Re: [DeTomaso] DeTomaso Digest, Vol 147, Issue 7
Guys I am new to Panteras having bought one one year ago and reworked it extensively i am used to european cars and i know when a chassis twists and therefore is poor on the handling side the pantera is the only car i ever had that will lift 2 opposite wheels off the ground if you jack it from one corner i believe it is an extremely stiff chassis and needs no further stiffening . the suspensions may of course need tuning for specific use but that is all in my opinion my car at least drives like a go-cart regards owen On 07/09/2016 17:00, detomaso-request@server.detomasolist.com wrote:
Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com
To subscribe or unsubscribe via the World Wide Web, visit http://server.detomasolist.com/mailman/listinfo/detomaso or, via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com
You can reach the person managing the list at detomaso-owner@server.detomasolist.com
When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..."
Daily Detomaso List Digest
Today's Topics:
1. Re: Chassis stiffening kit install (Asa Jay Laughton) 2. Re: Chassis stiffening kit install (Corey Price) 3. Re: Chassis stiffening kit install (Himes, Terry (397C)) 4. Re: Chassis stiffening kit install (Jeff Cobb) 5. Re: Chassis stiffening kit install (Ed Mendez) 6. Re: Flooded Pantera in Baton Rouge (Ed Mendez) 7. Re: Flooded Pantera in Baton Rouge (Bill Lewis) 8. Another Scirocco for Mike Drew? (Mike Reilly) 9. Re: Flooded Pantera in Baton Rouge (Charles Engles) 10. Re: Flooded Pantera in Baton Rouge (Scott Mead Photography) 11. Re: Flooded Pantera in Baton Rouge (Jim Gray) 12. Re: Flooded Pantera in Baton Rouge (Julian Kift) 13. Re: Another Scirocco for Mike Drew? (Paul A Rimov) 14. NPC: Re: Another Scirocco for Mike Drew? (Mike Drew) 15. Re: Flooded Pantera in Baton Rouge (bill@incendium.com) 16. Re: Flooded Pantera in Baton Rouge (Jeff Cobb) 17. Pantera that was delivered to Ford Executive (Ed Mendez) 18. Re: Pantera that was delivered to Ford Executive (Michael Becker) 19. Re: Pantera that was delivered to Ford Executive (Mike Drew) 20. Re: Pantera that was delivered to Ford Executive (Asa Jay Laughton)
Message: 1 Date: Tue, 06 Sep 2016 09:12:36 -0700 From: Asa Jay Laughton <asajay@asajay.com> To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Chassis stiffening kit install Message-ID: <20160906091236.Horde.ar-Z_qWIOS8j_qGVt8ynMXJ@webmail.asajay.com> Content-Type: text/plain; charset=utf-8; format=flowed; DelSp=Yes
For what it's worth, when I was in Castle Rock a few years ago and had time to visit with Dennis and Adam at Pantera Performance Center, Dennis essentially told me the same thing about the front trunk brace (as I recall). That it really wasn't necessary and only served to reduce the amount of usable space in a street car that was only occasionally tracked or open road raced. I believe his recommendation was to not bother with it for most purposes.
Asa Jay
Quoting Larry Stock <larrys@panteraparts.com>:
If one actually was an engineer and analyzed this brace, it is utterly useless. It braces the shear wall construction already built into the upper A-Arm mounting points. Not much movement here with the factory job. Lots of help is needed down below to take the twist out of the lower A-Arm supports. Larry
On 9/6/16, 8:18 AM, "DeTomaso on behalf of Julian Kift" <detomaso-bounces@server.detomasolist.com on behalf of julian_kift@hotmail.com> wrote:
I could start by saying leave it i the corner of the garage, unless you are building and out and out racer.... it is only purpose in a street car is to further limit your wife's luggage allowance, although maybe that could be deemed a positive if she is then limited to only taking briefs and bras...
Others seem to have managed to bolt it in, sitting very low in the trunk (less than an inch between brace and trunk floor). To be functional it should sit directly behind the upper shock mounts. Julian __________________________________________________________________
From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of John McKee <johnmckee@cox.net> Sent: Monday, September 5, 2016 10:28 PM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Chassis stiffening kit install
I am currently working on the front trunk area and I am trying to figure out the best way to mount the triangular upper brace (the part sold by Precision ProFormance). The mounting plates have four bolt holes but it looks like I would not be able to get bolts to work as they would conflict with the upper suspension mounting rail. I am thinking the best solution may be to plug weld those holes from the trunk side. Can anyone share their experience installing these plates?
Thank you,
John _______________________________________________
Our tests show that the body rolls approx. 1.5 degrees without our brace kit. 4.5 degrees of body roll without our Brace Kit and 3.0 degrees with our Brace Kit mounted. Larry stock On 9/7/16, 9:49 AM, "DeTomaso on behalf of Owen Cooke" <detomaso-bounces@server.detomasolist.com on behalf of owen@tadhgcooke.com> wrote:
Guys
regards owen
Today's Topics:
Asa Jay
Thank you,
Owen Cooke
