I've never had a radiator shop charge anything to test one. You have some expensive radiator shops up there! m -------------------------------------------- On Wed, 7/27/16, Ken and Lela MacArthur <klckmac@msn.com> wrote: Subject: Re: [DeTomaso] Cooling system To: "Himes, Terry (397C)" <terry.himes@jpl.nasa.gov>, "MikeLDrew@aol.com" <MikeLDrew@aol.com>, "detomaso@server.detomasolist.com" <detomaso@server.detomasolist.com> Date: Wednesday, July 27, 2016, 10:46 AM Getting 2nd opinion today. This shop thinks it looks ok, just age on it, will do a $30 test, but seems pretty optimistic it's not a total re-do like the other shop. Crossing my fingers. He was surprised the other shop just made a diagnosis without a test, which tells me which shop to avoid. __________________________________________________________________ From: Himes, Terry (397C) <terry.himes@jpl.nasa.gov> Sent: Wednesday, July 27, 2016 7:15 AM To: MikeLDrew@aol.com; klckmac@msn.com; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Cooling system I agree with Mike. I have my original radiator with new fans and it is still functioning perfectly. <knock on wood>. I'm no expert but it doesn't make sense to spend a ton of money. I do have to pull some preventative maintenance on my 42 year old radiator, but I'm not going to spend a lot to do it. That's my plan anyway. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Mike Drew via DeTomaso <[3]detomaso@server.detomasolist.com> Reply-To: "[4]MikeLDrew@aol.com" <[5]MikeLDrew@aol.com> Date: Tuesday, July 26, 2016 4:33 PM To: "[6]klckmac@msn.com" <[7]klckmac@msn.com>, "[8]detomaso@server.detomasolist.com" <[9]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Cooling system In a message dated 7/26/16 8 41 31, [10]klckmac@msn.com writes: Looking for advice on the newer aluminum radiators and stainless tube sets offered out there. I just took my OLD Hall brass one in for repairs and they want $650 for a re-do. I could get a new one for that price, but would like to know who has upgraded to a turn key kit like PIM offers or other dealer and if you would recommend any particular setup. Ken, Lots of people are proposing a $1500 fix to a $200 problem. For sure, that would work, but is it necessary? No. The first thing you need to do is find another radiator shop. The quote they gave you is absurd. Likely they are proposing an entirely new core for your existing tanks, which amounts to buying a whole new radiator. If your core is well and truly shot, then yes, you might as well just get a new radiator, but in that case I would just buy another one like you have now. By way of contrast to the megabucks suggestions, consider this: A few years ago, Wilkinson gave Lori an old Hall radiator for free. He had removed it from a customer's car when that guy 'upgraded' to a megabuck Fluidyne radiator and sucker fan setup. Steve actually offered me the choice of several old radiators, and I took the best-looking one, knowing it needed work. I brought it to a radiator shop out in the country a half-hour from my house. They pressure-tested it and found several leaks, from failures in the brazing around the drain petcock caused by overtightening, and from the junction of the core and one of the end tanks. They fixed all the leaks, pressure-tested it, painted it and gave it back to me, looking as good as new and guaranteed to work. For this, they charged me FORTY dollars. Not $650, not anything close. That radiator, with Hall Meriah fans, keeps her car running at a rock-solid 180 degrees in all conditions, including extended periods of idling in Las Vegas traffic with ambient temps nearing 100 degrees, and has been doing so now for years. Yes, you could spend a ton of money on an all-new setup. But as long as your existing core is good (and why wouldn't it be?), you should be able to get minor leaks repaired easily for a fraction of the cost of buying a new Hall replacement radiator, never mind the megabuck setup. One tremendous advantage of a brass radiator (any brass radiator) is that it can normally be repaired easily if it suffers damage when you're on the road. The aluminum radiators are glued together and normally not easily repaired--if they can be repaired at all. So while Hall recently failed to warranty their product per Chuck's testimony, at least their product is infinitely repairable. A Mangusta owner from England who was driving to the south of France earlier this month wound up going home on a tow truck because his radiator sprung a leak and it dribbled much of his coolant overboard. He failed to notice the water temp increase, but the subsequent oil temp increase and Expensive Noises from the engine got his attention! Had he been paying attention and thought about the problem a little bit, he could have easily had the car repaired and saved his vacation, since apparently the engine is actually unhurt and was simply rattling a bit due to the lifters not lifting as much due to the hot, thin oil. As it is, since he's not mechanically savvy he took the safe option and had the car towed back to England. But if he had an aluminum radiator, likely that would have been his only recourse. Just FWIW.... Mike References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:detomaso@server.detomasolist.com 4. mailto:MikeLDrew@aol.com 5. mailto:MikeLDrew@aol.com 6. mailto:klckmac@msn.com 7. mailto:klckmac@msn.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso@server.detomasolist.com 10. mailto:klckmac@msn.com -----Inline Attachment Follows----- _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages.
marshall smith
