Re: [DeTomaso] Cooling system
In a message dated 7/26/16 8 41 31, klckmac@msn.com writes:
Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup.
Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike In a message dated 7/26/16 8 41 31, klckmac@msn.com writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike
When I pulled my Hall brass radiator out to get it flushed and replace the original lines in my '71, two things surprised me. 1. That radiator weighs a ton, and 2. It was really clean inside The unit was not was not leaking, but I had never pulled it to ascertain its true health. The shop flushed, pressure tested, added a few weld spots for Good measure, and told me it was a very solid design. I live in FL where it is warm to blistering year round. My original fans were shot and I only seemed to run hot in traffic When I did not have my manual fan on ( as original wiring allows on '71s). I bought non polished SS tubes from a vendor, polished them myself, all new hose and clamps, bought the Pantera Electronics fan controller, new Spam pushers, and filled it all up with distilled water, water wetter, and coolant. Temps are fine. The fan controller works off of one temp sensor on the radiator and runs the fans at a variable speed depending on the heat. I highly recommend it. When I pulled my Hall brass radiator out to get it flushed and replace the original lines in my '71, two things surprised me. 1. That radiator weighs a ton, and 2. It was really clean inside The unit was not was not leaking, but I had never pulled it to ascertain its true health. The shop flushed, pressure tested, added a few weld spots for Good measure, and told me it was a very solid design. I live in FL where it is warm to blistering year round. My original fans were shot and I only seemed to run hot in traffic When I did not have my manual fan on ( as original wiring allows on '71s).A I bought non polished SS tubes from a vendor, polished them myself, all new hose and clamps, bought the Pantera Electronics fan controller, new Spam pushers, and filled it all up with distilled water, water wetter, and coolant. Temps are fine. The fan controller works off of one temp sensor on the radiator and runs the fans at a variable speed depending on the heat. I highly recommend it.
I think you also have to consider the location you live in. I have had 3 or 4 different brass radiators. About every radiator Hall sold and then some. In Arizona the only radiator that kept the car cool was the Ron Davis. The combination of radiator and Dennis's fans makes it work without ever being a problem. Rich _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
As we have gotten to know our new Brock Daytona I have been reminded of all the things that contribute to a car overheating. Besides the obvious (too little coolant, fans not spinning, radiator full of bugs or plugged internally) one must also think about things like the timing and the fuel mixture. Our Daytona with its 427R was prone to getting warm. Found that the timing was off by about 5 degrees (retarded) and the fuel mixture was way lean. Do these things matter? Well, after getting the timing right and resetting the fuel pressure (was at 2, recommended 6 psi), the float levels (down a quarter of an inch) and the idle mixture, wow - not only runs cooler, but the increased hp showed the clutch was not fully releasing - so next adjusted the length of the slave cylinder rod. Of course, to get the timing I wanted (as recommended by folks on the Superformance forum - 18 to 20 degrees BTDC at 1,000 rpm and 34 or 36 at 2,500 rpm) I ended up needing to turn a custom bushing for the MSD distributor. But, wow, does she now pull! Stephen Nelson 5332 -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Rich Sent: Wednesday, July 27, 2016 6:52 AM To: Rob Dumoulin <rob@dumoulins.net>; Pantera Mail List <detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Cooling system I think you also have to consider the location you live in. I have had 3 or 4 different brass radiators. About every radiator Hall sold and then some. In Arizona the only radiator that kept the car cool was the Ron Davis. The combination of radiator and Dennis's fans makes it work without ever being a problem. Rich _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
One of my favorite cars of all time. Sent from my iPhone
Stephen Nelson 5332
I agree with Mike. I have my original radiator with new fans and it is still functioning perfectly. <knock on wood>. I'm no expert but it doesn't make sense to spend a ton of money. I do have to pull some preventative maintenance on my 42 year old radiator, but I'm not going to spend a lot to do it. That's my plan anyway. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Reply-To: "MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>> Date: Tuesday, July 26, 2016 4:33 PM To: "klckmac@msn.com<mailto:klckmac@msn.com>" <klckmac@msn.com<mailto:klckmac@msn.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Cooling system In a message dated 7/26/16 8 41 31, klckmac@msn.com<mailto:klckmac@msn.com> writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike I agree with Mike. I have my original radiator with new fans and it is still functioning perfectly. <knock on wood>. I'm no expert but it doesn't make sense to spend a ton of money. I do have to pull some preventative maintenance on my 42 year old radiator, but I'm not going to spend a lot to do it. That's my plan anyway. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <[3]detomaso@server.detomasolist.com> Reply-To: "[4]MikeLDrew@aol.com" <[5]MikeLDrew@aol.com> Date: Tuesday, July 26, 2016 4:33 PM To: "[6]klckmac@msn.com" <[7]klckmac@msn.com>, "[8]detomaso@server.detomasolist.com" <[9]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Cooling system In a message dated 7/26/16 8 41 31, [10]klckmac@msn.com writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:detomaso@server.detomasolist.com 4. mailto:MikeLDrew@aol.com 5. mailto:MikeLDrew@aol.com 6. mailto:klckmac@msn.com 7. mailto:klckmac@msn.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:klckmac@msn.com
Getting 2nd opinion today. This shop thinks it looks ok, just age on it, will do a $30 test, but seems pretty optimistic it's not a total re-do like the other shop. Crossing my fingers. He was surprised the other shop just made a diagnosis without a test, which tells me which shop to avoid. ________________________________ From: Himes, Terry (397C) <terry.himes@jpl.nasa.gov> Sent: Wednesday, July 27, 2016 7:15 AM To: MikeLDrew@aol.com; klckmac@msn.com; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Cooling system I agree with Mike. I have my original radiator with new fans and it is still functioning perfectly. <knock on wood>. I'm no expert but it doesn't make sense to spend a ton of money. I do have to pull some preventative maintenance on my 42 year old radiator, but I'm not going to spend a lot to do it. That's my plan anyway. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Reply-To: "MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>> Date: Tuesday, July 26, 2016 4:33 PM To: "klckmac@msn.com<mailto:klckmac@msn.com>" <klckmac@msn.com<mailto:klckmac@msn.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Cooling system In a message dated 7/26/16 8 41 31, klckmac@msn.com<mailto:klckmac@msn.com> writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike Getting 2nd opinion today. This shop thinks it looks ok, just age on it, will do a $30 test, but seems pretty optimistic it's not a total re-do like the other shop. Crossing my fingers. He was surprised the other shop just made a diagnosis without a test, which tells me which shop to avoid. __________________________________________________________________ From: Himes, Terry (397C) <terry.himes@jpl.nasa.gov> Sent: Wednesday, July 27, 2016 7:15 AM To: MikeLDrew@aol.com; klckmac@msn.com; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Cooling system I agree with Mike. I have my original radiator with new fans and it is still functioning perfectly. <knock on wood>. I'm no expert but it doesn't make sense to spend a ton of money. I do have to pull some preventative maintenance on my 42 year old radiator, but I'm not going to spend a lot to do it. That's my plan anyway. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <[3]detomaso@server.detomasolist.com> Reply-To: "[4]MikeLDrew@aol.com" <[5]MikeLDrew@aol.com> Date: Tuesday, July 26, 2016 4:33 PM To: "[6]klckmac@msn.com" <[7]klckmac@msn.com>, "[8]detomaso@server.detomasolist.com" <[9]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Cooling system In a message dated 7/26/16 8 41 31, [10]klckmac@msn.com writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:detomaso@server.detomasolist.com 4. mailto:MikeLDrew@aol.com 5. mailto:MikeLDrew@aol.com 6. mailto:klckmac@msn.com 7. mailto:klckmac@msn.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:klckmac@msn.com
participants (7)
Ken and Lela MacArthur
MikeLDrew@aol.com
Rich
Rob Dumoulin
Stephen
Will Kooiman
