Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike
Is it wired so that the indicator light in the speedo works? Are you using the external cooling fan on the alternator? Forest From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> To: detomaso@server.detomasolist.com Sent: Sunday, October 2, 2016 9:11 PM Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. Is it wired so that the indicator light in the speedo works? Are you using the external cooling fan on the alternator? Forest __________________________________________________________________ From: Mike Drew via DeTomaso <detomaso@server.detomasolist.com> To: detomaso@server.detomasolist.com Sent: Sunday, October 2, 2016 9:11 PM Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [1]DeTomaso@server.detomasolist.com [2]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:DeTomaso@server.detomasolist.com 2. http://server.detomasolist.com/mailman/listinfo/detomaso
Good morning Mike, High ohm engine ground strap connections will cause spastic and damaging alternator function. If it charges now then use a hand held load meter; -1-set idle-hold at 1,500 and note volts + amps at both battery post at no load, now load the meter and note, -2-Then from batt positive post to closest frame ground, loading and noting again, a six second 100 amp load will smoke out the weak connection, -3-Then from alternator output post to engine block, repeat above no and load test, -4-repeat from alt output to frame ground, repeat above no and load test, -5-now place load meter or test light from engine to frame ground and find voltage or light, 1 and 3 will be closely identical, though 3 slightly less due to wire distance ohm reduction, reference values that you can base the alt function and amp meter realities. 2 and 4 will help you find electrical resistance. If all above 8 test give pretty much same values within a .3 volt and 5 amp variance then you need to find flaw elsewhere. Sometimes a 10 second 100 amp load test at 3,000 may break your hidden problem, try and see if above 8 don't point to issue. If it does not charge then use a large battery charger and load both battery post then repeat and charge alt stud and engine ground, you may find resistance. Also an extra large woven ground strap never hurts! 33 years ago the Baton Rouge Volvo dealer sold me 6 defective alternators in a row for the same customer. I was the largest Volvo repair shop in town and also was paid my said dealer to do warranty work for them as they were overloaded. The 7th one worked, the owner was scamming his dealership and was putting new-defective-warrantied alternators back in stock so to make more money to finance his hydroplane racing. Of course I was the largest buyer of Volvo parts so I got stung and customer was pissed beyond belief. Year or so later when owner was busted, jailed and dealer closed, his son brought me as a guilt gift a new Volvo cylinder head in crate and other parts so to make amends. Poo-poo occurs. Back in March prepping for Amelia, I noticed where my Mangusta had electrical burning marks on the alloy around the large bell housing bolt washer interfaces, WTF???, we found the bolts not to be as tight as they should have been. So my alternator engine ground was trying and having a difficult time getting back to the true body-battery ground and left burning-jumping marks on the bell housing. Now all is fine and battery cable temps are cooler. Good luck, Jeff Jeff Cobb- I pad W-225-343-7525 C-225-907-4514 On Oct 2, 2016, at 11:11 PM, Mike Drew via DeTomaso <detomaso@server.detomasolist.com> wrote:
Good morning Mike, High ohm engine ground strap connections will cause spastic and damaging alternator function. If it charges now then use a hand held load meter; -1-set idle-hold at 1,500 and note volts + amps at both battery post at no load, now load the meter and note, -2-Then from batt positive post to closest frame ground, loading and noting again, a six second 100 amp load will smoke out the weak connection, -3-Then from alternator output post to engine block, repeat above no and load test, -4-repeat from alt output to frame ground, repeat above no and load test, -5-now place load meter or test light from engine to frame ground and find voltage or light, 1 and 3 will be closely identical, though 3 slightly less due to wire distance ohm reduction, reference values that you can base the alt function and amp meter realities. 2 and 4 will help you find electrical resistance. If all above 8 test give pretty much same values within a .3 volt and 5 amp variance then you need to find flaw elsewhere. Sometimes a 10 second 100 amp load test at 3,000 may break your hidden problem, try and see if above 8 don't point to issue. If it does not charge then use a large battery charger and load both battery post then repeat and charge alt stud and engine ground, you may find resistance. Also an extra large woven ground strap never hurts! 33 years ago the Baton Rouge Volvo dealer sold me 6 defective alternators in a row for the same customer. I was the largest Volvo repair shop in town and also was paid my said dealer to do warranty work for them as they were overloaded. The 7th one worked, the owner was scamming his dealership and was putting new-defective-warrantied alternators back in stock so to make more money to finance his hydroplane racing. Of course I was the largest buyer of Volvo parts so I got stung and customer was pissed beyond belief. Year or so later when owner was busted, jailed and dealer closed, his son brought me as a guilt gift a new Volvo cylinder head in crate and other parts so to make amends. Poo-poo occurs. Back in March prepping for Amelia, I noticed where my Mangusta had electrical burning marks on the alloy around the large bell housing bolt washer interfaces, WTF???, we found the bolts not to be as tight as they should have been. So my alternator engine ground was trying and having a difficult time getting back to the true body-battery ground and left burning-jumping marks on the bell housing. Now all is fine and battery cable temps are cooler. Good luck, Jeff Jeff Cobb- I pad W-225-343-7525 C-225-907-4514 On Oct 2, 2016, at 11:11 PM, Mike Drew via DeTomaso <[1]detomaso@server.detomasolist.com> wrote: Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [2]DeTomaso@server.detomasolist.com [3]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:detomaso@server.detomasolist.com 2. mailto:DeTomaso@server.detomasolist.com 3. http://server.detomasolist.com/mailman/listinfo/detomaso
Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com> Sent: Sunday, October 2, 2016 9:11 PM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com> Sent: Sunday, October 2, 2016 9:11 PM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike
Ditto. I put in 2 rebuilt units and they both failed. Finally bought a new one. No problem since. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Date: Monday, October 3, 2016 6:57 AM To: "MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Alternator blues.... Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Sunday, October 2, 2016 9:11 PM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike Ditto. I put in 2 rebuilt units and they both failed. Finally bought a new one. No problem since. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Julian Kift <[3]julian_kift@hotmail.com> Date: Monday, October 3, 2016 6:57 AM To: "[4]MikeLDrew@aol.com" <[5]MikeLDrew@aol.com>, "[6]detomaso@server.detomasolist.com" <[7]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Alternator blues.... Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian ________________________________ From: DeTomaso <[8]detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <[9]detomaso@server.detomasolist.com> Sent: Sunday, October 2, 2016 9:11 PM To: [10]detomaso@server.detomasolist.com Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:julian_kift@hotmail.com 4. mailto:MikeLDrew@aol.com 5. mailto:MikeLDrew@aol.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso-bounces@server.detomasolist.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:detomaso@server.detomasolist.com
All, Further to my original inquiry, I failed to mention that this is a GM alternator with built-in regulator, running in the stock three-wire configuration. Normally it works normally--shows a somewhat strong charge for a short time after engine start, coming back down to slight charge when battery is 'full' again, with slight discharge at idle when fans, lights etc are on. When it starts acting up, initially the needle bounces erratically over a small range between slight charge and slight discharge. After a few minutes of that, it goes into greater discharge mode as it quits completely. Mike Sent from my iPhone On Oct 3, 2016, at 8:15, "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov> wrote:
Terry W. Himes
Fax: (818) 393-3147
1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:julian_kift@hotmail.com 4. mailto:MikeLDrew@aol.com 5. mailto:MikeLDrew@aol.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso-bounces@server.detomasolist.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:detomaso@server.detomasolist.com _______________________________________________
Further to my further, here is a video I just shot after starting up and letting it run for five minutes. Rpm held at constant 2000. http://youtu.be/1T20MHyd9zU Mike Sent from my iPhone On Oct 3, 2016, at 9:00, Mike Drew <MikeLDrew@aol.com> wrote:
All,
Terry W. Himes
Fax: (818) 393-3147
Further to my further, here is a video I just shot after starting up and letting it run for five minutes. Rpm held at constant 2000. [1]http://youtu.be/1T20MHyd9zU Mike Sent from my iPhone On Oct 3, 2016, at 9:00, Mike Drew <[2]MikeLDrew@aol.com> wrote: All, Further to my original inquiry, I failed to mention that this is a GM alternator with built-in regulator, running in the stock three-wire configuration. Normally it works normally--shows a somewhat strong charge for a short time after engine start, coming back down to slight charge when battery is 'full' again, with slight discharge at idle when fans, lights etc are on. When it starts acting up, initially the needle bounces erratically over a small range between slight charge and slight discharge. After a few minutes of that, it goes into greater discharge mode as it quits completely. Mike Sent from my iPhone On Oct 3, 2016, at 8:15, "Himes, Terry (397C)" <[3]terry.himes@jpl.nasa.gov> wrote: Ditto. I put in 2 rebuilt units and they both failed. Finally bought a new one. No problem since. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1][4]thimes@jpl.nasa.gov From: DeTomaso <[2][5]detomaso-bounces@server.detomasolist.com> on behalf of Julian Kift <[3][6]julian_kift@hotmail.com> Date: Monday, October 3, 2016 6:57 AM To: "[4][7]MikeLDrew@aol.com" <[5][8]MikeLDrew@aol.com>, "[6][9]detomaso@server.detomasolist.com" <[7][10]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Alternator blues.... Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian ________________________________ From: DeTomaso <[8][11]detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <[9][12]detomaso@server.detomasolist.com> Sent: Sunday, October 2, 2016 9:11 PM To: [10][13]detomaso@server.detomasolist.com Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike References 1. [14]mailto:thimes@jpl.nasa.gov 2. [15]mailto:detomaso-bounces@server.detomasolist.com 3. [16]mailto:julian_kift@hotmail.com 4. [17]mailto:MikeLDrew@aol.com 5. [18]mailto:MikeLDrew@aol.com 6. [19]mailto:detomaso@server.detomasolist.com 7. [20]mailto:detomaso@server.detomasolist.com 8. [21]mailto:detomaso-bounces@server.detomasolist.com 9. [22]mailto:detomaso@server.detomasolist.com 10. [23]mailto:detomaso@server.detomasolist.com _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [24]DeTomaso@server.detomasolist.com [25]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://youtu.be/1T20MHyd9zU 2. mailto:MikeLDrew@aol.com 3. mailto:terry.himes@jpl.nasa.gov 4. mailto:thimes@jpl.nasa.gov 5. mailto:detomaso-bounces@server.detomasolist.com 6. mailto:julian_kift@hotmail.com 7. mailto:MikeLDrew@aol.com 8. mailto:MikeLDrew@aol.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:detomaso@server.detomasolist.com 11. mailto:detomaso-bounces@server.detomasolist.com 12. mailto:detomaso@server.detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:thimes@jpl.nasa.gov 15. mailto:detomaso-bounces@server.detomasolist.com 16. mailto:julian_kift@hotmail.com 17. mailto:MikeLDrew@aol.com 18. mailto:MikeLDrew@aol.com 19. mailto:detomaso@server.detomasolist.com 20. mailto:detomaso@server.detomasolist.com 21. mailto:detomaso-bounces@server.detomasolist.com 22. mailto:detomaso@server.detomasolist.com 23. mailto:detomaso@server.detomasolist.com 24. mailto:DeTomaso@server.detomasolist.com 25. http://server.detomasolist.com/mailman/listinfo/detomaso
Terry W. Himes
Fax: (818) 393-3147
My first suspect would be HEAT. Google shows two different external fans, one being more air flow than other. At idle with lights on, slight discharge; the alternator would be getting its hottest due to high current/low speed with the least amount of speed for the cooling fan. Putting a temporary temperature gauge on the housing would let you know, my first google for acceptable temperature has not provided a value, BUT several mentions of temperature, low speed high current causing rapid failures. IF (hopefully WHEN) I get a running Pantera, looking into providing cooler air to the alternator will be something I hope I remember, mayby some type of shielding/ducting AND just because I think it is needed, a grounding strap from alternator to chassis wouldn't hurt. When I get time I'll search more on alternator temperature range. Joe -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Monday, October 03, 2016 12:00 PM To: Himes, Terry (397C) Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... All, Further to my original inquiry, I failed to mention that this is a GM alternator with built-in regulator, running in the stock three-wire configuration. Normally it works normally--shows a somewhat strong charge for a short time after engine start, coming back down to slight charge when battery is 'full' again, with slight discharge at idle when fans, lights etc are on. When it starts acting up, initially the needle bounces erratically over a small range between slight charge and slight discharge. After a few minutes of that, it goes into greater discharge mode as it quits completely. Mike Sent from my iPhone On Oct 3, 2016, at 8:15, "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov> wrote: the links above.
message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
I didn't find any detail info, just one reference to where regulator switches off above 320F. as for "cooking" the wiring's insulation,causing failure, all I can go by is normal motor/generator insulation classes, the cheapest should not exceed 220F and the best 320F -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Joseph F. Byrd, Jr. Sent: Monday, October 03, 2016 12:19 PM To: 'Mike Drew'; 'Himes, Terry (397C)' Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... My first suspect would be HEAT. Google shows two different external fans, one being more air flow than other. .... When I get time I'll search more on alternator temperature range. Joe
Check the fat wire from B+ (or what it is called on the alt) to the ammeter. If there is a marginal connection there the voltage can fluctuate wildly and possibly kill semiconductors in the alt.
3 okt. 2016 kl. 18:00 skrev Mike Drew via DeTomaso <detomaso@server.detomasolist.com>:
All,
Terry W. Himes
Fax: (818) 393-3147
The GM 1-wire on my XKE died after about 6 months, replaced it and been fine since. Also have one on our Pantera, with about 5,000 miles, everything fine so far. I will comment that, given the lack of air flow when the car is sitting still, I suspect my added cooling fan might help a little, but heck, the alternator is not right above the exhaust manifold - would not think it would get that warm unless it has too small a built-in fan... As I recall there were two options when I bought our 1 wire from Napa - one with a fan that looked a lot nicer. Stephen Nelson 5332 -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Himes, Terry (397C) Sent: Monday, October 03, 2016 8:15 AM To: Julian Kift <julian_kift@hotmail.com>; MikeLDrew@aol.com; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... Ditto. I put in 2 rebuilt units and they both failed. Finally bought a new one. No problem since. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Date: Monday, October 3, 2016 6:57 AM To: "MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Alternator blues.... Mike, I hate chasing these type of electrical problems, but here's some thoughts; i) Battery going bad (how old is it?), requiring the alternator to have to constantly charge ii) Some alternator re builders are notorious for units failing, over a 50% failure rate is not uncommon. I had a similar issue with my GT40; on the third alternator we switched to a higher amp 'new' unit and never had a problem since. iii) It could also be an intermittent short or bad ground Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Sunday, October 2, 2016 9:11 PM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] Alternator blues.... Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike
For what it’s worth, In all my years of working on cars, boats and airplanes, 90% of electrical issues can be traced to poor grounds and/or poor connections. David Finley 3659
Stephen Nelson 5332
Mike,
Hi guys,
Quick thoughts. I recently looked at an ammeter in a Pantera that was pegged on full charge... even when the battery was disconnected. um..... So I took the dash apart and found the terminals on the ammeter were kind of fried and all the ring terminals were black from oxidation. Short story, we put all terminals on one post and bypassed the ammeter. What's my point. I know Mike has probably got a recommended bypass on his ammeter, but maybe it's worth pulling the dash, removing all the connections, polishing them up and putting it back together. At least that would eliminate the gauge and it's connections. Because David has a good point. Asa Jay Asa Jay Laughton - W7TSC, MSgt, USAFR, Retired & Shelley Marie Spokane, WA ****************************** http://w7tsc.org http://www.teampanteraracing.com On 10/3/2016 6:09 PM, MSM Contractors wrote:
David Finley 3659
Stephen Nelson 5332
-----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Himes, Terry (397C) Sent: Monday, October 03, 2016 8:15 AM To: Julian Kift<julian_kift@hotmail.com>; MikeLDrew@aol.com; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues....
From: DeTomaso<detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Julian Kift<julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>> Date: Monday, October 3, 2016 6:57 AM To: "MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>"<MikeLDrew@aol.com<mailto:MikeLDrew@aol.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>"<detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Alternator blues....
Mike,
Julian ________________________________ From: DeTomaso<detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Mike Drew via DeTomaso<detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Sent: Sunday, October 2, 2016 9:11 PM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] Alternator blues....
Hi guys,
----- No virus found in this message. Checked by AVG - www.avg.com Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: 10/03/16
Hey Mike, After we left you yesterday afternoon, The trip back over the Sierra¹s last night was horrific. Rain started just above Placerville as we hydroplaned many times the rain was so heavy. The snow started below 6000 feet causing white out conditions several times. At the top of Echo summit there was a Bad Head On collision that closed the highway in both directions for quite a while. Certainly no place for Pantera¹s yesterday evening. Apparently The Reno Tahoe Pantera¹s stayed in place for good reasons. Larry On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <detomaso-bounces@server.detomasolist.com on behalf of detomaso@server.detomasolist.com> wrote:
That makes me feel a whole lot better about my last minute decision to stay home yesterday. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Larry Stock <larrys@panteraparts.com> Sent: Monday, October 3, 2016 7:14 AM To: MikeLDrew@aol.com Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... Hey Mike, After we left you yesterday afternoon, The trip back over the Sierra¹s last night was horrific. Rain started just above Placerville as we hydroplaned many times the rain was so heavy. The snow started below 6000 feet causing white out conditions several times. At the top of Echo summit there was a Bad Head On collision that closed the highway in both directions for quite a while. Certainly no place for Pantera¹s yesterday evening. Apparently The Reno Tahoe Pantera¹s stayed in place for good reasons. Larry On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <detomaso-bounces@server.detomasolist.com on behalf of detomaso@server.detomasolist.com> wrote:
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso DeTomaso Info Page<http://server.detomasolist.com/mailman/listinfo/detomaso> server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ...
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com [1]http://server.detomasolist.com/mailman/listinfo/detomaso [2]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ...
_______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso DeTomaso Info Page<http://server.detomasolist.com/mailman/listinfo/detomaso> server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. That makes me feel a whole lot better about my last minute decision to stay home yesterday. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Larry Stock <larrys@panteraparts.com> Sent: Monday, October 3, 2016 7:14 AM To: MikeLDrew@aol.com Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... Hey Mike, After we left you yesterday afternoon, The trip back over the Sierra^1s last night was horrific. Rain started just above Placerville as we hydroplaned many times the rain was so heavy. The snow started below 6000 feet causing white out conditions several times. At the top of Echo summit there was a Bad Head On collision that closed the highway in both directions for quite a while. Certainly no place for Pantera^1s yesterday evening. Apparently The Reno Tahoe Pantera^1s stayed in place for good reasons. Larry On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <detomaso-bounces@server.detomasolist.com on behalf of detomaso@server.detomasolist.com> wrote: that list.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com [3]http://server.detomasolist.com/mailman/listinfo/detomaso [4]DeTomaso Info Page server.detomasolist.com This is the DeTomaso mailing list, a free and open forum for the discussion of issues surrounding all DeTomaso automobiles. This is an unmoderated mailing list ... To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://server.detomasolist.com/mailman/listinfo/detomaso 2. http://server.detomasolist.com/mailman/listinfo/detomaso 3. http://server.detomasolist.com/mailman/listinfo/detomaso 4. http://server.detomasolist.com/mailman/listinfo/detomaso
Although not related (maybe), does the name “Neillo” represent a family name? Just curious. Jack
Yes, the Niello family owns almost all the import car dealerships in Sacramento. Niello Audi, Niello VW, Niello Land Rover, etc etc. https://www.niello.com/ Mike Sent from my iPad
Yes, the Niello family owns almost all the import car dealerships in Sacramento. Niello Audi, Niello VW, Niello Land Rover, etc etc. [1]https://www.niello.com/ Mike Sent from my iPad On Oct 5, 2016, at 10:28 AM, Jack Donahue <[2]demongusta@gmail.com> wrote: Although not related (maybe), does the name "Neillo" represent a family name? Just curious. Jack On Oct 3, 2016, at 7:14 AM, Larry Stock <[3]larrys@panteraparts.com> wrote: Hey Mike, After we left you yesterday afternoon, The trip back over the Sierra^1s last night was horrific. Rain started just above Placerville as we hydroplaned many times the rain was so heavy. The snow started below 6000 feet causing white out conditions several times. At the top of Echo summit there was a Bad Head On collision that closed the highway in both directions for quite a while. Certainly no place for Pantera^1s yesterday evening. Apparently The Reno Tahoe Pantera^1s stayed in place for good reasons. Larry On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <[4]detomaso-bounces@server.detomasolist.com on behalf of [5]detomaso@server.detomasolist.com> wrote: Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [6]DeTomaso@server.detomasolist.com [7]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [8]DeTomaso@server.detomasolist.com [9]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [10]DeTomaso@server.detomasolist.com [11]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. https://www.niello.com/ 2. mailto:demongusta@gmail.com 3. mailto:larrys@panteraparts.com 4. mailto:detomaso-bounces@server.detomasolist.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:DeTomaso@server.detomasolist.com 7. http://server.detomasolist.com/mailman/listinfo/detomaso 8. mailto:DeTomaso@server.detomasolist.com 9. http://server.detomasolist.com/mailman/listinfo/detomaso 10. mailto:DeTomaso@server.detomasolist.com 11. http://server.detomasolist.com/mailman/listinfo/detomaso
OK - here’s a bit of a co-incidence - My father wanted to buy a Porsche Super-90 in 1961 at Neillo Porsche - at that time they had one business only - the Porsche dealership on Fulton Ave. in Sacto.. BUT - Mr. Neillo wanted the car also - a powder blue couple with red leather. So the battle began with my father arguing he had cash in his pocket and the car was on the showroom floor - so it was “for sale”. Neillo won - so my father bought a pearl white Super - removable hadrtop - red leather. But he loved the Super-90 (red line-6500). I was in high school with Rick and Roger Neillo and almost wound up in a fist fight. We were in a German language class when it all went down - Good story. I see the family has expanded their business - more headaches. I am now the longest standing member of the Porsche Club of America( 61 years) and the only remaining Charter member - it began in 1955. I should go pull some rank on the Neillos for old times sake. Anyway - I thought I recognized the name. Jack
https://www.niello.com/ <https://www.niello.com/>
Sent from my iPad
On Oct 5, 2016, at 10:28 AM, Jack Donahue <demongusta@gmail.com <mailto:demongusta@gmail.com>> wrote:
On Oct 3, 2016, at 7:14 AM, Larry Stock <larrys@panteraparts.com <mailto:larrys@panteraparts.com>> wrote:
On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <detomaso-bounces@server.detomasolist.com <mailto:detomaso-bounces@server.detomasolist.com> on behalf of detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>> wrote:
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com <mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso <http://server.detomasolist.com/mailman/listinfo/detomaso>
OK - here's a bit of a co-incidence - My father wanted to buy a Porsche Super-90 in 1961 at Neillo Porsche - at that time they had one business only - the Porsche dealership on Fulton Ave. in Sacto.. BUT - Mr. Neillo wanted the car also - a powder blue couple with red leather. So the battle began with my father arguing he had cash in his pocket and the car was on the showroom floor - so it was "for sale". Neillo won - so my father bought a pearl white Super - removable hadrtop - red leather. But he loved the Super-90 (red line-6500). I was in high school with Rick and Roger Neillo and almost wound up in a fist fight. We were in a German language class when it all went down - Good story. I see the family has expanded their business - more headaches. I am now the longest standing member of the Porsche Club of America( 61 years) and the only remaining Charter member - it began in 1955. I should go pull some rank on the Neillos for old times sake. Anyway - I thought I recognized the name. Jack On Oct 5, 2016, at 10:34 AM, Mike Drew <[1]MikeLDrew@aol.com> wrote: Yes, the Niello family owns almost all the import car dealerships in Sacramento. Niello Audi, Niello VW, Niello Land Rover, etc etc. [2]https://www.niello.com/ Mike Sent from my iPad On Oct 5, 2016, at 10:28 AM, Jack Donahue <[3]demongusta@gmail.com> wrote: Although not related (maybe), does the name "Neillo" represent a family name? Just curious. Jack On Oct 3, 2016, at 7:14 AM, Larry Stock <[4]larrys@panteraparts.com> wrote: Hey Mike, After we left you yesterday afternoon, The trip back over the Sierra^1s last night was horrific. Rain started just above Placerville as we hydroplaned many times the rain was so heavy. The snow started below 6000 feet causing white out conditions several times. At the top of Echo summit there was a Bad Head On collision that closed the highway in both directions for quite a while. Certainly no place for Pantera^1s yesterday evening. Apparently The Reno Tahoe Pantera^1s stayed in place for good reasons. Larry On 10/2/16, 9:11 PM, "DeTomaso on behalf of Mike Drew via DeTomaso" <[5]detomaso-bounces@server.detomasolist.com on behalf of [6]detomaso@server.detomasolist.com> wrote: Hi guys, Just got home from a terrific weekend in the Sierra foothills; 24 Panteras (of the 36 scheduled) took part in the Niello concours at Serrano. It heaved down with rain for a very brief period, but that rain then turned to snow which kept the large Reno/Tahoe contingent from braving the summit. Still, a great time was had by all who attended, and we drove home in splendid sunshine. We were driving in Lori's Pantera, which has a flat firewall kit and uses a GM alternator with built-in regulator. She drove the car to Vegas this spring, and the alternator failed while we were there. At first it started acting erratic, with the amp needle bouncing around, and then finally it quit and just showed a partial discharge. Testing at the battery revealed it was doing nothing at that point. We replaced it with another one, which did exactly the same thing and failed about 50 miles from home. We replaced THAT one, and the third one has worked fine until today. But it probably only has about 250 miles on it or so. On the way home, once again, I noticed the ammeter needle behaving erratically, then it quit and showed partial discharge for many miles, then briefly came back to life and showed a very strong charge (since we had been running on battery power for awhile), then discharged again. Methinks the problem is not simply that alternators are failing, but rather that there is some sort of fault in the electrical system. As electrons are far from my strong suit, I hesitate to start diving it to it blindly. What say all of you? FWIW we've got a spare alternator we will be installing tomorrow, which almost assuredly will work just fine...for awhile anyway???? Mike _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [7]DeTomaso@server.detomasolist.com [8]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com [10]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [11]DeTomaso@server.detomasolist.com [12]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:MikeLDrew@aol.com 2. https://www.niello.com/ 3. mailto:demongusta@gmail.com 4. mailto:larrys@panteraparts.com 5. mailto:detomaso-bounces@server.detomasolist.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:DeTomaso@server.detomasolist.com 8. http://server.detomasolist.com/mailman/listinfo/detomaso 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso 11. mailto:DeTomaso@server.detomasolist.com 12. http://server.detomasolist.com/mailman/listinfo/detomaso
Sent from my iPad
Although not related (maybe), does the name Neillo represent a family name? Just curious. Jack
<<We were in a German language class when it all went down - Good story.>> God story....welll???? Larry (is only 61) - Cleveland (AKA "Baby") -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Jack Donahue Sent: Wednesday, October 05, 2016 1:54 PM To: Mike Drew Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Alternator blues.... OK - heres a bit of a co-incidence - My father wanted to buy a Porsche Super-90 in 1961 at Neillo Porsche - at that time they had one business only - the Porsche dealership on Fulton Ave. in Sacto.. BUT - Mr. Neillo wanted the car also - a powder blue couple with red leather. So the battle began with my father arguing he had cash in his pocket and the car was on the showroom floor - so it was for sale. Neillo won - so my father bought a pearl white Super - removable hadrtop - red leather. But he loved the Super-90 (red line-6500). I was in high school with Rick and Roger Neillo and almost wound up in a fist fight. We were in a German language class when it all went down - Good story. I see the family has expanded their business - more headaches. I am now the longest standing member of the Porsche Club of America( 61 years) and the only remaining Charter member - it began in 1955. I should go pull some rank on the Neillos for old times sake. Anyway - I thought I recognized the name. Jack list. the archiving of list messages. the links above. the archiving of list messages.
participants (14)
Forest Goodhart
Jack Donahue
JEFFREY COBB
Joseph F. Byrd, Jr.
Larry - Ohio Time
MikeLDrew@aol.com
MSM Contractors
Stephen
Thomas Törnblom
