Re: [DeTomaso] Which axles on which side?
Many screws on a car are sized based on other qualities than their mechanical strength. For instance, a fender may be held on by say ten 6 or 8 mm screws. The fender itself will rip like tin foil before any of the screws gives in. If you look at an open wheel race car you'll see many screws that look scary small in for instance the suspension. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com] Sent: 22/5/2016 5:16:05 PM To: guson@home.se Cc: detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Perhaps it just seems that the sizing is out of proportion to all of the other fasteners involved with suspension loads. Sent from my iPhone On May 22, 2016, at 10:28 AM, Tomas Gunnarsson <guson@home.se<mailto:guson@home.se>> wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com<mailto:lplugw@hotmail.com>] Sent: 22/5/2016 2:15:10 AM To: guson@home.se<mailto:guson@home.se> Cc: detomaso@detomasolist.com<mailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <guson@home.se<mailto:guson@home.se><mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com<mailto:lplugw@hotmail.com><mailto:lplugw@hotmail.com
] Sent: 20/5/2016 10:49:42 PM To: julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_ki ft@hotmail.com> Cc: MikeLDrew@aol.com<mailto:MikeLDrew@aol.com><mailto:MikeLDrew@aol.com>;de tomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:detomas o@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side?
On May 20, 2016, at 4:38 PM, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_k ift@hotmail.com>> wrote:
The axle nut is on there at 450 ft/lb but it is only keeping the axle tight in the inner race of the wheel bearings, rotational freedom being within the bearings and even though you are braking hard the axle is still rotating in a forward direction, plus the axle inner flange/half shaft is splined to the axle shaft and most of us do let of the gas when we brake!
Julian ________________________________________ From: marshall smith <marshallgsmith@sbcglobal.net<mailto:marshallgsmith@sbcglobal.net><mailt o:marshallgsmith@sbcglobal.net>> Sent: Friday, May 20, 2016 1:16 PM To: Douglas Kelm; 'Mike Drew'; detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:detom aso@detomasolist.com>; Julian Kift Subject: Re: [DeTomaso] Which axles on which side?
Okay...really dumb question here. Wouldn't hard braking want to loosen
That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone the axle nut??
M -------------------------------------------- On Fri, 5/20/16, Julian Kift
Subject: Re: [DeTomaso] Which axles on which side? To: "Douglas Kelm"
<dakelm@qwest.net<mailto:dakelm@qwest.net><mailto:dakelm@qwest.net>>, "'Mike Drew'" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com><mailto:MikeLDrew@aol.com>>, "detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:deto maso@detomasolist.com>" <detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:deto maso@detomasolist.com>>
Date: Friday, May 20, 2016, 1:12 PM
Doug,
Remember the axle nut is on the inside of the wheel in this case, if it were RH then the counter clockwise motion of the axle would want to undo it!
Julian
________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server .detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Douglas Kelm <dakelm@qwest.net<mailto:dakelm@qwest.net><mailto:dakelm@qwest.net>> Sent: Friday, May 20, 2016 12:52 PM To: 'Mike Drew'; detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:detom aso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side?
I would think that the "righty tighty" threads (normal) go on the left side of the vehicle. Think of the nut being stationary while the axle (on the drivers side) rotates counter clockwise (looking from outside the car), meaning the nut wants to self tighten (rotate clockwise), which is the desired situation. Of course, there's a 50/50 chance that I'm completely full of "it"!
Doug
-----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, May 20, 2016 12:34 PM To: detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:detom aso@detomasolist.com> Subject: [DeTomaso] Which axles on which side?
Hi guys,
I thought I would lead off with he first technical question on the new forum.
The rear axles are marked S and D, for 'left' and 'right' respectively. But that speaks to the thread direction (one of them is reverse thread, left to tighten)
It's my belief that the S or left-tighten axle goes on the left side of the car but I can't remember for sure. Can somebody confirm or deny?
Thanks!
And welcome back!
Sent from my iPhone _______________________________________________
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com <mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso
To manage your subscription (change email address, unsubscribe, etc.) use the links above. _______________________________________________
To manage your subscription (change email address, unsubscribe, etc.) use the links above. Many screws on a car are sized based on other qualities than their mechanical strength. For instance, a fender may be held on by say ten 6 or 8 mm screws. The fender itself will rip like tin foil before any of the screws gives in. If you look at an open wheel race car you'll see many screws that look scary small in for instance the suspension. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com] Sent: 22/5/2016 5:16:05 PM To: guson@home.se Cc: detomaso@detomasolist.com Subject: Re: [DeTomaso] Which axles on which side? Ok. Perhaps it just seems that the sizing is out of proportion to all of the other fasteners involved with suspension loads. Sent from my iPhone On May 22, 2016, at 10:28 AM, Tomas Gunnarsson <guson@home.se<mailto:guson@home.se>> wrote: An M6 screw has a core diameter of 5 mm. A 5 mm dia rod has an area of 19.6 mm2. An ordinare 8.8 grade screw has a yield strength of 640 N/mm2 and a tensile strength of 800 N/mm2. 19.6 x 640 N is 12544 N whis is a little less than what a Pantera would require to be lifted in all. 19.6 x 800 is 15680 N which is enough with a margin. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com<mailto:lplugw@hotmail.com>] Sent: 22/5/2016 2:15:10 AM To: guson@home.se<mailto:guson@home.se> Cc: detomaso@detomasolist.com<mailto:detomaso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? Ok. Not sure about the physics of all of it, but if that's the case, there are four of them. Sent from my iPhone On May 21, 2016, at 5:14 PM, Tomas Gunnarsson <guson@home.se<mailto:guson@home.se><mailto:guson@home.se>> wrote: A single six mm diameter screw itself is just about able to lift the weight of the car. Tomas <-----Ursprungligt Meddelande-----> From: Larry Weston [lplugw@hotmail.com<mailto:lplugw@hotmail.com><mailto:lplugw@hotmail.co m>] Sent: 20/5/2016 10:49:42 PM To: julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_k ift@hotmail.com> Cc: MikeLDrew@aol.com<mailto:MikeLDrew@aol.com><mailto:MikeLDrew@aol.com>;d etomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:detom aso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side? That being said, I have sometimes wondered about the faith we put in that 1/8" thick bearing retainer plate we secure with four six mm diameter flathead screws. That seems like a weak link. Best not to think about it to much I decided. Sent from my iPhone
On May 20, 2016, at 4:38 PM, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_ kift@hotmail.com>> wrote:
Julian ________________________________________ From: marshall smith <marshallgsmith@sbcglobal.net<mailto:marshallgsmith@sbcglobal.net><mail to:marshallgsmith@sbcglobal.net>> Sent: Friday, May 20, 2016 1:16 PM To: Douglas Kelm; 'Mike Drew'; detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:deto maso@detomasolist.com>; Julian Kift Subject: Re: [DeTomaso] Which axles on which side?
Okay...really dumb question here. Wouldn't hard braking want to loosen the axle nut??
M -------------------------------------------- On Fri, 5/20/16, Julian Kift <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_ kift@hotmail.com>> wrote:
Subject: Re: [DeTomaso] Which axles on which side? To: "Douglas Kelm" <dakelm@qwest.net<mailto:dakelm@qwest.net><mailto:dakelm@qwest.net>>, "'Mike Drew'" <MikeLDrew@aol.com<mailto:MikeLDrew@aol.com><mailto:MikeLDrew@aol.com>> , "detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:det omaso@detomasolist.com>" <detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:det omaso@detomasolist.com>> Date: Friday, May 20, 2016, 1:12 PM
Doug,
Julian
________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@serve r.detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Douglas Kelm <dakelm@qwest.net<mailto:dakelm@qwest.net><mailto:dakelm@qwest.net>> Sent: Friday, May 20, 2016 12:52 PM To: 'Mike Drew'; detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:deto maso@detomasolist.com> Subject: Re: [DeTomaso] Which axles on which side?
Doug
-----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Mike Drew via DeTomaso Sent: Friday, May 20, 2016 12:34 PM To: detomaso@detomasolist.com<mailto:detomaso@detomasolist.com><mailto:deto maso@detomasolist.com> Subject: [DeTomaso] Which axles on which side?
Hi guys,
Thanks!
And welcome back!
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.co m><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Forum NO LONGER Managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.co m><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above.
Tomas Gunnarsson
