Re: Techno Question: AC system dryer insulation
Hello Pantera loving people, Driers run hot and maybe hotter than its environment. Take a fast drive with a/c on max then stop and quickly check drier body temp and its surrounding metal with temp gun to see what they are. I believe the dryer maybe cooler than its area. So insulation only sounds good. Also your oil is cooler so to help the compressor. A drier should release temp not hold it. Thanks, Jeff Cobb Sent from my brain.
On May 30, 2025, at 5:20 PM, Charles Engles <cengles@cox.net> wrote: Dear Larry,
I believe that is a safety switch that cuts off the compressor if the system pressure is too high (above 400 psi) or too low (less than 28 psi). Many driers have an M10 x 1.25 threaded fitting for the above mentioned safety switch.
Warmest regards, Chuck Engles
-----Original Message----- From: Larry Stock [mailto:larrys@panteraparts.com] Sent: Friday, May 30, 2025 5:07 PM To: Larry Finch; detomaso@server.detomasolist.com Subject: [DeTomaso] Re: Techno Question: AC system dryer insulation
What kind of drier is that with an electrical plug in it?
On 5/30/25, 2:28 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com>> wrote:
Or you can just avoid the concern of engine bay heat while cleaning up the engine bay appearance by locating the drier in this manner inside the RR wheel well.
Larry
Sent from me using a magic, handheld electronic gizmo. _______________________________________________
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list -- detomaso@server.detomasolist.com <mailto:detomaso@server.detomasolist.com> To unsubscribe send an email to detomaso-leave@server.detomasolist.com <mailto:detomaso-leave@server.detomasolist.com>
Stupid me. I meant to write that the drier would be hotter than it surrounds. So you want it to vent away temps. Jeff Sent from my brain.
Larry
Jeff Cobb
Jeff Cobb
