Hi all,just fitted a pair of new door mirrors and was in the process of refitting the door cards when I remembered a piece of advice a friends dad gave me forty years ago ( yeah I know) " don't put the plastic back on the door behind the card as it causes condensation and inevitably corrosion" What do you guys think, leave the plastic on or bin it? Thanks for any input Michael Sent from my iPad
Just my opinion mind you, but I think it helps so I leave it in place. If you don't, moisture can seep into the door panel (card) and destroy it faster than the door itself. There are enough openings in the inner door frame that you'll plainly see the plastic is not creating a total seal on any one area, so moisture has a chance to evaporate. However, if you leave the plastic off, moisture that seeps in from the outside will transition through those same openings to the interior panel door card. And since the card is made of a fiberboard material, it -will- absorb the moisture, eventually warping and degrading your overall Pantera experience. I'd leave them in place. :) Asa Quoting Michael Barnes <michaelbarnessrt10@hotmail.co.uk>:
Michael
Sent from my iPad _______________________________________________
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso
-- Asa Jay Laughton - sent from somewhere other than home ****************************************************** http://www.w7tsc.org http://www.teampanteraracing.com
Michael, Water is designed to flow through the doors. There are drains at the bottom which should be clear, and any debris in the door should be vacuumed up to keep from turning to mud which rusts the doors from the inside. The only reason for the plastic is to prevent rainwater/washing water from soaking the back side of the card. It should therefore be retained. Mike Sent from my iPhone On Jun 17, 2016, at 10:13, Michael Barnes <michaelbarnessrt10@hotmail.co.uk> wrote:
Michael
Michael
I know my door cards don't have a plastic backer (and really should). What would be the best vapor barrier to use? Tyvek, 3-mil polyethylene sheeting or something else? Mahalo, Scott -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, June 17, 2016 9:48 AM To: Michael Barnes Cc: Detomaso Subject: Re: [DeTomaso] Door cards. Michael, Water is designed to flow through the doors. There are drains at the bottom which should be clear, and any debris in the door should be vacuumed up to keep from turning to mud which rusts the doors from the inside. The only reason for the plastic is to prevent rainwater/washing water from soaking the back side of the card. It should therefore be retained. Mike Sent from my iPhone On Jun 17, 2016, at 10:13, Michael Barnes <michaelbarnessrt10@hotmail.co.uk> wrote: the door behind the card as it causes condensation and inevitably corrosion" the links above.
message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Doors should have a thick plastic sheet glued to the metal frame of the door. Garbage bag isn't thick enough.... Mike Sent from my iPhone On Jun 17, 2016, at 12:58, "Scott Mead Photography" <scott@scottmeadphotography.com> wrote:
Mahalo,
Scott
Michael,
Michael
Thanks for the replies, it makes perfect sense to replace the plastic " gasket" to prevent warpage of the hardboard door card. Incidentally mine have small clear viewing panels in the plastic, what the hell are they for? Sent by Michael Barnes
Mahalo,
Scott
Michael,
Michael
Are your door panels actually a pressed cardboard type? I am working on mine right now and they are made of some kind plastic definitely not the cardboard type most older cars have. Another Pantera mystery? Peter check out our website at: www.whitehorseranch.com
From: michaelbarnessrt10@hotmail.co.uk Date: Sat, 18 Jun 2016 10:28:08 +0100 To: MikeLDrew@aol.com CC: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Door cards.
Mahalo,
Scott
Michael,
Michael
should). What
Mahalo,
Scott
Michael,
Michael
Are your door panels actually a pressed cardboard type? I am working on mine right now and they are made of some kind plastic definitely not the cardboard type most older cars have. Another Pantera mystery? Peter check out our website at: [1]www.whitehorseranch.com the door. Garbage bag isn't thick enough.... the bottom process list. list. list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.whitehorseranch.com/
On my '85 car, they are fiberglass if I remember correctly -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Peter Menyhart Sent: sábado, 18 de junio de 2016 14:34 To: michael barnes; mike drew Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Door cards. Are your door panels actually a pressed cardboard type? I am working on mine right now and they are made of some kind plastic definitely not the cardboard type most older cars have. Another Pantera mystery? Peter check out our website at: www.whitehorseranch.com the hell are they for?
What
Mahalo,
Scott
Michael,
Michael
Den 2016-06-18 kl. 15:18, skrev Charles McCall:
Yep, the same on my 84 GT5
Peter
Mahalo,
Scott
Michael,
Michael
!DSPAM:57654a4f59252219129925!
-- Real life: Thomas Törnblom Email: thomas@hax.se Snail mail: Banvallsvägen 14 Phone: +46 18 32 31 18 S - 754 40 Uppsala, Sweden Mobile: +46 76 209 8320
I believe 3400's are fiberglass also. From: Charles McCall <charlesmccall@gmail.com> To: 'Peter Menyhart' <pmenyhart@msn.com>; 'michael barnes' <michaelbarnessrt10@hotmail.co.uk>; 'mike drew' <mikeldrew@aol.com> Cc: detomaso@server.detomasolist.com Sent: Saturday, June 18, 2016 8:18 AM Subject: Re: [DeTomaso] Door cards. On my '85 car, they are fiberglass if I remember correctly -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Peter Menyhart Sent: sábado, 18 de junio de 2016 14:34 To: michael barnes; mike drew Cc: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Door cards. Are your door panels actually a pressed cardboard type? I am working on mine right now and they are made of some kind plastic definitely not the cardboard type most older cars have. Another Pantera mystery? Peter check out our website at: www.whitehorseranch.com the hell are they for?
What
Mahalo,
Scott
Michael,
Michael
From: [3]michaelbarnessrt10@hotmail.co.uk Date: Sat, 18 Jun 2016 10:28:08 +0100 To: [4]MikeLDrew@aol.com CC: [5]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Door cards.
_______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. I believe 3400's are fiberglass also. __________________________________________________________________ From: Charles McCall <charlesmccall@gmail.com> To: 'Peter Menyhart' <pmenyhart@msn.com>; 'michael barnes' <michaelbarnessrt10@hotmail.co.uk>; 'mike drew' <mikeldrew@aol.com> Cc: detomaso@server.detomasolist.com Sent: Saturday, June 18, 2016 8:18 AM Subject: Re: [DeTomaso] Door cards. On my '85 car, they are fiberglass if I remember correctly -----Original Message----- From: DeTomaso [mailto:[1]detomaso-bounces@server.detomasolist.com] On Behalf Of Peter Menyhart Sent: sA!bado, 18 de junio de 2016 14:34 To: michael barnes; mike drew Cc: [2]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Door cards. Are your door panels actually a pressed cardboard type? I am working on mine right now and they are made of some kind plastic definitely not the cardboard type most older cars have. Another Pantera mystery? Peter check out our website at: www.whitehorseranch.com the hell are they for?
should). What
Mahalo,
Scott
-----Original Message----- From: DeTomaso [mailto:[8]detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, June 17, 2016 9:48 AM To: Michael Barnes Cc: Detomaso Subject: Re: [DeTomaso] Door cards.
Michael,
On Jun 17, 2016, at 10:13, Michael Barnes <[9]michaelbarnessrt10@hotmail.co.uk> wrote:
Michael
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [10]DeTomaso@server.detomasolist.com [11]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [12]DeTomaso@server.detomasolist.com [13]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [14]DeTomaso@server.detomasolist.com [15]http://server.detomasolist.com/mailman/listinfo/detomaso
the door. Garbage bag isn't thick enough.... the bottom process list. list. the links above.
any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [16]DeTomaso@server.detomasolist.com [17]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:detomaso-bounces@server.detomasolist.com 2. mailto:detomaso@server.detomasolist.com 3. mailto:michaelbarnessrt10@hotmail.co.uk 4. mailto:MikeLDrew@aol.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:MikeLDrew@aol.com 7. mailto:scott@scottmeadphotography.com 8. mailto:detomaso-bounces@server.detomasolist.com 9. mailto:michaelbarnessrt10@hotmail.co.uk 10. mailto:DeTomaso@server.detomasolist.com 11. http://server.detomasolist.com/mailman/listinfo/detomaso 12. mailto:DeTomaso@server.detomasolist.com 13. http://server.detomasolist.com/mailman/listinfo/detomaso 14. mailto:DeTomaso@server.detomasolist.com 15. http://server.detomasolist.com/mailman/listinfo/detomaso 16. mailto:DeTomaso@server.detomasolist.com 17. http://server.detomasolist.com/mailman/listinfo/detomaso
participants (9)
B Hower
Charles McCall
Michael Barnes
michael barnes
Peter Menyhart
Thomas Tornblom
