Re: [DeTomaso] Heater Vent Registers
But one big problem: You can get the little grills that direct the air but you CANNOT find the housing, either the late plastic or the early vinyl-wrapped metal ones to hold the little grills in place in the dash. If any one knows of a source I may be a customer. Vendors don't have them. Jim Gray -----Original Message----- From: Charles Engles Sent: Thursday, June 30, 2016 6:47 PM To: 'MyCars' ; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Heater Vent Registers Dear Roydon, Good news: yes the Pantera dash vent registers come from seventies Ford vehicles Bad news: I can't remember if they were same vintage Thunderbirds or another model Good news: someone else who knows the answer will see this. Stiff upper lip, Chuck Engles -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of MyCars Sent: Thursday, June 30, 2016 6:37 PM To: detomaso@server.detomasolist.com Subject: [DeTomaso] Heater Vent Registers Hello, Anyone know if the heater vent registers were used in other cars (ford or italian). I need to get 3, mine always fall out when I apply the gas. Thanks Roydon _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
Roydon , If your only issue with your vents is that they are loose and fall out , I was able to fix that issue on a set I have by sliding a thin piece of metal ( or plastic , I forget which ) behind the plastic tabs that they swivel on help them engage the outer housing deeper and more securely . Caution is advised however since the tabs could conceivably be snapped off if they are bent out too far out . - Also keeping a stiff upper lip , :) , Jim Coyne
From: grayjim@cox.net To: cengles@cox.net; mycars@comcast.net; detomaso@server.detomasolist.com Date: Thu, 30 Jun 2016 19:34:20 -0500 Subject: Re: [DeTomaso] Heater Vent Registers
Jim Gray
Dear Roydon,
Roydon , If your only issue with your vents is that they are loose and fall out , I was able to fix that issue on a set I have by sliding a thin piece of metal ( or plastic , I forget which ) behind the plastic tabs that they swivel on help them engage the outer housing deeper and more securely . Caution is advised however since the tabs could conceivably be snapped off if they are bent out too far out . - Also keeping a stiff upper lip , :) , Jim Coyne them.
Jim Gray
Dear Roydon,
Behalf list. list. list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
The plastic tabs are broken on at least 2 of the vents, so I will just replace all 3. I found images of Thunderbirds with the vents, but cannot find the actual parts anywhere. I may check with 1 of the Pantera vendors later this summer after I transport the car down here. It's no rush, sometimes I just like the hunt Roydon On 6/30/2016 5:46 PM, James coyne wrote:
Roydon , If your only issue with your vents is that they are loose and fall out , I was able to fix that issue on a set I have by sliding a thin piece of metal ( or plastic , I forget which ) behind the plastic tabs that they swivel on help them engage the outer housing deeper and more securely . Caution is advised however since the tabs could conceivably be snapped off if they are bent out too far out . - Also keeping a stiff upper lip , :) , Jim Coyne > From: grayjim@cox.net > To: cengles@cox.net; mycars@comcast.net; detomaso@server.detomasolist.com > Date: Thu, 30 Jun 2016 19:34:20 -0500 > Subject: Re: [DeTomaso] Heater Vent Registers > > But one big problem: You can get the little grills that direct the air but > you CANNOT find the housing, either the late plastic or the early > vinyl-wrapped metal ones to hold the little grills in place in the dash. If > any one knows of a source I may be a customer. Vendors don't have them. > > Jim Gray > > -----Original Message----- > From: Charles Engles > Sent: Thursday, June 30, 2016 6:47 PM > To: 'MyCars' ; detomaso@server.detomasolist.com > Subject: Re: [DeTomaso] Heater Vent Registers > > Dear Roydon, > > > Good news: yes the Pantera dash vent registers come from > seventies Ford vehicles > > Bad news: I can't remember if they were same vintage > Thunderbirds or another model > > Good news: someone else who knows the answer will see this. > > > Stiff upper lip, Chuck Engles > > > > -----Original Message----- > From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf > Of MyCars > Sent: Thursday, June 30, 2016 6:37 PM > To: detomaso@server.detomasolist.com > Subject: [DeTomaso] Heater Vent Registers > > Hello, > Anyone know if the heater vent registers were used in other cars (ford or > italian). I need to get 3, mine always fall out when I apply the gas. > > Thanks > Roydon > _______________________________________________ > > > Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 > Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com > http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use > the links above. > > Members who post to this list grant license to the list to forward any > message posted here to all past, current, or future members of the list. > They also grant the list owner permission to maintain an archive or approve > the archiving of list messages. > > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > DeTomaso@server.detomasolist.com > http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use > the links above. > > Members who post to this list grant license to the list to forward any > message posted here to all past, current, or future members of the list. > They also grant the list owner permission to maintain an archive or approve > the archiving of list messages. > > _______________________________________________ > > > Detomaso Email List is not managed by POCA > Posted emails must not exceed 1.5 Megabytes > DeTomaso mailing list > DeTomaso@server.detomasolist.com > http://server.detomasolist.com/mailman/listinfo/detomaso > > To manage your subscription (change email address, unsubscribe, etc.) use the links above. > > Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
From: [1]grayjim@cox.net To: [2]cengles@cox.net; [3]mycars@comcast.net; [4]detomaso@server.detomasolist.com Date: Thu, 30 Jun 2016 19:34:20 -0500 Subject: Re: [DeTomaso] Heater Vent Registers
The plastic tabs are broken on at least 2 of the vents, so I will just replace all 3. I found images of Thunderbirds with the vents, but cannot find the actual parts anywhere. I may check with 1 of the Pantera vendors later this summer after I transport the car down here. It's no rush, sometimes I just like the hunt Roydon On 6/30/2016 5:46 PM, James coyne wrote: Roydon , If your only issue with your vents is that they are loose and fall out , I was able to fix that issue on a set I have by sliding a thin piece of metal ( or plastic , I forget which ) behind the plastic tabs that they swivel on help them engage the outer housing deeper and more securely . Caution is advised however since the tabs could conceivably be snapped off if they are bent out too far out . - Also keeping a stiff upper lip , :) , Jim Coyne them.
Jim Gray
-----Original Message----- From: Charles Engles Sent: Thursday, June 30, 2016 6:47 PM To: 'MyCars' ; [5]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Heater Vent Registers
Dear Roydon,
-----Original Message----- From: DeTomaso [[6]mailto:detomaso-bounces@server.detomasolist.com] On
Of MyCars Sent: Thursday, June 30, 2016 6:37 PM To: [7]detomaso@server.detomasolist.com Subject: [DeTomaso] Heater Vent Registers
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [8]DeTomaso@server.detomasolist.com [9]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [10]DeTomaso@server.detomasolist.com [11]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [12]DeTomaso@server.detomasolist.com [13]http://server.detomasolist.com/mailman/listinfo/detomaso
Behalf list. list. list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [14]DeTomaso@server.detomasolist.com [15]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the li nks above. Members who post to this list grant license to the list to forward any message p osted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of lis t messages. References 1. mailto:grayjim@cox.net 2. mailto:cengles@cox.net 3. mailto:mycars@comcast.net 4. mailto:detomaso@server.detomasolist.com 5. mailto:detomaso@server.detomasolist.com 6. mailto:detomaso-bounces@server.detomasolist.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:DeTomaso@server.detomasolist.com 9. http://server.detomasolist.com/mailman/listinfo/detomaso 10. mailto:DeTomaso@server.detomasolist.com 11. http://server.detomasolist.com/mailman/listinfo/detomaso 12. mailto:DeTomaso@server.detomasolist.com 13. http://server.detomasolist.com/mailman/listinfo/detomaso 14. mailto:DeTomaso@server.detomasolist.com 15. http://server.detomasolist.com/mailman/listinfo/detomaso
My remedy for the issue was to gently pry out the pivot tabs and 're temper' them with heat from the heat gun I use to set heat shrink wire insulation. Tension restored, no shims required and no tabs snapped. Sent from my iPhone
Jim Gray
Dear Roydon,
Sounds like a great solution. Thanks for sharing with the rest of us. Bud #3400 ( Drive it like there is no tomorrow -- for there may not be ! ) From: Larry Weston <lplugw@hotmail.com> To: James coyne <tecnosound@hotmail.com> Cc: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Sent: Friday, July 1, 2016 7:02 AM Subject: Re: [DeTomaso] Heater Vent Registers My remedy for the issue was to gently pry out the pivot tabs and 're temper' them with heat from the heat gun I use to set heat shrink wire insulation. Tension restored, no shims required and no tabs snapped. Sent from my iPhone
Jim Gray
Dear Roydon,
From: [2]grayjim@cox.net To: [3]cengles@cox.net; [4]mycars@comcast.net; [5]detomaso@server.detomasolist.com Date: Thu, 30 Jun 2016 19:34:20 -0500 Subject: Re: [DeTomaso] Heater Vent Registers
Jim Gray
-----Original Message----- From: Charles Engles Sent: Thursday, June 30, 2016 6:47 PM To: 'MyCars' ; [6]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Heater Vent Registers
Dear Roydon,
-----Original Message----- From: DeTomaso [mailto:[7]detomaso-bounces@server.detomasolist.com]
Of MyCars Sent: Thursday, June 30, 2016 6:37 PM To: [8]detomaso@server.detomasolist.com Subject: [DeTomaso] Heater Vent Registers
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [9]DeTomaso@server.detomasolist.com [10]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [11]DeTomaso@server.detomasolist.com [12]http://server.detomasolist.com/mailman/listinfo/detomaso
On Behalf list. list.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [13]DeTomaso@server.detomasolist.com [14]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [15]DeTomaso@server.detomasolist.com [16]http://server.detomasolist.com/mailman/listinfo/detomaso
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. Sounds like a great solution. Thanks for sharing with the rest of us. Bud #3400 ( Drive it like there is no tomorrow -- for there may not be ! ) __________________________________________________________________ From: Larry Weston <lplugw@hotmail.com> To: James coyne <tecnosound@hotmail.com> Cc: "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Sent: Friday, July 1, 2016 7:02 AM Subject: Re: [DeTomaso] Heater Vent Registers My remedy for the issue was to gently pry out the pivot tabs and 're temper' them with heat from the heat gun I use to set heat shrink wire insulation. Tension restored, no shims required and no tabs snapped. Sent from my iPhone plastic the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [17]DeTomaso@server.detomasolist.com [18]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:tecnosound@hotmail.com 2. mailto:grayjim@cox.net 3. mailto:cengles@cox.net 4. mailto:mycars@comcast.net 5. mailto:detomaso@server.detomasolist.com 6. mailto:detomaso@server.detomasolist.com 7. mailto:detomaso-bounces@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:DeTomaso@server.detomasolist.com 10. http://server.detomasolist.com/mailman/listinfo/detomaso 11. mailto:DeTomaso@server.detomasolist.com 12. http://server.detomasolist.com/mailman/listinfo/detomaso 13. mailto:DeTomaso@server.detomasolist.com 14. http://server.detomasolist.com/mailman/listinfo/detomaso 15. mailto:DeTomaso@server.detomasolist.com 16. http://server.detomasolist.com/mailman/listinfo/detomaso 17. mailto:DeTomaso@server.detomasolist.com 18. http://server.detomasolist.com/mailman/listinfo/detomaso
Jim, That part sounds like a candidate for 3D printing. Unfortunately I am not to the stage of being able to create the STL file. Trying to learn 3D CAD, jerry knotts On 6/30/2016 7:34 PM, Jim Gray wrote:
Jim Gray
Dear Roydon,
Not true Jim, Pantera Parts Connection has both types of housings and the vent grills in stock. We have been looking into remanufacturing these which are up to 8 pieces per assembly using 3D manufacturing with our CNC manufacturing capabilities. Larry Stock On 6/30/16, 5:34 PM, "DeTomaso on behalf of Jim Gray" <detomaso-bounces@server.detomasolist.com on behalf of grayjim@cox.net> wrote:
Jim Gray
Dear Roydon,
All hail to the 3-D printer. ;-) "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Larry Stock <larrys@panteraparts.com<mailto:larrys@panteraparts.com>> Date: Friday, July 1, 2016 8:23 AM To: Jim Gray <grayjim@cox.net<mailto:grayjim@cox.net>>, Charles Engles <cengles@cox.net<mailto:cengles@cox.net>>, 'MyCars' <mycars@comcast.net<mailto:mycars@comcast.net>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Heater Vent Registers Not true Jim, Pantera Parts Connection has both types of housings and the vent grills in stock. We have been looking into remanufacturing these which are up to 8 pieces per assembly using 3D manufacturing with our CNC manufacturing capabilities. Larry Stock On 6/30/16, 5:34 PM, "DeTomaso on behalf of Jim Gray" <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com> on behalf of grayjim@cox.net<mailto:grayjim@cox.net>> wrote: But one big problem: You can get the little grills that direct the air but you CANNOT find the housing, either the late plastic or the early vinyl-wrapped metal ones to hold the little grills in place in the dash. If any one knows of a source I may be a customer. Vendors don't have them. Jim Gray -----Original Message----- From: Charles Engles Sent: Thursday, June 30, 2016 6:47 PM To: 'MyCars' ; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Heater Vent Registers Dear Roydon, Good news: yes the Pantera dash vent registers come from seventies Ford vehicles Bad news: I can't remember if they were same vintage Thunderbirds or another model Good news: someone else who knows the answer will see this. Stiff upper lip, Chuck Engles -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of MyCars Sent: Thursday, June 30, 2016 6:37 PM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: [DeTomaso] Heater Vent Registers Hello, Anyone know if the heater vent registers were used in other cars (ford or italian). I need to get 3, mine always fall out when I apply the gas. Thanks Roydon _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. All hail to the 3-D printer. ;-) "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Larry Stock <[3]larrys@panteraparts.com> Date: Friday, July 1, 2016 8:23 AM To: Jim Gray <[4]grayjim@cox.net>, Charles Engles <[5]cengles@cox.net>, 'MyCars' <[6]mycars@comcast.net>, "[7]detomaso@server.detomasolist.com" <[8]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Heater Vent Registers Not true Jim, Pantera Parts Connection has both types of housings and the vent grills in stock. We have been looking into remanufacturing these which are up to 8 pieces per assembly using 3D manufacturing with our CNC manufacturing capabilities. Larry Stock On 6/30/16, 5:34 PM, "DeTomaso on behalf of Jim Gray" <[9]detomaso-bounces@server.detomasolist.com on behalf of [10]grayjim@cox.net> wrote: But one big problem: You can get the little grills that direct the air but you CANNOT find the housing, either the late plastic or the early vinyl-wrapped metal ones to hold the little grills in place in the dash. If any one knows of a source I may be a customer. Vendors don't have them. Jim Gray -----Original Message----- From: Charles Engles Sent: Thursday, June 30, 2016 6:47 PM To: 'MyCars' ; [11]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Heater Vent Registers Dear Roydon, Good news: yes the Pantera dash vent registers come from seventies Ford vehicles Bad news: I can't remember if they were same vintage Thunderbirds or another model Good news: someone else who knows the answer will see this. Stiff upper lip, Chuck Engles -----Original Message----- From: DeTomaso [[12]mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of MyCars Sent: Thursday, June 30, 2016 6:37 PM To: [13]detomaso@server.detomasolist.com Subject: [DeTomaso] Heater Vent Registers Hello, Anyone know if the heater vent registers were used in other cars (ford or italian). I need to get 3, mine always fall out when I apply the gas. Thanks Roydon _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [14]DeTomaso@server.detomasolist.com [15]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [16]DeTomaso@server.detomasolist.com [17]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [18]DeTomaso@server.detomasolist.com [19]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [20]DeTomaso@server.detomasolist.com [21]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:larrys@panteraparts.com 4. mailto:grayjim@cox.net 5. mailto:cengles@cox.net 6. mailto:mycars@comcast.net 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso-bounces@server.detomasolist.com 10. mailto:grayjim@cox.net 11. mailto:detomaso@server.detomasolist.com 12. mailto:detomaso-bounces@server.detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:DeTomaso@server.detomasolist.com 15. http://server.detomasolist.com/mailman/listinfo/detomaso 16. mailto:DeTomaso@server.detomasolist.com 17. http://server.detomasolist.com/mailman/listinfo/detomaso 18. mailto:DeTomaso@server.detomasolist.com 19. http://server.detomasolist.com/mailman/listinfo/detomaso 20. mailto:DeTomaso@server.detomasolist.com 21. http://server.detomasolist.com/mailman/listinfo/detomaso
I think 1981 Lincoln Continental MkIII
On Jul 1, 2016, at 8:27 AM, Himes, Terry (397C) <terry.himes@jpl.nasa.gov> wrote:
Terry W. Himes
Fax: (818) 393-3147
but
If
Jim Gray
Dear Roydon,
Of MyCars
Hello,
Thanks
Roydon
1.5
the links above.
approve
the links above.
approve
the links above.
1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:larrys@panteraparts.com 4. mailto:grayjim@cox.net 5. mailto:cengles@cox.net 6. mailto:mycars@comcast.net 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso-bounces@server.detomasolist.com 10. mailto:grayjim@cox.net 11. mailto:detomaso@server.detomasolist.com 12. mailto:detomaso-bounces@server.detomasolist.com 13. mailto:detomaso@server.detomasolist.com 14. mailto:DeTomaso@server.detomasolist.com 15. http://server.detomasolist.com/mailman/listinfo/detomaso 16. mailto:DeTomaso@server.detomasolist.com 17. http://server.detomasolist.com/mailman/listinfo/detomaso 18. mailto:DeTomaso@server.detomasolist.com 19. http://server.detomasolist.com/mailman/listinfo/detomaso 20. mailto:DeTomaso@server.detomasolist.com 21. http://server.detomasolist.com/mailman/listinfo/detomaso _______________________________________________
participants (9)
B Hower
Jack Donahue
James coyne
Jerry Knotts
Jim Gray
Larry Weston
MyCars
