to undo it!
Julian
________________________________________ From: DeTomaso <[31]detomaso-bounces@server.detomasolist.com[32]<mailto:detomaso-bounce s@ser ve r.detomasolist.com>> on behalf of Douglas Kelm <[33]dakelm@qwest.net[34]<mailto:dakelm@qwest.net
Sent: Friday, May 20, 2016 12:52 PM To: 'Mike Drew'; [35]detomaso@detomasolist.com[36]<mailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side?
I would think that the "righty tighty" threads (normal) go on the left side of the vehicle. Think of the nut being stationary while the axle (on the drivers side) rotates counter clockwise (looking from outside the car), meaning the nut wants to self tighten (rotate clockwise), which is the desired situation. Of course, there's a 50/50 chance that I'm completely full of "it"!
Doug
-----Original Message----- From: DeTomaso [[37]mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, May 20, 2016 12:34 PM To: [38]detomaso@detomasolist.com[39]<mailto:detomaso@detomasolist.com> Subject: [DeTomaso] Which axles on which side?
Hi guys,
I thought I would lead off with he first technical question on the new forum.
The rear axles are marked S and D, for 'left' and 'right' respectively. But that speaks to the thread direction (one of them is reverse thread, left to tighten)
It's my belief that the S or left-tighten axle goes on the left side of the car but I can't remember for sure. Can somebody confirm or deny?
Thanks!
And welcome back!
Sent from my iPhone _______________________________________________
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [40]DeTomaso@server.detomasolist.com[41]<mailto:DeTomaso@server.detomaso
Sorry for giving you a headache Asa Jay! :-) It's actually as simple as (cross section area) multiplied by (force per area unit). Tomas <-----Ursprungligt Meddelande-----> From: Asa Jay Laughton [asajay@asajay.com] Sent: 22/5/2016 10:41:34 PM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, Please take the following comment as a deep respect for your depth of knowledge as I have never professed to be a learned engineer. Dang man you can make my head hurt. ;) I truly admire the smart folks we have out there. Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** [1]http://w7tsc.org [2]http://www.teampanteraracing.com On 5/22/2016 7:28 AM, Tomas Gunnarsson wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[3]lplugw@hotmail.com] Sent: 22/5/2016 2:15:10 AM To: [4]guson@home.se Cc: [5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <[6]guson@home.se[7]<mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[8]lplugw@hotmail.com[9]<mailto:lplugw@hotmail.com>] Sent: 20/5/2016 10:49:42 PM To: [10]julian_kift@hotmail.com[11]<mailto:julian_kift@hotmail.com> Cc: [12]MikeLDrew@aol.com[13]<mailto:MikeLDrew@aol.com>;detomaso@detomasolis t.com [14]<m ailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone list. co m>
[42]http://server.detomasolist.com/mailman/listinfo/detomaso
[43]DeTomaso@server.detomasolist.com[44]<mailto:DeTomaso@server.detomaso list. co m>
[45]http://server.detomasolist.com/mailman/listinfo/detomaso
To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________
[46]DeTomaso@server.detomasolist.com[47]<mailto:DeTomaso@server.detomaso list. co m>
[48]http://server.detomasolist.com/mailman/listinfo/detomaso
[49]DeTomaso@server.detomasolist.com[50]<mailto:DeTomaso@server.detomaso list. co m>
[51]http://server.detomasolist.com/mailman/listinfo/detomaso
Julian ________________________________________ From: marshall smith <[17]marshallgsmith@sbcglobal.net[18]<mailto:marshallgsmith@sbcglobal.n et>> Sent: Friday, May 20, 2016 1:16 PM To: Douglas Kelm; 'Mike Drew'; [19]detomaso@detomasolist.com[20]<mailto:detomaso@detomasolist.com>; Julian Kift Subject: Re: [DeTomaso] Which axles on which side?
Doug,
Julian
________________________________________ From: DeTomaso <[31]detomaso-bounces@server.detomasolist.com[32]<mailto:detomaso-bounc es@ser ve r.detomasolist.com>> on behalf of Douglas Kelm <[33]dakelm@qwest.net[34]<mailto:dakelm@qwest.net
Doug
Hi guys,
Thanks!
And welcome back!
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [52]DeTomaso@server.detomasolist.com[53]<mailto:DeTomaso@server.detomaso list. co m> [54]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [55]DeTomaso@server.detomasolist.com [56]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. ----- No virus found in this message. Checked by AVG - [57]www.avg.com Version: 2016.0.7597 / Virus Database: 4568/12278 - Release Date: 05/22/16 References 1. http://w7tsc.org/ 2. http://www.teampanteraracing.com/ 3. mailto:lplugw@hotmail.com 4. mailto:guson@home.se 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guson@home.se 8. mailto:lplugw@hotmail.com 9. mailto:lplugw@hotmail.com 10. mailto:julian_kift@hotmail.com 11. mailto:julian_kift@hotmail.com 12. mailto:MikeLDrew@aol.com 13. mailto:MikeLDrew@aol.com 14. mailto:detomaso@detomasolist.com 15. mailto:julian_kift@hotmail.com 16. mailto:julian_kift@hotmail.com 17. mailto:marshallgsmith@sbcglobal.net 18. mailto:marshallgsmith@sbcglobal.net 19. mailto:detomaso@detomasolist.com 20. mailto:detomaso@detomasolist.com 21. mailto:julian_kift@hotmail.com 22. mailto:julian_kift@hotmail.com 23. mailto:dakelm@qwest.net 24. mailto:dakelm@qwest.net 25. mailto:MikeLDrew@aol.com 26. mailto:MikeLDrew@aol.com 27. mailto:detomaso@detomasolist.com 28. mailto:detomaso@detomasolist.com 29. mailto:detomaso@detomasolist.com 30. mailto:detomaso@detomasolist.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso-bounces@server.detomasolist.com 33. mailto:dakelm@qwest.net 34. mailto:dakelm@qwest.net 35. mailto:detomaso@detomasolist.com 36. mailto:detomaso@detomasolist.com 37. mailto:detomaso-bounces@server.detomasolist.com 38. mailto:detomaso@detomasolist.com 39. mailto:detomaso@detomasolist.com 40. mailto:DeTomaso@server.detomasolist.com 41. mailto:DeTomaso@server.detomasolist.com 42. http://server.detomasolist.com/mailman/listinfo/detomaso 43. mailto:DeTomaso@server.detomasolist.com 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:DeTomaso@server.detomasolist.com 47. mailto:DeTomaso@server.detomasolist.com 48. http://server.detomasolist.com/mailman/listinfo/detomaso 49. mailto:DeTomaso@server.detomasolist.com 50. mailto:DeTomaso@server.detomasolist.com 51. http://server.detomasolist.com/mailman/listinfo/detomaso 52. mailto:DeTomaso@server.detomasolist.com 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. http://www.avg.com/ _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. . Sorry for giving you a headache Asa Jay! :-) It's actually as simple as (cross section area) multiplied by (force per area unit). Tomas <-----Ursprungligt Meddelande-----> From: Asa Jay Laughton [asajay@asajay.com] Sent: 22/5/2016 10:41:34 PM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, Please take the following comment as a deep respect for your depth of knowledge as I have never professed to be a learned engineer. Dang man you can make my head hurt. ;) I truly admire the smart folks we have out there. Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** [1]http://w7tsc.org [2]http://www.teampanteraracing.com On 5/22/2016 7:28 AM, Tomas Gunnarsson wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[3]lplugw@hotmail.com] Sent: 22/5/2016 2:15:10 AM To: [4]guson@home.se Cc: [5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <[6]guson@home.se[7]<mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[8]lplugw@hotmail.com[9]<mailto:lplugw@hotmail.com>] Sent: 20/5/2016 10:49:42 PM To: [10]julian_kift@hotmail.com[11]<mailto:julian_kift@hotmail.com> Cc: [12]MikeLDrew@aol.com[13]<mailto:MikeLDrew@aol.com>;detomaso@detomasoli st.com [14]<m ailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone olist. co m>
[43]DeTomaso@server.detomasolist.com[44]<mailto:DeTomaso@server.detomas olist. co m>
[46]DeTomaso@server.detomasolist.com[47]<mailto:DeTomaso@server.detomas olist. co m>
[49]DeTomaso@server.detomasolist.com[50]<mailto:DeTomaso@server.detomas olist. co m>
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [52]DeTomaso@server.detomasolist.com[53]<mailto:DeTomaso@server.detomas olist. co m> [54]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [55]DeTomaso@server.detomasolist.com [56]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. ----- No virus found in this message. Checked by AVG - [57]www.avg.com Version: 2016.0.7597 / Virus Database: 4568/12278 - Release Date: 05/22/16 References 1. http://w7tsc.org/ 2. http://www.teampanteraracing.com/ 3. mailto:lplugw@hotmail.com 4. mailto:guson@home.se 5. mailto:detomaso@detomasolist.com 6. mailto:guson@home.se 7. mailto:guson@home.se 8. mailto:lplugw@hotmail.com 9. mailto:lplugw@hotmail.com 10. mailto:julian_kift@hotmail.com 11. mailto:julian_kift@hotmail.com 12. mailto:MikeLDrew@aol.com 13. mailto:MikeLDrew@aol.com 14. mailto:detomaso@detomasolist.com 15. mailto:julian_kift@hotmail.com 16. mailto:julian_kift@hotmail.com 17. mailto:marshallgsmith@sbcglobal.net 18. mailto:marshallgsmith@sbcglobal.net 19. mailto:detomaso@detomasolist.com 20. mailto:detomaso@detomasolist.com 21. mailto:julian_kift@hotmail.com 22. mailto:julian_kift@hotmail.com 23. mailto:dakelm@qwest.net 24. mailto:dakelm@qwest.net 25. mailto:MikeLDrew@aol.com 26. mailto:MikeLDrew@aol.com 27. mailto:detomaso@detomasolist.com 28. mailto:detomaso@detomasolist.com 29. mailto:detomaso@detomasolist.com 30. mailto:detomaso@detomasolist.com 31. mailto:detomaso-bounces@server.detomasolist.com 32. mailto:detomaso-bounces@server.detomasolist.com 33. mailto:dakelm@qwest.net 34. mailto:dakelm@qwest.net 35. mailto:detomaso@detomasolist.com 36. mailto:detomaso@detomasolist.com 37. mailto:detomaso-bounces@server.detomasolist.com 38. mailto:detomaso@detomasolist.com 39. mailto:detomaso@detomasolist.com 40. mailto:DeTomaso@server.detomasolist.com 41. mailto:DeTomaso@server.detomasolist.com 42. http://server.detomasolist.com/mailman/listinfo/detomaso 43. mailto:DeTomaso@server.detomasolist.com 44. mailto:DeTomaso@server.detomasolist.com 45. http://server.detomasolist.com/mailman/listinfo/detomaso 46. mailto:DeTomaso@server.detomasolist.com 47. mailto:DeTomaso@server.detomasolist.com 48. http://server.detomasolist.com/mailman/listinfo/detomaso 49. mailto:DeTomaso@server.detomasolist.com 50. mailto:DeTomaso@server.detomasolist.com 51. http://server.detomasolist.com/mailman/listinfo/detomaso 52. mailto:DeTomaso@server.detomasolist.com 53. mailto:DeTomaso@server.detomasolist.com 54. http://server.detomasolist.com/mailman/listinfo/detomaso 55. mailto:DeTomaso@server.detomasolist.com 56. http://server.detomasolist.com/mailman/listinfo/detomaso 57. http://www.avg.com/ _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. .
Oh, well... that's explains it then. ;) Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** [1]http://w7tsc.org [2]http://www.teampanteraracing.com On 5/22/2016 11:51 PM, Tomas Gunnarsson wrote: Sorry for giving you a headache Asa Jay! :-) It's actually as simple as (cross section area) multiplied by (force per area unit). Tomas <-----Ursprungligt Meddelande-----> From: Asa Jay Laughton [[3]asajay@asajay.com] Sent: 22/5/2016 10:41:34 PM To: [4]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, Please take the following comment as a deep respect for your depth of knowledge as I have never professed to be a learned engineer. Dang man you can make my head hurt. ;) I truly admire the smart folks we have out there. Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** [1][5]http://w7tsc.org [2][6]http://www.teampanteraracing.com On 5/22/2016 7:28 AM, Tomas Gunnarsson wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[[7]3]lplugw@hotmail.com] Sent: 22/5/2016 2:15:10 AM To: [[8]4]guson@home.se Cc: [[9]5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <[[10]6]guson@home.se[7][11]<mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[[12]8]lplugw@hotmail.com[9][13]<mailto:lplugw@hotmail.com>] Sent: 20/5/2016 10:49:42 PM To: [[14]10]julian_kift@hotmail.com[11][15]<mailto:julian_kift@hotmail.com> Cc: [[16]12]MikeLDrew@aol.com[13][17]<mailto:MikeLDrew@aol.com>;detomaso@de tomasolist.com [14]<m [18]ailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone
On May 20, 2016, at 4:38 PM, Julian Kift <[[19]15]julian_kift@hotmail.com[16][20]<mailto:julian_kift@hotmail.com
Julian ________________________________________ From: marshall smith <[[21]17]marshallgsmith@sbcglobal.net[18][22]<mailto:marshallgsmith@sbc global.net>> Sent: Friday, May 20, 2016 1:16 PM To: Douglas Kelm; 'Mike Drew'; [[23]19]detomaso@detomasolist.com[20][24]<mailto:detomaso@detomasolist. com>; Julian Kift Subject: Re: [DeTomaso] Which axles on which side?
M -------------------------------------------- On Fri, 5/20/16, Julian Kift <[[25]21]julian_kift@hotmail.com[22][26]<mailto:julian_kift@hotmail.com
wrote:
Subject: Re: [DeTomaso] Which axles on which side? To: "Douglas Kelm" <[[27]23]dakelm@qwest.net[24][28]<mailto:dakelm@qwest.net>>, "'Mike Drew'" <[[29]25]MikeLDrew@aol.com[26][30]<mailto:MikeLDrew@aol.com>>, "[[31]27]detomaso@detomasolist.com[28][32]<mailto:detomaso@detomasolist .com>" <[[33]29]detomaso@detomasolist.com[30][34]<mailto:detomaso@detomasolist .com>> Date: Friday, May 20, 2016, 1:12 PM
Doug,
Julian
________________________________________ From: DeTomaso <[[35]31]detomaso-bounces@server.detomasolist.com[32]<[36]mailto:detoma so-bounces@ser ve r.detomasolist.com>> on behalf of Douglas Kelm <[[37]33]dakelm@qwest.net[34]<[38]mailto:dakelm@qwest.net
Sent: Friday, May 20, 2016 12:52 PM To: 'Mike Drew'; [[39]35]detomaso@detomasolist.com[36][40]<mailto:detomaso@detomasolist. com> Subject: Re: [DeTomaso] Which axles on which side?
Doug
-----Original Message----- From: DeTomaso [[37][41]mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, May 20, 2016 12:34 PM To: [[42]38]detomaso@detomasolist.com[39][43]<mailto:detomaso@detomasolist. com> Subject: [DeTomaso] Which axles on which side?
Hi guys,
Thanks!
And welcome back!
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[44]40]DeTomaso@server.detomasolist.com[41]<[45]mailto:DeTomaso@server .detomasolist. co m> [42][46]http://server.detomasolist.com/mailman/listinfo/detomaso
[[47]43]DeTomaso@server.detomasolist.com[44]<[48]mailto:DeTomaso@server .detomasolist. co m>
[45][49]http://server.detomasolist.com/mailman/listinfo/detomaso
[[50]46]DeTomaso@server.detomasolist.com[47]<[51]mailto:DeTomaso@server .detomasolist. co m>
[48][52]http://server.detomasolist.com/mailman/listinfo/detomaso
[[53]49]DeTomaso@server.detomasolist.com[50]<[54]mailto:DeTomaso@server .detomasolist. co m>
[51][55]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[56]52]DeTomaso@server.detomasolist.com[53]<[57]mailto:DeTomaso@server .detomasolist. co m> [54][58]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[59]55]DeTomaso@server.detomasolist.com [56][60]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. ----- No virus found in this message. Checked by AVG - [57]www.avg.com Version: 2016.0.7597 / Virus Database: 4568/12278 - Release Date: 05/22/16 References 1. [61]http://w7tsc.org/ 2. [62]http://www.teampanteraracing.com/ 3. [63]mailto:lplugw@hotmail.com 4. [64]mailto:guson@home.se 5. [65]mailto:detomaso@detomasolist.com 6. [66]mailto:guson@home.se 7. [67]mailto:guson@home.se 8. [68]mailto:lplugw@hotmail.com 9. [69]mailto:lplugw@hotmail.com 10. [70]mailto:julian_kift@hotmail.com 11. [71]mailto:julian_kift@hotmail.com 12. [72]mailto:MikeLDrew@aol.com 13. [73]mailto:MikeLDrew@aol.com 14. [74]mailto:detomaso@detomasolist.com 15. [75]mailto:julian_kift@hotmail.com 16. [76]mailto:julian_kift@hotmail.com 17. [77]mailto:marshallgsmith@sbcglobal.net 18. [78]mailto:marshallgsmith@sbcglobal.net 19. [79]mailto:detomaso@detomasolist.com 20. [80]mailto:detomaso@detomasolist.com 21. [81]mailto:julian_kift@hotmail.com 22. [82]mailto:julian_kift@hotmail.com 23. [83]mailto:dakelm@qwest.net 24. [84]mailto:dakelm@qwest.net 25. [85]mailto:MikeLDrew@aol.com 26. [86]mailto:MikeLDrew@aol.com 27. [87]mailto:detomaso@detomasolist.com 28. [88]mailto:detomaso@detomasolist.com 29. [89]mailto:detomaso@detomasolist.com 30. [90]mailto:detomaso@detomasolist.com 31. [91]mailto:detomaso-bounces@server.detomasolist.com 32. [92]mailto:detomaso-bounces@server.detomasolist.com 33. [93]mailto:dakelm@qwest.net 34. [94]mailto:dakelm@qwest.net 35. [95]mailto:detomaso@detomasolist.com 36. [96]mailto:detomaso@detomasolist.com 37. [97]mailto:detomaso-bounces@server.detomasolist.com 38. [98]mailto:detomaso@detomasolist.com 39. [99]mailto:detomaso@detomasolist.com 40. [100]mailto:DeTomaso@server.detomasolist.com 41. [101]mailto:DeTomaso@server.detomasolist.com 42. [102]http://server.detomasolist.com/mailman/listinfo/detomaso 43. [103]mailto:DeTomaso@server.detomasolist.com 44. [104]mailto:DeTomaso@server.detomasolist.com 45. [105]http://server.detomasolist.com/mailman/listinfo/detomaso 46. [106]mailto:DeTomaso@server.detomasolist.com 47. [107]mailto:DeTomaso@server.detomasolist.com 48. [108]http://server.detomasolist.com/mailman/listinfo/detomaso 49. [109]mailto:DeTomaso@server.detomasolist.com 50. [110]mailto:DeTomaso@server.detomasolist.com 51. [111]http://server.detomasolist.com/mailman/listinfo/detomaso 52. [112]mailto:DeTomaso@server.detomasolist.com 53. [113]mailto:DeTomaso@server.detomasolist.com 54. [114]http://server.detomasolist.com/mailman/listinfo/detomaso 55. [115]mailto:DeTomaso@server.detomasolist.com 56. [116]http://server.detomasolist.com/mailman/listinfo/detomaso 57. [117]http://www.avg.com/ _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [118]DeTomaso@server.detomasolist.com [119]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. . No virus found in this message. Checked by AVG - [120]www.avg.com Version: 2016.0.7597 / Virus Database: 4568/12280 - Release Date: 05/22/16 References 1. http://w7tsc.org/ 2. http://www.teampanteraracing.com/ 3. mailto:asajay@asajay.com 4. mailto:detomaso@server.detomasolist.com 5. http://w7tsc.org/ 6. http://www.teampanteraracing.com/ 7. mailto:3]lplugw@hotmail.com 8. mailto:4]guson@home.se 9. mailto:5]detomaso@detomasolist.com 10. mailto:6]guson@home.se 11. mailto:guson@home.se 12. mailto:8]lplugw@hotmail.com 13. mailto:lplugw@hotmail.com 14. mailto:10]julian_kift@hotmail.com 15. mailto:julian_kift@hotmail.com 16. mailto:12]MikeLDrew@aol.com 17. mailto:MikeLDrew@aol.com 18. mailto:ailto:detomaso@detomasolist.com 19. mailto:15]julian_kift@hotmail.com 20. mailto:julian_kift@hotmail.com 21. mailto:17]marshallgsmith@sbcglobal.net 22. mailto:marshallgsmith@sbcglobal.net 23. mailto:19]detomaso@detomasolist.com 24. mailto:detomaso@detomasolist.com 25. mailto:21]julian_kift@hotmail.com 26. mailto:julian_kift@hotmail.com 27. mailto:23]dakelm@qwest.net 28. mailto:dakelm@qwest.net 29. mailto:25]MikeLDrew@aol.com 30. mailto:MikeLDrew@aol.com 31. mailto:27]detomaso@detomasolist.com 32. mailto:detomaso@detomasolist.com 33. mailto:29]detomaso@detomasolist.com 34. mailto:detomaso@detomasolist.com 35. mailto:31]detomaso-bounces@server.detomasolist.com 36. mailto:detomaso-bounces@ser 37. mailto:33]dakelm@qwest.net 38. mailto:dakelm@qwest.net 39. mailto:35]detomaso@detomasolist.com 40. mailto:detomaso@detomasolist.com 41. mailto:detomaso-bounces@server.detomasolist.com 42. mailto:38]detomaso@detomasolist.com 43. mailto:detomaso@detomasolist.com 44. mailto:40]DeTomaso@server.detomasolist.com 45. mailto:DeTomaso@server.detomasolist 46. http://server.detomasolist.com/mailman/listinfo/detomaso 47. mailto:43]DeTomaso@server.detomasolist.com 48. mailto:DeTomaso@server.detomasolist 49. http://server.detomasolist.com/mailman/listinfo/detomaso 50. mailto:46]DeTomaso@server.detomasolist.com 51. mailto:DeTomaso@server.detomasolist 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:49]DeTomaso@server.detomasolist.com 54. mailto:DeTomaso@server.detomasolist 55. http://server.detomasolist.com/mailman/listinfo/detomaso 56. mailto:52]DeTomaso@server.detomasolist.com 57. mailto:DeTomaso@server.detomasolist 58. http://server.detomasolist.com/mailman/listinfo/detomaso 59. mailto:55]DeTomaso@server.detomasolist.com 60. http://server.detomasolist.com/mailman/listinfo/detomaso 61. http://w7tsc.org/ 62. http://www.teampanteraracing.com/ 63. mailto:lplugw@hotmail.com 64. mailto:guson@home.se 65. mailto:detomaso@detomasolist.com 66. mailto:guson@home.se 67. mailto:guson@home.se 68. mailto:lplugw@hotmail.com 69. mailto:lplugw@hotmail.com 70. mailto:julian_kift@hotmail.com 71. mailto:julian_kift@hotmail.com 72. mailto:MikeLDrew@aol.com 73. mailto:MikeLDrew@aol.com 74. mailto:detomaso@detomasolist.com 75. mailto:julian_kift@hotmail.com 76. mailto:julian_kift@hotmail.com 77. mailto:marshallgsmith@sbcglobal.net 78. mailto:marshallgsmith@sbcglobal.net 79. mailto:detomaso@detomasolist.com 80. mailto:detomaso@detomasolist.com 81. mailto:julian_kift@hotmail.com 82. mailto:julian_kift@hotmail.com 83. mailto:dakelm@qwest.net 84. mailto:dakelm@qwest.net 85. mailto:MikeLDrew@aol.com 86. mailto:MikeLDrew@aol.com 87. mailto:detomaso@detomasolist.com 88. mailto:detomaso@detomasolist.com 89. mailto:detomaso@detomasolist.com 90. mailto:detomaso@detomasolist.com 91. mailto:detomaso-bounces@server.detomasolist.com 92. mailto:detomaso-bounces@server.detomasolist.com 93. mailto:dakelm@qwest.net 94. mailto:dakelm@qwest.net 95. mailto:detomaso@detomasolist.com 96. mailto:detomaso@detomasolist.com 97. mailto:detomaso-bounces@server.detomasolist.com 98. mailto:detomaso@detomasolist.com 99. mailto:detomaso@detomasolist.com 100. mailto:DeTomaso@server.detomasolist.com 101. mailto:DeTomaso@server.detomasolist.com 102. http://server.detomasolist.com/mailman/listinfo/detomaso 103. mailto:DeTomaso@server.detomasolist.com 104. mailto:DeTomaso@server.detomasolist.com 105. http://server.detomasolist.com/mailman/listinfo/detomaso 106. mailto:DeTomaso@server.detomasolist.com 107. mailto:DeTomaso@server.detomasolist.com 108. http://server.detomasolist.com/mailman/listinfo/detomaso 109. mailto:DeTomaso@server.detomasolist.com 110. mailto:DeTomaso@server.detomasolist.com 111. http://server.detomasolist.com/mailman/listinfo/detomaso 112. mailto:DeTomaso@server.detomasolist.com 113. mailto:DeTomaso@server.detomasolist.com 114. http://server.detomasolist.com/mailman/listinfo/detomaso 115. mailto:DeTomaso@server.detomasolist.com 116. http://server.detomasolist.com/mailman/listinfo/detomaso 117. http://www.avg.com/ 118. mailto:DeTomaso@server.detomasolist.com 119. http://server.detomasolist.com/mailman/listinfo/detomaso 120. http://www.avg.com/
From: Asa Jay Laughton [[3]asajay@asajay.com] Sent: 22/5/2016 10:41:34 PM To: [4]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Tomas, Please take the following comment as a deep respect for your depth of knowledge as I have never professed to be a learned engineer. Dang man you can make my head hurt. ;) I truly admire the smart folks we have out there. Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** [1][5]http://w7tsc.org [2][6]http://www.teampanteraracing.com On 5/22/2016 7:28 AM, Tomas Gunnarsson wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[[7]3]lplugw@hotmail.com] Sent: 22/5/2016 2:15:10 AM To: [[8]4]guson@home.se Cc: [[9]5]detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <[[10]6]guson@home.se[7][11]<mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [[[12]8]lplugw@hotmail.com[9][13]<mailto:lplugw@hotmail.com>] Sent: 20/5/2016 10:49:42 PM To: [[14]10]julian_kift@hotmail.com[11][15]<mailto:julian_kift@hotmail.com> Cc: [[16]12]MikeLDrew@aol.com[13][17]<mailto:MikeLDrew@aol.com>;detomaso@de tomasolist.com [14]<m [18]ailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone > On May 20, 2016, at 4:38 PM, Julian Kift <[[19]15]julian_kift@hotmail.com[16][20]<mailto:julian_kift@hotmail.com >> wrote: > > The axle nut is on there at 450 ft/lb but it is only keeping the axle tight in the inner race of the wheel bearings, rotational freedom being within the bearings and even though you are braking hard the axle is still rotating in a forward direction, plus the axle inner flange/half shaft is splined to the axle shaft and most of us do let of the gas when we brake! > > Julian > ________________________________________ > From: marshall smith <[[21]17]marshallgsmith@sbcglobal.net[18][22]<mailto:marshallgsmith@sbc global.net>> > Sent: Friday, May 20, 2016 1:16 PM > To: Douglas Kelm; 'Mike Drew'; [[23]19]detomaso@detomasolist.com[20][24]<mailto:detomaso@detomasolist. com>; Julian Kift > Subject: Re: [DeTomaso] Which axles on which side? > > Okay...really dumb question here. Wouldn't hard braking want to loosen the axle nut?? > > M > -------------------------------------------- > On Fri, 5/20/16, Julian Kift <[[25]21]julian_kift@hotmail.com[22][26]<mailto:julian_kift@hotmail.com >> wrote: > > Subject: Re: [DeTomaso] Which axles on which side? > To: "Douglas Kelm" <[[27]23]dakelm@qwest.net[24][28]<mailto:dakelm@qwest.net>>, "'Mike Drew'" <[[29]25]MikeLDrew@aol.com[26][30]<mailto:MikeLDrew@aol.com>>, "[[31]27]detomaso@detomasolist.com[28][32]<mailto:detomaso@detomasolist .com>" <[[33]29]detomaso@detomasolist.com[30][34]<mailto:detomaso@detomasolist .com>> > Date: Friday, May 20, 2016, 1:12 PM > > Doug, > > Remember the axle nut is on the inside of the > wheel in this case, if it were RH then the counter clockwise > motion of the axle would want to undo it! > > Julian > > ________________________________________ > From: DeTomaso <[[35]31]detomaso-bounces@server.detomasolist.com[32]<[36]mailto:detoma so-bounces@ser ve r.detomasolist.com>> > on behalf of Douglas Kelm <[[37]33]dakelm@qwest.net[34]<[38]mailto:dakelm@qwest.net >> > Sent: Friday, May 20, 2016 12:52 PM > To: 'Mike Drew'; [[39]35]detomaso@detomasolist.com[36][40]<mailto:detomaso@detomasolist. com> > Subject: Re: [DeTomaso] Which axles on which > side? > > I would think that > the "righty tighty" threads (normal) go on the > left side > of the vehicle. Think of the nut > being stationary while the axle (on the > drivers side) rotates counter clockwise > (looking from outside the car), > meaning the > nut wants to self tighten (rotate clockwise), which is > the > desired situation. Of course, > there's a 50/50 chance that I'm completely > full of "it"! > > Doug > > -----Original Message----- > From: DeTomaso [[37][41]mailto:detomaso-bounces@server.detomasolist.com] > On Behalf > Of Mike Drew via DeTomaso > Sent: Friday, May 20, 2016 12:34 PM > To: [[42]38]detomaso@detomasolist.com[39][43]<mailto:detomaso@detomasolist. com> > Subject: [DeTomaso] Which axles on which > side? > > Hi guys, > > I thought I would lead off > with he first technical question on the new > forum. > > The > rear axles are marked S and D, for 'left' and > 'right' respectively. But > that > speaks to the thread direction (one of them is reverse > thread, left to > tighten) > > It's my belief that the S or left-tighten > axle goes on the left side of the > car but I > can't remember for sure. Can somebody confirm or > deny? > > Thanks! > > And welcome back! > > Mike > > Sent from my iPhone > _______________________________________________ > > Detomaso Forum NO LONGER > Managed by POCA Posted emails must not exceed 1.5 > Megabytes DeTomaso mailing list [[44]40]DeTomaso@server.detomasolist.com[41]<[45]mailto:DeTomaso@server .detomasolist. co m> > [42][46]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription > (change email address, unsubscribe, etc.) use > the links above. > > _______________________________________________ > > Detomaso Forum NO LONGER > Managed by POCA > Posted emails must not > exceed 1.5 Megabytes > DeTomaso mailing > list > [[47]43]DeTomaso@server.detomasolist.com[44]<[48]mailto:DeTomaso@server .detomasolist. co m> > [45][49]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription > (change email address, unsubscribe, etc.) use the links > above. > _______________________________________________ > > Detomaso Forum NO LONGER > Managed by POCA > Posted emails must not > exceed 1.5 Megabytes > DeTomaso mailing > list > [[50]46]DeTomaso@server.detomasolist.com[47]<[51]mailto:DeTomaso@server .detomasolist. co m> > [48][52]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription > (change email address, unsubscribe, etc.) use the links > above. > _______________________________________________ > > Detomaso Forum NO LONGER Managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > [[53]49]DeTomaso@server.detomasolist.com[50]<[54]mailto:DeTomaso@server .detomasolist. co m> > [51][55]http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[56]52]DeTomaso@server.detomasolist.com[53]<[57]mailto:DeTomaso@server .detomasolist. co m> [54][58]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [[59]55]DeTomaso@server.detomasolist.com [56][60]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. ----- No virus found in this message. Checked by AVG - [57]www.avg.com Version: 2016.0.7597 / Virus Database: 4568/12278 - Release Date: 05/22/16 References 1. [61]http://w7tsc.org/ 2. [62]http://www.teampanteraracing.com/ 3. [63]mailto:lplugw@hotmail.com 4. [64]mailto:guson@home.se 5. [65]mailto:detomaso@detomasolist.com 6. [66]mailto:guson@home.se 7. [67]mailto:guson@home.se 8. [68]mailto:lplugw@hotmail.com 9. [69]mailto:lplugw@hotmail.com 10. [70]mailto:julian_kift@hotmail.com 11. [71]mailto:julian_kift@hotmail.com 12. [72]mailto:MikeLDrew@aol.com 13. [73]mailto:MikeLDrew@aol.com 14. [74]mailto:detomaso@detomasolist.com 15. [75]mailto:julian_kift@hotmail.com 16. [76]mailto:julian_kift@hotmail.com 17. [77]mailto:marshallgsmith@sbcglobal.net 18. [78]mailto:marshallgsmith@sbcglobal.net 19. [79]mailto:detomaso@detomasolist.com 20. [80]mailto:detomaso@detomasolist.com 21. [81]mailto:julian_kift@hotmail.com 22. [82]mailto:julian_kift@hotmail.com 23. [83]mailto:dakelm@qwest.net 24. [84]mailto:dakelm@qwest.net 25. [85]mailto:MikeLDrew@aol.com 26. [86]mailto:MikeLDrew@aol.com 27. [87]mailto:detomaso@detomasolist.com 28. [88]mailto:detomaso@detomasolist.com 29. [89]mailto:detomaso@detomasolist.com 30. [90]mailto:detomaso@detomasolist.com 31. [91]mailto:detomaso-bounces@server.detomasolist.com 32. [92]mailto:detomaso-bounces@server.detomasolist.com 33. [93]mailto:dakelm@qwest.net 34. [94]mailto:dakelm@qwest.net 35. [95]mailto:detomaso@detomasolist.com 36. [96]mailto:detomaso@detomasolist.com 37. [97]mailto:detomaso-bounces@server.detomasolist.com 38. [98]mailto:detomaso@detomasolist.com 39. [99]mailto:detomaso@detomasolist.com 40. [100]mailto:DeTomaso@server.detomasolist.com 41. [101]mailto:DeTomaso@server.detomasolist.com 42. [102]http://server.detomasolist.com/mailman/listinfo/detomaso 43. [103]mailto:DeTomaso@server.detomasolist.com 44. [104]mailto:DeTomaso@server.detomasolist.com 45. [105]http://server.detomasolist.com/mailman/listinfo/detomaso 46. [106]mailto:DeTomaso@server.detomasolist.com 47. [107]mailto:DeTomaso@server.detomasolist.com 48. [108]http://server.detomasolist.com/mailman/listinfo/detomaso 49. [109]mailto:DeTomaso@server.detomasolist.com 50. [110]mailto:DeTomaso@server.detomasolist.com 51. [111]http://server.detomasolist.com/mailman/listinfo/detomaso 52. [112]mailto:DeTomaso@server.detomasolist.com 53. [113]mailto:DeTomaso@server.detomasolist.com 54. [114]http://server.detomasolist.com/mailman/listinfo/detomaso 55. [115]mailto:DeTomaso@server.detomasolist.com 56. [116]http://server.detomasolist.com/mailman/listinfo/detomaso 57. [117]http://www.avg.com/ _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [118]DeTomaso@server.detomasolist.com [119]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. .
1. http://w7tsc.org/ 2. http://www.teampanteraracing.com/ 3. mailto:asajay@asajay.com 4. mailto:detomaso@server.detomasolist.com 5. http://w7tsc.org/ 6. http://www.teampanteraracing.com/ 7. mailto:3]lplugw@hotmail.com 8. mailto:4]guson@home.se 9. mailto:5]detomaso@detomasolist.com 10. mailto:6]guson@home.se 11. mailto:guson@home.se 12. mailto:8]lplugw@hotmail.com 13. mailto:lplugw@hotmail.com 14. mailto:10]julian_kift@hotmail.com 15. mailto:julian_kift@hotmail.com 16. mailto:12]MikeLDrew@aol.com 17. mailto:MikeLDrew@aol.com 18. mailto:ailto:detomaso@detomasolist.com 19. mailto:15]julian_kift@hotmail.com 20. mailto:julian_kift@hotmail.com 21. mailto:17]marshallgsmith@sbcglobal.net 22. mailto:marshallgsmith@sbcglobal.net 23. mailto:19]detomaso@detomasolist.com 24. mailto:detomaso@detomasolist.com 25. mailto:21]julian_kift@hotmail.com 26. mailto:julian_kift@hotmail.com 27. mailto:23]dakelm@qwest.net 28. mailto:dakelm@qwest.net 29. mailto:25]MikeLDrew@aol.com 30. mailto:MikeLDrew@aol.com 31. mailto:27]detomaso@detomasolist.com 32. mailto:detomaso@detomasolist.com 33. mailto:29]detomaso@detomasolist.com 34. mailto:detomaso@detomasolist.com 35. mailto:31]detomaso-bounces@server.detomasolist.com 36. mailto:detomaso-bounces@ser 37. mailto:33]dakelm@qwest.net 38. mailto:dakelm@qwest.net 39. mailto:35]detomaso@detomasolist.com 40. mailto:detomaso@detomasolist.com 41. mailto:detomaso-bounces@server.detomasolist.com 42. mailto:38]detomaso@detomasolist.com 43. mailto:detomaso@detomasolist.com 44. mailto:40]DeTomaso@server.detomasolist.com 45. mailto:DeTomaso@server.detomasolist 46. http://server.detomasolist.com/mailman/listinfo/detomaso 47. mailto:43]DeTomaso@server.detomasolist.com 48. mailto:DeTomaso@server.detomasolist 49. http://server.detomasolist.com/mailman/listinfo/detomaso 50. mailto:46]DeTomaso@server.detomasolist.com 51. mailto:DeTomaso@server.detomasolist 52. http://server.detomasolist.com/mailman/listinfo/detomaso 53. mailto:49]DeTomaso@server.detomasolist.com 54. mailto:DeTomaso@server.detomasolist 55. http://server.detomasolist.com/mailman/listinfo/detomaso 56. mailto:52]DeTomaso@server.detomasolist.com 57. mailto:DeTomaso@server.detomasolist 58. http://server.detomasolist.com/mailman/listinfo/detomaso 59. mailto:55]DeTomaso@server.detomasolist.com 60. http://server.detomasolist.com/mailman/listinfo/detomaso 61. http://w7tsc.org/ 62. http://www.teampanteraracing.com/ 63. mailto:lplugw@hotmail.com 64. mailto:guson@home.se 65. mailto:detomaso@detomasolist.com 66. mailto:guson@home.se 67. mailto:guson@home.se 68. mailto:lplugw@hotmail.com 69. mailto:lplugw@hotmail.com 70. mailto:julian_kift@hotmail.com 71. mailto:julian_kift@hotmail.com 72. mailto:MikeLDrew@aol.com 73. mailto:MikeLDrew@aol.com 74. mailto:detomaso@detomasolist.com 75. mailto:julian_kift@hotmail.com 76. mailto:julian_kift@hotmail.com 77. mailto:marshallgsmith@sbcglobal.net 78. mailto:marshallgsmith@sbcglobal.net 79. mailto:detomaso@detomasolist.com 80. mailto:detomaso@detomasolist.com 81. mailto:julian_kift@hotmail.com 82. mailto:julian_kift@hotmail.com 83. mailto:dakelm@qwest.net 84. mailto:dakelm@qwest.net 85. mailto:MikeLDrew@aol.com 86. mailto:MikeLDrew@aol.com 87. mailto:detomaso@detomasolist.com 88. mailto:detomaso@detomasolist.com 89. mailto:detomaso@detomasolist.com 90. mailto:detomaso@detomasolist.com 91. mailto:detomaso-bounces@server.detomasolist.com 92. mailto:detomaso-bounces@server.detomasolist.com 93. mailto:dakelm@qwest.net 94. mailto:dakelm@qwest.net 95. mailto:detomaso@detomasolist.com 96. mailto:detomaso@detomasolist.com 97. mailto:detomaso-bounces@server.detomasolist.com 98. mailto:detomaso@detomasolist.com 99. mailto:detomaso@detomasolist.com 100. mailto:DeTomaso@server.detomasolist.com 101. mailto:DeTomaso@server.detomasolist.com 102. http://server.detomasolist.com/mailman/listinfo/detomaso 103. mailto:DeTomaso@server.detomasolist.com 104. mailto:DeTomaso@server.detomasolist.com 105. http://server.detomasolist.com/mailman/listinfo/detomaso 106. mailto:DeTomaso@server.detomasolist.com 107. mailto:DeTomaso@server.detomasolist.com 108. http://server.detomasolist.com/mailman/listinfo/detomaso 109. mailto:DeTomaso@server.detomasolist.com 110. mailto:DeTomaso@server.detomasolist.com 111. http://server.detomasolist.com/mailman/listinfo/detomaso 112. mailto:DeTomaso@server.detomasolist.com 113. mailto:DeTomaso@server.detomasolist.com 114. http://server.detomasolist.com/mailman/listinfo/detomaso 115. mailto:DeTomaso@server.detomasolist.com 116. http://server.detomasolist.com/mailman/listinfo/detomaso 117. http://www.avg.com/ 118. mailto:DeTomaso@server.detomasolist.com 119. http://server.detomasolist.com/mailman/listinfo/detomaso 120. http://www.avg.com/ _______________________________________________
MyCars
Tomas Gunnarsson
