Re: [DeTomaso] McLeod hydraulic throw out
The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <detomaso-bounces@server.detomasolist.com on behalf of will.kooiman@gmail.com> wrote:
Wow.
I have one in my Cobra, and so far it has worked perfectly.
My Cobra came with an external slave from a Volvo that was readily available 20 years ago, but is now unobtanium. Rather than building a new bracket for a different slave, I switched to a McLeod slave.
At any rate, as I said, it has worked perfectly - so far.
-- Will
On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" <detomaso@server.detomasolist.com> wrote:
Cullen,
2511 came equipped with one of those from Dennis when I purchased it in 2002. Since then I have rebuilt the unit twice (three?) and most recently did so using what I believe to be their current offering. I spoke with and ordered directly from McLeod.
My opinion, in brief, is a very simple "NO!!"
The current offering was shipped to me with an incorrect input snout spacer (I solved that by using the old spacer which luckily I still had on hand), and the stainless steel input line, due to its 90° fitting where one should have used a 45° fitting, twisted itself, unseen of course, within the bell housing when it was connected to the hard line attached to the chassis rails. Even stainless steel lines don't hold up very long against grinding by a pressure plate.
The stainless steel bleed line is about 4 inches too long, sticking outside the bell housing in a terrible display of ugly.
Finally, my last experience started with me ordering the same rebuild kit I had previously used, using the same number off of the previous invoice. What I received from them was the rebuild kit for the current unit which uses an entirely different set of all rings. I ultimately determined that for all three generations of their hydraulic bearing McLeod has used exactly the same rebuild kit part number. They added no suffix such as a A or a B which to me seems indicative of a problem within the company. No, they no longer support a rebuild kit for the first two generations.
While you have some experience in using one of these previously, the task of establishing proper free play and clearances is quite exacting and unforgiving. If you get it wrong there is nothing left to do but pull the transaxle and start all over again.
The unit I have is now adjusted for the factory shortcomings and as has been my experience for over 50,000 miles, the system works just fine. Dennis however no longer recommends their installation and based on my experience I would not encourage any other owners to venture down that road for themselves.
Feel free to reach out to me off-line or by phone for more of the gory details.
Larry
Sent from me using a magic, handheld electronic gizmo. _______________________________________________
Heat? As I previously wrote, I have over 50,000 miles using one of the McLeod systems. Those 50,000 miles have all been WITH a black plastic plug in the hole that some wish to call a ventilation hole rather than an inspection hole. Your choice, I don't really care. Whatever heat issues may or may not be present, with or without a plug, have never appeared to be an issue in any way, shape or form in my many years of experience. I am all ears if Larry or anyone else has history that supports a failure of the McLeod unit from excessive heat. Larry Sent from me using a magic, handheld electronic gizmo.
Wow.
-- Will
Cullen,
Larry
well, I have the quicktime bellhousing for the ZF on 4653. I forgot to mention that. Also didn't consider it would be relevant. hmmmm. On Fri, Sep 16, 2016 at 3:53 PM, Larry Stock <larrys@panteraparts.com> wrote:
Wow.
-- Will
Cullen,
Larry
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [5]DeTomaso@server.detomasolist.com [6]http://server.detomasolist.com/mailman/listinfo/detomaso
They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [7]DeTomaso@server.detomasolist.com [8]http://server.detomasolist.com/mailman/listinfo/detomaso
well, I have the quicktime bellhousing for the ZF on 4653. I forgot to mention that. Also didn't consider it would be relevant. hmmmm. On Fri, Sep 16, 2016 at 3:53 PM, Larry Stock <[1]larrys@panteraparts.com> wrote: The basic problem is that the bell housing is too confined and not ventilated well enough to dissipate the heat. The Superformance is using a Quick Time bell housing that has much more ventilation than the DeTomaso Bell housing. Just another reason not to run those Plugs that some vendors offer, that close off the inspection hole at the left hand top of the bell housing. That is the only heat dissipation vent there is. Larry On 9/16/16, 1:26 PM, "DeTomaso on behalf of Will Kooiman" <[2]detomaso-bounces@server.detomasolist.com on behalf of [3]will.kooiman@gmail.com> wrote: >Wow. > >I have one in my Cobra, and so far it has worked perfectly. > >My Cobra came with an external slave from a Volvo that was readily >available 20 years ago, but is now unobtanium.A Rather than building a new >bracket for a different slave, I switched to a McLeod slave. > >At any rate, as I said, it has worked perfectly - so far. > >-- >Will > > > > > >On 9/16/16 3:35 PM, "Larry Finch via DeTomaso" ><[4]detomaso@server.detomasolist.com> wrote: > >>Cullen, >> >>2511 came equipped with one of those from Dennis when I purchased it in >>2002. Since then I have rebuilt the unit twice (three?) and most recently >>did so using what I believe to be their current offering. I spoke with >>and ordered directly from McLeod. >> >>My opinion, in brief, is a very simple "NO!!" >> >>The current offering was shipped to me with an incorrect input snout >>spacer (I solved that by using the old spacer which luckily I still had >>on hand), and the stainless steel input line, due to its 90ADEG fitting >>where one should have used a 45ADEG fitting, twisted itself, unseen of >>course, within the bell housing when it was connected to the hard line >>attached to the chassis rails. Even stainless steel lines don't hold up >>very long against grinding by a pressure plate. >> >>The stainless steel bleed line is about 4 inches too long, sticking >>outside the bell housing in a terrible display of ugly. >> >>Finally, my last experience started with me ordering the same rebuild kit >>I had previously used, using the same number off of the previous invoice. >>What I received from them was the rebuild kit for the current unit which >>uses an entirely different set of all rings. I ultimately determined that >>for all three generations of their hydraulic bearing McLeod has used >>exactly the same rebuild kit part number. They added no suffix such as a >>A A or a AB which to me seems indicative of a problem within the company. >>No, they no longer support a rebuild kit for the first two generations. >> >>While you have some experience in using one of these previously, the task >>of establishing proper free play and clearances is quite exacting and >>unforgiving. If you get it wrong there is nothing left to do but pull the >>transaxle and start all over again. >> >>The unit I have is now adjusted for the factory shortcomings and as has >>been my experience for over 50,000 miles, the system works just fine. >>Dennis however no longer recommends their installation and based on my >>experience I would not encourage any other owners to venture down that >>road for themselves. >> >>Feel free to reach out to me off-line or by phone for more of the gory >>details. >> >>Larry >> >>Sent from me using a magic, handheld electronic gizmo. list. list.
_______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com [10]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:larrys@panteraparts.com 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:will.kooiman@gmail.com 4. mailto:detomaso@server.detomasolist.com 5. mailto:DeTomaso@server.detomasolist.com 6. http://server.detomasolist.com/mailman/listinfo/detomaso 7. mailto:DeTomaso@server.detomasolist.com 8. http://server.detomasolist.com/mailman/listinfo/detomaso 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso
Cullen McCann
