Re: DeTomaso Digest, Vol 249, Issue 38
Had this been an actual issue, you would NOT have had time to react. LOL -----Original Message----- From: detomaso-request@server.detomasolist.com <detomaso-request@server.detomasolist.com> Sent: Thursday, March 20, 2025 3:09 PM To: detomaso@server.detomasolist.com Subject: DeTomaso Digest, Vol 249, Issue 38 Send DeTomaso mailing list submissions to detomaso@server.detomasolist.com To subscribe or unsubscribe via email, send a message with subject or body 'help' to detomaso-request@server.detomasolist.com You can reach the person managing the list at detomaso-owner@server.detomasolist.com When replying, please edit your Subject line so it is more specific than "Re: Contents of DeTomaso digest..." Daily Detomaso List Digest Today's Topics: 1. Re: Another email list test (Richard Greenblum) 2. Re: Removing Clutch master cylinder issue-Help! (Panteratime) ---------------------------------------------------------------------- Message: 1 Date: Thu, 20 Mar 2025 15:30:52 -0500 From: "Richard Greenblum" <Richard@richardgreenblum.com> Subject: [DeTomaso] Re: Another email list test To: "'Daniel C Jones'" <daniel.c.jones2@gmail.com>, "'detomaso'" <detomaso@server.detomasolist.com> Message-ID: <003a01db99d6$fa6a4080$ef3ec180$@richardgreenblum.com> Content-Type: text/plain; charset="utf-8" Test message received. Richard Austin, TX -----Original Message----- From: Daniel C Jones <daniel.c.jones2@gmail.com> Sent: Thursday, March 20, 2025 3:03 PM To: detomaso <detomaso@server.detomasolist.com> Subject: [DeTomaso] Another email list test So back on 27 February I sent a test to the list that others on the list received and replied to me (off the list). Since then, I have not seen a single DeTomaso list email. I've attempted to unsubscribe and resubscribe. This is another test to see if the list is working (for me). Thanks, Dan Jones ------------------------------ Message: 2 Date: Thu, 20 Mar 2025 22:09:11 +0000 (UTC) From: Panteratime <panteratime@aol.com> Subject: [DeTomaso] Re: Removing Clutch master cylinder issue-Help! To: Julian Kift <julian_kift@hotmail.com>, Larry Weston <lplugw@hotmail.com> Cc: Mike Drew <mikeldrew@aol.com>, "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Message-ID: <77870391.35217.1742508551879@mail.yahoo.com> Content-Type: multipart/mixed; boundary="----=_Part_35216_581893410.1742508551878" Folks,Thanks for the tips on removing the top bolt. Im going to try and get a needle nose vise grip up in that area or have a friend stick a flat head screw driver on the side of the bolt to jam it up and stop rotating, or try a 1/4 in socket. I will see if i can put a "tab " washer in for next time I do this job in the future. As suggested , it will hold the bolt head in place. (Im 69-if there is a next time, ill be glad im still around to do it!) Thanks again for all the help! I wont be doing this job until I fix what may be ignition or exhaust leak for backfiring on de-acceleration and look into an issue with the fast idle cam and choke flap closing and not opening after kick down sequence. Choke flap stays closed after kickdown and wont move again. I think its something with the cam and choke linkage after I pushed the Fast idle cam down in error with my finger. it now seems to be in the wrong position to work correctly. Cliff On Thursday, March 20, 2025 at 06:50:00 AM EDT, Larry Weston <lplugw@hotmail.com> wrote: Another way of holding the clutch master reservoir bolts: Sent from my iPhone On Mar 19, 2025, at 4:39 PM, Julian Kift <julian_kift@hotmail.com> wrote: I assume you are familiar with the brake caliper tabs that you bend over to stop the nut backing out right?... Fabricate one for the two bolts of the clutch master and install under the bolt heads to stop them turning or alternatively fabricate a plate and tack weld the bolt heads to it, no more helper required...... I think folks may be getting confused between 'synthetic' and 'silicone' brake fluids, nothing wrong with synthetic and they are typically higher performing than non-synthetic, you however want to stay away from silicone (DoT 5), which is incompatible with earlier fluids and may older brake seals. Julian __________________________________________________________________ From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> Sent: Wednesday, March 19, 2025 11:44 AM To: Panteratime <panteratime@aol.com> Cc: detomaso@server.detomasolist.com <detomaso@server.detomasolist.com> Subject: [DeTomaso] Re: Removing Clutch master cylinder issue-Help! Cliff, Your helper under the dash holds the bolt (I think using 1/4 inch drive ratchet and extension and socket) while you turn the nut from outside. Doing it solo would be a damn hard job. Mike Sent from my iPad On Mar 19, 2025, at 11:22, Panteratime via DeTomaso <detomaso@server.detomasolist.com> wrote: Folks, Clutch master cylinder leaking. How do you stop top mounting bolt from spinning under dash? I can get a 13mm closed end wrench on the bottom mounting bolt under dash, cant access top bolt. Any tips appreciated! BTW-tough to find locally DOT 3 "Non synthetic" Brake fluid. Everything is synthetic. Had to order STP brand online! Thanks again! Cliff _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list -- detomaso@server.detomasolist.com To unsubscribe send an email to detomaso-leave@server.detomasolist.com To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list -- detomaso@server.detomasolist.com To unsubscribe send an email to detomaso-leave@server.detomasolist.com To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list -- detomaso@server.detomasolist.com To unsubscribe send an email to detomaso-leave@server.detomasolist.com To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
david.hofman@cox.net
